Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1966 - 1968 Safari
Old 08-20-2002, 09:05 AM   #1
Lexxy
Lexxy's Avatar
Profile:
Images: 13
Talking 1967
We are new to having an Airstream and we have the 22' 67 with the settee and not the dinette in the bow. ...or we did until we took it out and now we just have a space.
I hope some other '67 owners will post here and we can commerserate and support each other.
I have seen some pictures of a few others 67's and written to some folks so I know they are out there.
I just wanted to start some posts in this column an maybe some others will follow. Nobody ever called me shy!!!
Lexxy
Lexxy is offline   Reply With Quote
Old 08-20-2002, 11:17 AM   #2
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
you go girl
Old 09-03-2002, 06:05 PM   #3
urb2165
Profile:  Currently Looking...
Dillon , South Carolina
Smile Dry Weight
What is the dry weight of your 1967 unit?
urb2165 is offline   Reply With Quote
Old 09-07-2002, 11:27 AM   #4
Lexxy
Lexxy's Avatar
Profile:
Images: 13
weight
It's 3240 pounds base weight, if I'm not mistaken. We have the model without the dinette in front. Right now it's a lot less since we ripped out the beds, the bath plastic and fiberglass stuff several wood walls and all the overhead cabinets...just the floor. fridge, sink and stove left and they are next. We are checking to see if the fridge works today.
We got the brakes working well and now have to do some body work to the back bumper and have a metal box fabticated for the holding tank...it's barely strong enuf to hold air right now!!! A little waste water and it would be sitting on the driveway!!! This trailer is definitely in the fixit stage.
Lexxy
Old 10-12-2002, 08:00 PM   #5
Creampuff
Creampuff
Creampuff's Avatar
Profile:  1957 22' Flying Cloud
Malibu Lake , California
Images: 60
Lexxy:
I've got the identical coach in fairly original condition (with some upgrades).If you need to compare notes on anything,let me know.Sounds like you are going DEEP on this baby!I hope you don't mean you are adding anything to the bumper - as that's a definite no-no!
Murray
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 10-13-2002, 01:39 PM   #6
Lexxy
Lexxy's Avatar
Profile:
Images: 13
welcome
So glad you posted...we are just getting back into the project since the weather got a bit cooler. We are grinding rust from the underside frame in back after dropping the holding tank box. There was a leak in the gate valve for what must have been 20 years and it rusted the whole thing out. We will have a new metal box made. The rust on the trailer frame isn't bad at all...comes right off and no metal is rusted thru so we are going to prime and paint and have the bumper removed pounded straight and welded back on and we will make a new bottom to the hose box there.
So you have the settee arrangement? We are building in a new settee and dinette where the old bunk was. We will only have it equipped for 2 to sleep then.
Yesterday I bought the paint and primer to do the head plastic and fiberglass that I yanked out and cleaned up and stored in my guest room. Yes, we have a project started but we do have vision. I had a nifty drawing until my computer blew up and now I have to draw it again.
We aren't adding any weight and are, infact, deducting weight by eliminating the furnace and big waterheater.
Have you done much to yours?
Lexxy
Old 10-13-2002, 06:00 PM   #7
tod47d
Profile:  1967 22' Safari
clarkston , Georgia
Thumbs up 67
Got our belly pan down and scraped lots of rust from our frame- lucky as well that only one place is rusted thru and it isn't that bad at all (a 1" hole that I hope to get welded over) Painted the whole thing with rustoleum rusty metal primer, let dry then did a coat of black enamal over all and it looks great!!! Ia'm glad I got to it before rust got bad.
Got a trick 4 U
I took the 59cent plastic wire brush- only found at big lots- and taped it to a flexible piece of plastic and used it like a bottle brush to ream out the steel frame in the tongue. This operation yielded some rust and debris but i plan to tape a brush to the stick and prime then paint the insides of these rails to help preserve them from the inside as well as the outside. Good to know we will be riding on a solid foundation for a good long while.
I took a spard tire holder off our rear bumper and anticipate grinding off some welded steel plates on the bumper-it's so Hollywood to watch those sparks fly--I reckon I'll wait till I have an audience to do that one!!! We enjoy our 67 Safari22' big bunches, have named her Aurv the Silver Surfer.
tod47d is offline   Reply With Quote
Old 10-13-2002, 11:24 PM   #8
Creampuff
Creampuff
Creampuff's Avatar
Images: 60
Ours is named "Creampuff"!
We've had her about 8 months and try not to take anything apart that will take more than a week to restore-just in case I get the urge to go 'open roading'!So far I've redone the floor with a light oak "Pergo".redone some 12V wiring to get taillights and running lights,worked on the Univolt,restored the orig.water heater,frig.and stove and now working on the furnace.Hey,if you're junking that Suburban furnace-I could use the fan motor!
Also have one gaucho redone and working on the second.Lexxy-mine is not the dinnete model but has the full gaucho in front with the fold down table curbside.I have also been replacing the window and door weathersripping and window clips.Had to put in a new front window as someone poked something through the rockshield and window,but they were due anyways.I went with the local shops advice and used Lexan for shatter resistance,but it scratches easily and doesn't seal real well on the new rubber due to it's flex.
I've got a Cyclo polisher but haven't got more than a couple of segments stripped yet ready for polish.I notice a lot of oxidation on the stripped ones and am wishing I hadn't started!!?Oh well ,restoration is not an overnight thing!
Murray
AIR #189
Old 10-14-2002, 12:01 PM   #9
Lexxy
Lexxy's Avatar
Profile:
Images: 13
whew!! Gasp!!
We got the rust out of the whole back frame section...both of us on our backs with drills with wire brushes in them then scrubbed it with steel wool and mineral spirits and primed it well.
I really need to know how the metal holding tank box is supposed to be held in place in the very rear. I know that in the front of the box there is an angle iron and we are replacing that because it is just too rusted. We are also having the bolt holder pieces rewelded on cuz they are about to break off but the trailer frame was in perfect shape throughout under only light rust...we are so impressed. Not a bad job at all now it's almost over.
Would one of you look just under where the very back of the metal holding tank pan is and see if there in another angle iron that also goes along there too, right near where there are 2 angled strips that hold the bumper box that holds the drain hose.
I have the holding tank and box in the suv waiting to go to a metal shop tomorrow to have a duplicate made.
Creampuff [cute name], This furnace motor might just help you out but I have no idea if it works....it came in a bunch of parts when we got this trailer for $300 in July. You don't ask many questions at that price! I wouldn't be surprised if it did tho. It's so warm here that we just figured we'd get an A/C with a heat strip instead. Let me go dig thru the barn to find it and write me at lexxy@comcast.net for more info.
Lexxy
Old 10-15-2002, 07:55 AM   #10
tod47d
clarkston , Georgia
Thumbs up 67 belly
Lex- Angle iron --just like the other side --bolted on to tabs to the frame there is just enough left of ours to tell- I'm going to try to remove ours now without breaking the tabs--but am not optimistic about our prospects. I may have to cherry up the nuts with propane torch-careful not to burn it all up!!! I am going to rivet the frame up ecxept may want to use screws in the area near the door where I plan to have a small hole welded-patched over.
Old 10-15-2002, 04:36 PM   #11
Lexxy
Lexxy's Avatar
Profile:
Images: 13
box
I figured there was another angle iron...another person told me that too.
I found the best guy today who made my metal box in one afternoon!!! I'ts done! wow!! And as soon as I get a new gate valve he is going to help me with the welding on the frame below with the angle iron and bumper...what a find!!! We are saving enough to buy a new fridge! Yea!!!
Sometimes when I look at this big mess I think we must be nuts but I remember all the other times we have done these kinds of DIY adventures.
I just can't wait to do the decorating...that's the cherry on top!!! I have even found a resource here of quality foam and upholstery and made a good buddy out of the owner there. I am asking for a sailmakers sewing machine for Christmas so I can make the covers[and use on our sailboat]. If I can make my wedding dress 30 years ago I can make cushion covers!!!
Lexxy
Old 10-16-2002, 08:36 PM   #12
tod47d
clarkston , Georgia
67
Ours Safari is done with complete rustoleum primer then enamel undercoat! Oh So Happy to be done with that dirty job. I'm putting in all new brake light/turn signal wires while under ther-- found some crimps & nicks in the existing wires so for $6 why not? Our dump valve is cracked beyond the gate on the outside and will want to get a new one while ours is so easily accessible- what did you all find that fits the airstream black tank? will also "ask Andy"
Old 10-17-2002, 01:05 PM   #13
Lexxy
Lexxy's Avatar
Profile:
Images: 13
I sure hope Inland has a Thetford valve that is the right kind. I send an email order to him about 10 days ago ordering a list of several things but haven't heard anything back yet so he must be busy there. I guess he will let me know when he can get to my stuff.
I think the wires are ok...I did look them over closely while under there. All in all it was in good shape under there.
Shouldn't we have a drain hole or two in the metal holding tank pan for leaks? I mean it just holds the tank. It seems like it should have some kind of drain hole in it.
Lexxy
Old 10-17-2002, 08:38 PM   #14
tod47d
clarkston , Georgia
yes, I plan on adding a diagnostic hole or two so that we may be discreetly aware of problems in the system before they become catastrophic! Much as I have poked a pencil hole in a flooded drywall ceiling to direct flow away from tv and hi-fi as well relieve the accumalated weight of the water that could cause the entire cieling to collapse!!!
Wouldn't we hate to crack the frame of our RV by unknowingly toting hundreds of pounds in the rear!!!
1967 26 Foot Overlander orangeneolife 1967 Overlander 5 01-07-2008 02:17 PM
Vintage Airstream fans please help!! 72 or 1967 Safari? RichardT Community Polls 18 09-10-2005 08:32 PM
1967 Safari Back Compartment Access Door klingerswall Parts Archive 7 11-15-2003 07:54 PM
1967 tradewind parts for sale boardsander Parts Archive 31 11-14-2003 01:32 AM
1967 tradewind for sale boardsander For Sale & Wanted 1 06-22-2003 10:47 AM
