Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1977 Sovereign
Old 02-09-2007, 04:45 AM   #15
thenewguy
Profile:  1977 31' Sovereign
Water Valley , Mississippi
Hey guys,
I have taken up residence in my trailer at a temporary job site. Been living in it and have been through some pretty harsh weather-deep south thunderstorms. Noticed a few minor leaks around a window gasket which I plan to replace. Also I suspect that I have a leak at a seam toward the rear of the trailer. I was told that a "seal test" had been done on the trailer and that it checked out good. It as been sealed in the past but a looong time ago. I suspect that I need to strip the old sealant at the seams and redo.
Also, about 1 week ago I noticed about a 2 foot diameter wet spot in the carpet between the shower and the toilet. The toilet is brand new and no moisture around the base of the toilet. I suspect that the shower or the drain plumbing from the shower is leaking. All of the incoming water lines were redone at the factory so I will assume they are functional at this point. Any recs on a way to eval and fix this without tearing out the bathroom would be appreciated.
By the way, this thing is awesome. I underestimated the liveability of these trailers. I love this old trailer and can't see myself trading it in for a new one. This baby has found a permanent home.
thanks for the help and recs
thenewguy is offline   Reply With Quote
Old 02-09-2007, 07:25 AM   #16
SwampBillies
SwampBillies's Avatar
Profile:  1972 31' Sovereign
Plant City , Florida
So glad you decided to keep her. Sometimes I get the feeling that the vintage trailers have learned how to whisper in your ear. They speak to your heart. Taunt you with visions of times past. They make you want to be a part of their history. So we adopt them, name them and bring them into our families. Our histories become entagled with theirs, and we are better for it.
Never argue with an idiot. They will drag you down to their level, then beat you with experience.
Debbie & Lewis Adkins
WBCCI #15754 --- AIR #18873
1972 - 31' Sovereign International (Betty)
1964 - 24' Tradewind (Glory)
2002 Ford F250 Super Duty
SwampBillies is offline   Reply With Quote
Old 02-09-2007, 11:17 AM   #17
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
water can travel as you know, so leaks are not always easily traced. You might check outside also, as leaks around the beltline trim getting under the floor are common. Hose that area outside and see if the leak grows, I would pull up the carpet to se what the flooring looks like under it.
You could run the shower and watch for the leak to progress also.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 02-09-2007, 11:44 AM   #18
Sky
Sky's Avatar
Profile:  2007 30' Classic
NoneOfYourBus , Ohio
Good question
Originally Posted by thenewguy
I plan to spend in the area of 30 to 40000 total on renovation.
Originally Posted by PizzaChop
$30K-$40K is a lot of $$
Originally Posted by balrgn
That'll buy you alot of toys
Originally Posted by fastrob
Funny, for that much you might pick up 5-10 Airstreams
you guys are right. I guess this one goes back to being a mobile hunting cabin.
Don't give up so easy. If you can get a total restore from the ground up, only reusing the skin, I say its a great deal compared to buying new. I think you are a wise man asking that kind of question. The key word here is "IF", because I am not sure what it would cost to replace everything except the skin. Anyone know?
Dale
Sky is offline   Reply With Quote
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Kichen remodel - 85 Sovereign 25' j54mark Cabinets, Counter Tops & Furnishings 6 10-14-2003 06:20 AM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 11:10 AM
85 Sovereign 25' j54mark Airstream Trailer Forums 7 10-30-2002 09:23 PM
Help with Ancient Sovereign patti 1956 Sovereign 2 06-06-2002 02:23 PM
