1968 22' Safari Twin. Gotten to the point where I need to fix/replace the back tank before I do anything else. Any ideas on where to find a replacement that will fit the original space or how to do a major fix up of the old. Tank seems solid but connections are cracked and not going to hold and I think some newer "connections" might be the way to go. There is plumbing and then there are Airstream systems. I'm starting at ground zero. From what I've read so far it sounds like this may take some time and creative juice.
What have you all come up with? I'm trying to keep things fairly close to the same position as the original but it is a remodel not a restoration.
Skywriter
