Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 12-25-2008, 10:00 PM   #1
Profile:  1966 22' Safari
Boca Raton , Florida
? Breaker for 7 way wire harness under 66 safari
Finally got the 7 way connector working with my new TV.
Looked at access panel under front of my 1966 Safari.
There is a completely rusted away breaker has blue wire on one side and a red and blue on other end.
I believe it is a charging breaker but do not know amp # to replace it with.
Next question below;
I now have working electric brakes...to my surprise. BUT...
The two blue wires at the rear access door are disconnected, I believe they are the breakaway break connections...If anyone has a pic of what the back panel should look like or where the two blue wires go I would appreciate it.
All the best,
Christopher
1966-safari is offline   Reply With Quote
Old 12-26-2008, 06:35 AM   #2
centennialman's Avatar
Centennial , Colorado
Here you go Christopher....
Steve "Centennial Man"
1966 Airstream Safari - Her name is "Aunt Bee"
centennialman is offline   Reply With Quote
Old 12-29-2008, 08:05 AM   #3
Thanks ... Where are the blue brake wires?
If the two wires in left corner are blue You have solved my dilema.
Thank you!
I believe they are the breakaway power connections?
67 Safari lighting harness end? aircooled4 1966 - 1968 Safari 7 12-07-2008 08:25 PM
Pre wire in 2006 23" Safari Zugbug Audio, Video & TV 1 08-29-2007 11:51 AM
What size breaker for 8 gauge wire? guy99 Electrical - Systems, Generators, Batteries & Solar 7 11-20-2005 01:24 PM
Big 'Ol Cut Wire At Breaker Box squrlgurl Electrical - Systems, Generators, Batteries & Solar 16 11-12-2005 04:06 PM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 09:25 PM
