Old 05-24-2012, 05:27 PM   #1
1968 22' Safari
Waco , Texas
Thumbs up '68 Safari 22' twin insulation question
I'm tearing up the floor and found what looks like foam isulation under it. And it looks like it was the kind from a spray can. It is nice and flat where it meets the surface of the plywood floor and looks wavey like water on the bottom on the belly pan side. I'm wondering if this was original to the trailer or if this is the work of a previous owner. Anyone have the answer? Sure is on there good and going to take some time to get off so I can restore. And even little critters managed to dig into that stuff and make some nice little homes. Hickory nuts make a distictive noise when the shop vac eats them.
Skywriter
Skywriter is offline   Reply With Quote
Old 05-24-2012, 07:09 PM   #2
kokopat's Avatar
Hendersonville, NC , North Carolina
It's original, or at least our Overlander had it too.
kokopat is offline   Reply With Quote
Old 05-24-2012, 07:42 PM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
My 67, 68 and 69 all have factory installed foam in the floor.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 05-24-2012, 07:42 PM   #4
68Safari22
1968 22' Safari
edmond , Oklahoma
My 68 Safari 22 has the same foam insulation.
Harleyyat is offline   Reply With Quote
Old 05-24-2012, 09:30 PM   #5
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Apocalypse Now
Been There...
Name:	robert duval.jpg
ALUMINUMINUM is offline   Reply With Quote
Old 05-25-2012, 07:24 AM   #6
1968 22' Safari
Waco , Texas
Okay, that is the answer! I can't blame the previous owner! In my diggings, I did find out why the tail lights didn't work: wiring harness was corroded in half by critters remains and deposits. Next step after getting all the insulation off will be wire brushing the frame and Por 15. Thanks for answering my question. Mystery solved!
Jack
New to Us - 1966 Safari - Overseas Caravan O-4 & WBCC Number Question corinnedavid Airstream History 2 01-03-2012 11:31 PM
1969 Airstream Safari Twin eBay Watch Airstreams on eBay 0 10-17-2011 07:40 PM
2007 Airstream Safari SE FB Twin Beds eBay Watch Airstreams on eBay 0 10-03-2011 01:50 PM
'64 Safari Converter Question Fan/Pump Switch Castiniron Batteries, Univolts, Converters & Inverters 6 09-15-2011 07:24 AM
'64 safari steps repair question Homewrecker Steps 4 03-14-2011 03:01 AM
