Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 12-07-2008, 03:27 PM   #1
aircooled4's Avatar
Profile:  1971 31' Sovereign
1967 22' Safari
Pardeeville , Wisconsin
67 Safari lighting harness end?
My 67 has had the ext light wiring harness modified by a less than qualified individual. On my 71 theres a round connector on the tongue end of the body...what should my 67 have? Obviously theres no connector on the body, what should this unit have and where should the bundle run from/to? Currently, it has the 4 flat connector, the bundle is run through a hole in hte frame, by the lp cans. The wires are 'enclosed' in a length of GARDEN HOSE run under the trailer along side the copper lp pipe. Any one have any pics of HOW it should look...??
Jay (KB8VMO) & Sheri
Kids, cats, horses, & donkeys
WBCCI #10917
AIR #32349
aircooled4 is offline   Reply With Quote
Old 12-07-2008, 03:39 PM   #2
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
There should be an access panel in the belly pan. I can't see what you have but, It should be about a foot in on the same side the wires are. Put on a connector that is a good fit for your tow vehicle.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 12-07-2008, 03:45 PM   #3
Shacksman's Avatar
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
Well mine runs through the frame to an access panel in the underbelly, about a foot square, near the front. Inside is the conections for the lights.
The truck end has a 7 flat pin connector for the truck.
Too much snow right now to get a picture.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Shacksman is offline   Reply With Quote
Old 12-07-2008, 04:00 PM   #4
1960 18' "Footer"
This is what I have. The LP line runs by it. The tounge is at the top of the picture.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 12-07-2008, 05:04 PM   #5
aircooled4's Avatar
1967 22' Safari
Thanks guys...Im aware of that panel...Too much snow here to climb under it and take it off...another warmer day, another project!
WBCCI #10917
AIR #32349
Old 12-07-2008, 05:36 PM   #6
1960 18' "Footer"
Pic
Is this what your looking for?
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 12-07-2008, 06:01 PM   #7
aircooled4's Avatar
1967 22' Safari
Thats what mine SHOULD have ...mine is just hacked off! LOL
WBCCI #10917
AIR #32349
Old 12-07-2008, 08:25 PM   #8
goransons's Avatar
Profile:  1969 25' Tradewind
1963 22' Safari
State of , Washington
You should be able to run that inside the frame channel right by the jack (from underneith) and once inside that little access hole you'll see the frame has an opening for the wires to come out. Local RV shop should have that plug end with a nice pigtail on it long enough to get it back there. Just feed it back and rewire and you should be good to go.
Our 66 was wired delux when we brought it home, 2 orange extension cords ziptied to the propane lines with the ends hacked off, run externally up the back ofthe trailer and wired in behind the lenses, and up front twisted together and hooked to a 4 flat. I feel your pain! BTW don't have your head under that cover when you pull it off
Scott & Megan
Visit our Blog- http://safari8671.blogspot.com
63 PARTS NEEDED
roof locker tracks (plastic)
square cornered astrodome screen
63 refer, or at least the original door insert
2 12v hehr motors (working) w/ or w/o fan blade
goransons is online now   Reply With Quote
Installation of mood lighting in my Safari hshovic 2008 Safari SE 3 10-30-2008 06:10 PM
Track Lighting & Lighting Ideas ClassicRides Electrical - Systems, Generators, Batteries & Solar 8 08-29-2008 03:03 PM
Put me in a harness... bevman Batteries, Univolts, Converters & Inverters 10 04-02-2007 02:03 PM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 09:25 PM
