05-25-2014, 07:09 PM
#81
1968 22' Safari
Buda
Waste Lines
Install ABS waste lines to new gray water tank
DFlores
David & Diana
05-25-2014, 07:10 PM
#82
1968 22' Safari
Buda
Fresh water plumbing
Install new Pex plumbing lines
DFlores
David & Diana
05-25-2014, 07:27 PM
#83
1968 22' Safari
Buda
Gelcoat tub and lavatory
Gel coat Bath lavatory and tub, first time I've done this, not as hard as it seems, first I got an estimate of $1100 for just the labor, then I spent $39 for cheap gun and $85 for supplies
Test fit, tub and Diane's plastic pieces
DFlores
David & Diana
05-25-2014, 08:10 PM
#84
1968 22' Safari
Buda
Polishing Tub
We will have to wait about a week to be able to polish the tub, rain has slowed us down, allowing time for this update. I want to let gelcoat cure fully before finish sanding and polish
DFlores
David & Diana
05-26-2014, 08:24 AM
#85
1978 31' Sovereign
Texas Airstream Harbor
, Zavalla, in the Deep East Texas Piney Woods on Lake Sam Rayburn
Great Job - Awsome Documentation!!!
David and Dianne:
What a great thread.
Make sure to reserve a spot for Blanco.
You should call for a "Completion Rally" in the fall to celebrate all of your work.
Thanks to Top and "Bob the Airplane Guy" for help rendered.
Are you ready to lease Dianne out hourly of by the day for Vintage work?
Can't wait to see it in person.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
05-26-2014, 08:50 AM
#86
1968 22' Safari
Buda
Target set
Originally Posted by 87MH
David and Dianne:
Dennis, the Blanco Rally has been our target, we have a reservation already
DFlores
David & Diana
09-01-2014, 12:39 PM
#87
1968 22' Safari
Buda
Update for Labor Day
Plumb new shower fixture and complete installation of tub, had to be a little creative finding and installing plumbing. Fixture was sourced from a vintage claw foot tub supplier and washing machine connections used to connect to braided hoses
DFlores
David & Diana
09-01-2014, 12:41 PM
#88
1968 22' Safari
Buda
Shower wall
Install FRP clad wall next to shower, glued FRP panel to eighth inch plywood to make a quarter inch panel that would fit in aluminum channel.
DFlores
David & Diana
09-01-2014, 12:43 PM
#89
1968 22' Safari
Buda
Shower Curtain Rod
Design and install shower curtain rod, made from flat aluminum stock and aluminum angle cut into small pieces
DFlores
David & Diana
09-01-2014, 12:45 PM
#90
1968 22' Safari
Buda
Lavatory
Install lavatory and duplicate medicine cabinet doors without the plastic hinges
DFlores
David & Diana
09-01-2014, 12:47 PM
#91
1968 22' Safari
Buda
More Lavatory detail
Showing a few more details on lavatory, we later changed out hinges shown, Diane was not going for this style.
DFlores
David & Diana
09-01-2014, 12:49 PM
#92
1968 22' Safari
Buda
Toilet Install
Install new china toilet along with new wood door for hamper, we purchased a “tall” toilet for comfort and found a need to modify area where it fits, looked OK.
DFlores
David & Diana
09-01-2014, 12:52 PM
#93
1968 22' Safari
Buda
Linen Closet
Build new linen closet, with access to new 6 gal hot water heater, wood cutter ( can’t call me a carpenter) and finish specialist shown. Our first cabinet turns out pretty good.
DFlores
David & Diana
09-01-2014, 12:54 PM
#94
1968 22' Safari
Buda
More Linen Closet Detail
Linen closet detail, had to show the little access door for hot water heater, shelving is removable in case we need more hanging clothes space
DFlores
David & Diana
09-01-2014, 12:56 PM
#95
1968 22' Safari
Buda
Electrical Panel
New 120V / 12V distribution panel, this was not fun, combing out all the wiring serving everything in the trailer, but it is done.
DFlores
David & Diana
09-01-2014, 12:58 PM
#96
1968 22' Safari
Buda
Bulkhead Wall
Complete Bulkhead wall installation note new air vent designed and built by Diana
DFlores
David & Diana
09-01-2014, 12:59 PM
#97
1968 22' Safari
Buda
Door Treatment
Redo door, we laminated a sheet of quarter inch plywood to door, since the original finish could not be redone. New plywood finishes much better.
DFlores
David & Diana
09-01-2014, 01:02 PM
#98
1968 22' Safari
Buda
Street Side Closet
Built new street side closet with shelf and reused existing mirror
DFlores
David & Diana
09-01-2014, 01:04 PM
#99
1968 22' Safari
Buda
Door Edge Treatment
New closet door build and edge detail, used three quarter inch plywood and routed edges to come up with the original step shape on edges and Diana found a painted edge color that matched well with stain. The painted edge is what was originally done on our Airstream and I did not want to attempt to install edge binding on the step detail edge.
DFlores
David & Diana
09-01-2014, 01:06 PM
#100
1968 22' Safari
Buda
Cabinet Fronts
Reused cabinet fronts with some modifications, installed three quarter inch stiffener to hold up 50 lb microwave.
DFlores
David & Diana
