| electrical
I looked around briefly behind the goucho, but I didn't see anything; next time we go back I'll look much closer.
When we were working on the electrical system today
we discovered that the Uni-volt system was kaputz.
The previous owner had moved the system under the sink which
has a leak.
So Obie One came up with the idea of installing a 3000 watt
dc to ac inverter that has a built in battery charger. We were thinking of hotting up all the plugs, all the time that way. If we move the system back to over the axel and install two sealed batteries that are run parallel I think we will be okay.The other thing is that our tow vehicle came originally with two batteries also (camper special). As long as we are careful with our electrical use. Have you ever heard of any one doing this in an A/S???
3po
