Old 09-28-2010, 11:44 AM   #1
Dag68's Avatar
1965 22' Safari
Shelter Island , New York
Images: 20
Updating the 1965 trailer plug
So, for some silly reason, my first project is to put a new plug onto the trailer umbilical, updating the connection to the current standard and get the lights and brakes working. I've already got the new plug and it'll be a quick project. I've read that you can jumper from the 12v blade to the running light blade with either a short wire or a fuse and power up the running lights while parked and disconnected.
Based on my research, I've made up a chart of how the wiring should wind up:
Name:	wiring conversion chart.jpg
I haven't done the work yet, so this is theoretical. If an anyone has already done this I'd be glad for see if I've got my plan right.
Dag68 is offline   Reply With Quote
Old 10-08-2010, 11:16 AM   #2
BWH-Utah's Avatar
1965 22' Safari
Salt Lake City , Utah
Seems like this should work, the 12v blade does go to the battery (there should be a 20 or 30 amp fuse in that line) so it should be hot even when disconnected. The running lights are looking for 12v to light up, so connecting the two should light up the running lights. It would run the battery down, but if you needed to leave the trailer beside the road while getting a tire fixed or solving some other problem this might be a good idea.
Beware that the old round hole plugs seem to have a different wire diagram than the newer flat blade plugs, and the wire colors are different than the ones that are internal to your 1965 Airstream.
Good luck,
BWH
BWH-Utah is offline   Reply With Quote
Old 10-08-2010, 01:19 PM   #3
Ottawa , ON
Here are the two most common connectors.
Name:	7-way truckplug66-81.jpg
1965, wiring
Greetings - Updating a 1978 Argosy 27' Trailer JLJustice Member Introductions 2 11-28-2009 07:36 PM
Trailer plug trea Electrical - Systems, Generators, Batteries & Solar 3 10-31-2006 07:46 AM
Extension cord to plug in trailer mandolindave Batteries, Univolts, Converters & Inverters 10 02-05-2005 05:36 PM
Rewiring Trailer Umbilical Plug DPeakMD Electrical - Systems, Generators, Batteries & Solar 4 02-29-2004 05:40 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
