11-01-2008, 02:53 PM
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville
, Wisconsin
Got the UGLY tail lights off!
Now I need a pic of what the original lights looked like...The ones on VTS appear to be only lenses...Any one have a pic of these....
Ive also started taking out the interior *gulp* Ill be posting pics on the near future of the winter project....
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
11-01-2008, 03:14 PM
1967 26' Overlander
Huntsville
, Alabama
My Overlander should be close
Originally Posted by aircooled4
...Now I need a pic of what the original lights looked like... Any one have a pic of these...
Jay,
Take a look at the attached image. There are a few more pictures at my website (link below).
PM me if you want close-up images.
Tom
11-01-2008, 03:20 PM
1971 31' Sovereign
1967 22' Safari
Pardeeville
, Wisconsin
Tom
youre taillights are different than pics ive seen of the Safari lights...(the ones on vintageairstream.com are taken too far away) Yours have the cast al. frame around them...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
11-01-2008, 03:37 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
In checking Vintaggeairstream.com it appears that there was a difference between the Land Yacht and Land Yacht International. It appears that the International had the cast aluminum trim and the Land Yacht had what appear to be Bargman 99 lights(?).
Good luck with your project!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
11-01-2008, 03:48 PM
Like this?
If they look like this, I can get you a great deal. Free for the asking, you arrange transport.
11-01-2008, 04:05 PM
1971 31' Sovereign
1967 22' Safari
Pardeeville
, Wisconsin
HMMMM...mine appear to have been just the lenses screwed to the body...not even recessed holders for the bulbs...
1967Safari4
This is what i believe mine had...are these the Bargman 99??
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
11-01-2008, 04:14 PM
Those are the Bargman 99, but they're out of stock, and have been for at least 6 weeks. If you get the lens, you can dummy up a base out of a coffee can, and add LED lamps.
11-01-2008, 05:02 PM
1971 31' Sovereign
1967 22' Safari
Pardeeville
, Wisconsin
Thanks for the info...I just might take you up on the ones you have...how much $$ and shipping... heres a pic i just took of the back of mine w/o the lights on it...the duct tape kinda makes it look like its been performaning at the local gentlemans club ;-)
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
11-01-2008, 05:25 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Is that round over square?
11-01-2008, 06:28 PM
1971 31' Sovereign
1967 22' Safari
Pardeeville
, Wisconsin
The squares are what i took off...not so nice...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
11-01-2008, 06:34 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Yep..
I think the Rounds look a little better but, I think the Squares are correct for the year?
11-01-2008, 06:55 PM
1971 31' Sovereign
1967 22' Safari
Pardeeville
, Wisconsin
the rounds were correct...the squares were some aftermarket cheap plastic things some PO had put on...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
11-01-2008, 09:51 PM
Retired.
, At Large
Now would be the time to update to LEDs. I found a stack of them in the back room at Inland, if you want a pair, give 'em a call on Monday.
11-01-2008, 09:58 PM
1967 22' Safari
MILAN
Tail lights
If you look at the picture posted by TomW you will see that the style lights that Mark is offering are outside the (center) flat panel. The International trim package taillights are mounted on the curved rear panels. Your standard taillights were mounted in the flat panel under the rear window. The ones offered to you won't cover the original mounting holes in that flat panel...fyi. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
11-01-2008, 10:03 PM
1967 22' Safari
MILAN
Leds
Terry, Would the ones you found at Inland work in the International trimmed light package? I guess I have to check with the Guru (Andy) and see if an upgrade is in my future! Thanks for the tip... Ed
11-02-2008, 03:10 AM
That's true. You also need to be willing to cut two holes in the outer skin because the cast aluminum housings need to be recessed into the skin. This is not a reversible change, and it wouldn't cover the existing holes. The rear picture shows how large the recess needs to be.
Anyway, I'll get a shipping weight on the aluminum ones tomorrow so you can estimate the shipping cost. But I want to be sure you will use them before I ship them to you.
11-02-2008, 03:49 AM
1971 31' Sovereign
1967 22' Safari
Pardeeville
, Wisconsin
Thanks for hte info guys...I think im going to go with the original style...Im not to keen on cutting irreversible holes to mount those...as for the LEDS...I may have to give Inland a call on monday...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
