Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 10-12-2004, 11:14 PM   #1
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
'67 Safari Newbie
Greetings saahieb!
Originally Posted by saahieb
Just got some additional pics of axle condition see attached. From previous thread info. everything looks to be ok to me... any thoughts? I have also attached a couple of pics of the weight dist./anti-sway equipment. Looks complete. One thing that I have realized is that I will need to get a lowering extension? as the ball height show on the trunion? will add about 4" to the 21" I currently have from ground to bottom lip of receiver. Again, any thoughts?
The hitch pictured with the coach is a Reese Strait-Line with Dual Cam Sway Control. It may be very close to the same vintage as the coach. The hitch head appears to be of the "welded" type meaning that the drawbar and hitch head are essentially two pieces that have been welded together to make one - - this was quite common as recently as 20 years ago - - today it is quite rare, and you may have difficulty finding a welder who is willing to separate and rejoin the pieces (it is a little more complex than just separating and reattaching as the hitch head angle must be taken into account as well which requires a welder with hitch fabrication experience). The Trunion style hitch head/drawbar assemblies that are bolt-together are readily available through Reese at: Reese Weight Distribution Ball Mounts. It appears that other than that one small problem the hitch is complete.
Both of my coaches have the same hitch shown on your coach - - only I have upgraded to the adjustable hitch heads to make changing tow vehicles a bit easier. I think that you will find the hitch to be quite functional - - if my suspicion is correct and the weight distribution bars are 750 pound rated, you may find them a bit heavy for use with your F350 - - to get the best operation from the Dual Cam with a heavy tow vehicle a lower rated bar (either 350 or 500 pounds) is usually necessary (I utilize 350 pound bars with my Minuet 6.0 Metre -- 3,100 pounds gross weight/575 pounds gross tongue weight).
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 10-13-2004, 10:06 PM   #2
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Kevin has also posted excellent links for converting the round plug 7 pin to the flat prong round plug. Basically, if the trailer power cord has "round" pins, you will need to convert them to a round plug, "flat" prong plug to fit your truck. So far, the trailer looks good! I'd also check the age of those tires... you may need new rims if those are the orginal split rims. I don't think you will need to worry too much about functioning brakes with the F350.
Marc
Old 03-07-2005, 02:37 PM   #3
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
Send a message via Yahoo to till
The 1967 trailers are a little different. The biggest difference is the floor plans.
What are you needing to know? I have both the Sect. Services copy and now a original.
Tedd Ill
AIR#3788
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 03-07-2005, 07:03 PM   #4
Profile:  1967 17' Caravel
Reno , Nevada
Till- Nothing in particular. Those things are usually just crammed full of interesting tidbits and are always nice to have. Where did you find your original?
1967 Caravel
2007 Toyota Tundra
Yea! Great to be Back!!!
saahieb is offline   Reply With Quote
Old 03-07-2005, 08:57 PM   #5
hhuber's Avatar
Profile:
Images: 8
I have it!!
saahieb-
I have the original manuel that came with my trailer.
I would be happy to copy it for you and send it. I did this
for someone once before and it worked out fine. The only catch is
that it may be a week or so- I'm writing a paper. I have access to free copying so the price is right!
Heidi
'67 Caravel/'03 Tahoe
New Orleans, LA
hhuber is offline   Reply With Quote
Old 03-07-2005, 10:26 PM   #6
moogie32's Avatar
Profile:  1967 22' Safari
Branford , Connecticut
Images: 11
Heidi, I have been looking for a manual for my '67 Safari too! Is there any way you could make 2 copies? I'd gladly pay you for your time and any other expenses incurred along the way!
moogie32 is offline   Reply With Quote
Old 03-08-2005, 04:10 PM   #7
Reno , Nevada
Heidi- That would be great!!! Thanks a bunch. At your convenience, I'm not in any huge hurry. I'll gladly reimburse you for any costs incurred and time spent at the photocopier. Best way to reach me is at legumes@sbcglobal.net or (775) 338-8509 (Reno, NV). Thanks again!
-Steve
1967 Caravel
2007 Toyota Tundra
Old 03-08-2005, 09:25 PM   #8
moogie32's Avatar
Images: 11
Thanks too, Till! I'll keep you posted on what's up. By the way, Heidi, I love your coach under "The Blue Swallow" sign. Was just there in November - what a great place. No cool vintage trailer or car, but it was a memory that will stay with me for a long time. Nice to know an Airstream will fit under it. Maybe I can try that for myself someday. Did you sleep in a wigwam too? Diane
Old 03-08-2005, 12:33 PM   #9
till's Avatar
1968 26' Overlander
Lisle , Illinois
Images: 108
The original copy I have came with my 67 Overlander (aka parts). It also came with a copy of the 1967 sales book. I see that Hiedi has y'all covered.
Tedd Ill
AIR#3788
Old 04-12-2005, 02:27 PM   #10
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
Sahieb,
I was wondering, why did you put the trailer up for sale a week after you got it home?
azflycaster
azflycaster is online now   Reply With Quote
Old 04-12-2005, 10:32 PM   #11
Reno , Nevada
Long story, made short
Long and short is trailer was misrepreseted by Sellers. It was supposed to have sounds floors, that was simply not true. So, instead of some cosmetic updating, re-upholstering, new curtains, minor systems testing/troubleshooting and a good cleaning, I'm now looking at subfloor repair and/or replacement in the bathroom and possibly by the front door. Dissapointed...ABSOLUTELY!!! But I'm just not in the position right now to have a project trailer (no large workspace, no time with full-time job and two children under 5 y/o). We really wanted something that we could throw our stuff in and go (we have 7 pending camping trips around the Lake Tahoe/Lassen Nat'l. Park area for summer). So, I'm hoping to sell for $5K. This puts me out $4K, as I paid $9K. Lesson well learned. If anyone is interested let me know. It has a good base to work from as everything is original inside and mostly complete, pretty clean, no smokers film on vinyl and tows nicely on new tires and new braking system. Just more work than I really want to take on. I can be reached at (775) 853-3844 (home between 6-9pm) or (775) 338-8509 (cell, anytime) and I'll be happy to tell you all I can about the trailer.
Steve
1967 Caravel
2007 Toyota Tundra
Old 04-12-2005, 11:45 PM   #12
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
Bummer. I am truely sorry to hear about this - it's really tough to buy a trailer long distance. You must be smoldering mad! This kind of misrepesentaion really torques me!
So.. are you still going camping this summer?
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Old 04-12-2005, 11:50 PM   #13
Creampuff
Creampuff's Avatar
Profile:  1957 22' Flying Cloud
Malibu Lake , California
Images: 60
saahieb:
I'm so sorry to hear that your dream trailer has turned into a nightmare! It's really disheartening to get ripped off like that. A 9K unrestored Safari should definitely not need that kind of work! Hopefully you will not be too discouraged to keep looking for something mo' better, mo' local !
It might help to post the seller's name so no one else ever doe's business with the crook!
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 04-13-2005, 08:33 AM   #14
bimi's Avatar
Profile:
I think I understand your frustration. We, too, traveled about 10 hours one way on a long weekend to pick up what we thought was a very good trailer with minor problems. When we got there, the vents were broken out, which allowed rain to soften the flooring, the couch which in pictures looked fine with the throw over it had apparently been lunch for many rodents, the pull out bunks were split down the middle, and the systems had not been checked as they had said they were. We ended up just driving home, another 10 hours, very dissappointed and frustrated. The very next week, however, we found a trailer about 30 miles away that is in what I would consider perfect original interior condition. The only problem is the clear coat is separating, which is fine since we are wanting to polish it to a mirror finish anyway.
All that to say this. Don't be discouraged. There is a perfect trailer out there for you and your family.
bimi is offline   Reply With Quote
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 12:10 PM
Quality of new AS: 2004 22" SAFARI lee 2004 Safari 7 01-02-2005 08:13 AM
Al-13 on Safari blucloud On The Road... 0 07-27-2004 09:44 PM
Safari 28W + Chevy 5.3L/4.10 = Love? docbluedevil 2004 Safari 7 10-08-2003 10:51 AM
