Old 04-22-2014, 10:56 AM   #1
Darrengj's Avatar
1968 22' Safari
Fort Myers , Florida
Front frame crossmember replacement
I have removed the floor from the front of my 68 and found that the front crossmember is severely rusted. Does anyone know if this part is available anywhere, or if I should just plan to make a replacement?
Darren
ID:	210273   Click image for larger version
1968 Safari 22'
http://jenkinsonairstream.wordpress.com
Darrengj is offline   Reply With Quote
Old 04-22-2014, 10:59 AM   #2
1981 31' Excella II
New Market , Alabama
You need to replace it and the part that goes up the wall that connects to the cross member.
Perry
Old 04-22-2014, 11:03 AM   #3
Darrengj's Avatar
1968 22' Safari
Thanks for the quick response Perry. Do you know anywhere that I can get replacements for for those parts?
1968 Safari 22'
Old 04-22-2014, 11:11 AM   #4
1981 31' Excella II
I think you are going to have to make them or have them made. What is the cross section of the beam? Document and then try to find something close that will work. Members TOP (Lance) and 62Overlander (Frank) might have more information for you.
Perry
Old 04-22-2014, 11:15 AM   #5
Darrengj's Avatar
1968 22' Safari
The beam is shaped like a "U" or "C" facing back towards the trailer. At least that is what it looks like with it still installed. I was thinking that making the part would be the only option.
Darren
1968 Safari 22'
Old 04-22-2014, 12:09 PM   #6
1981 31' Excella II
A metal supplier or weld shop can probably fix you up.
Perry
Old 04-22-2014, 12:16 PM   #7
Darrengj's Avatar
1968 22' Safari
Once I searched for "metal hold down plate" I came across more info on this. Looks like custom making it is my best option. I will take your advice and check with a few metal suppliers.
Thanks again.
Darren
1968 Safari 22'
'67 Front window screen frame replacement SlvrSt8Steve Windows & Screens 10 11-30-2014 10:32 PM
HELP need pic. What seals the waste plumbing through the rear crossmember? Mixter Repairing/Replacing Floor &/or Frame 5 02-01-2013 08:09 PM
Frame crossmember wet-1972 Ambassador Mrwaterway Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 07-25-2011 08:07 PM
one bent crossmember on our 1971 Ambassador Pschoerrn Repairing/Replacing Floor &/or Frame 2 10-06-2005 10:27 AM
