Old 04-24-2007, 08:10 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Years to Avoid?
I may be in the market to replace my 73 Sovereign that has frame damage. What years should I avoid to make running into the same problems of frame bending or tail drop less likely? I have heard Airstreams when the company was owned by Beatrice in particular should be avoided. What are those years?
Old 04-24-2007, 08:49 AM   #2
Out in left field......
Jim & Susan's Avatar
Solidarite , Georgia
Somebody will correct me if I missed the dates, but I think the "weak frame" issues were from about 1971 to 1977. I think The Vap guys identified 1978 as the "year Airstream cleared up all the frame issues". Not meant to be a direct quote, just going by poor memory.
www.nesa.org
Air No. 6427
Old 04-24-2007, 11:25 AM   #3
1977 31' Sovereign
1989 34' Excella
McHenry , Illinois
Biggest problems were with the rear bath 31 footers. You want the units that had the 5 inch frame and the mid bath, if you want maximum durablity.
Old 04-24-2007, 11:37 AM   #4
_
others asking the same question...
http://www.airforums.com/forums/f141...ears-8242.html
how 'bout mohos?
http://www.airforums.com/forums/f156...void-2273.html
and it always helps to read about units WITH issues from that era..
especially with inland andy supplying the history.
http://www.airforums.com/forums/f36/...ion-23099.html
how about 'finish issues' ?
this thread seems timely now...
http://www.airforums.com/forums/f4/e...year-5238.html
cheers
2air'
Old 04-24-2007, 07:21 PM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Marshall, since I had a rear bath '77 31' with a slight frame issue and axles with still some life in them, I went to an '86 Sovereign mid/side bath and rear corner bed. I saw an '80 mid twin rear bath 25' Excella II that had the larger frame and wish I could have purchased it but didn't have the money at the time. I've been happy with my '86.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 11-22-2009, 08:07 AM   #6
Ashland , Kentucky
I am looking at older Airstreams and was just wondering if this is true?
transy416 is offline   Reply With Quote
Old 11-22-2009, 08:19 AM   #7
Central , Mississippi
My '77 29' has a full 5" frame. It was made in late '76. Kinda hate to sell it
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-22-2009, 08:33 AM   #8
1977 31' Sovereign
1989 34' Excella
McHenry , Illinois
The units that have the 4 inch frame and the rear bath and gray water tanks were particularly subject to rear end droop, frame separation, fatigue failures in the frame over the axles and were recalled by Airstream to install frame strengthener plates and "elephant ear fix" to better attach the frame to the shell. I would avoid them, unless they did a really good job installing fixes to the problem. Likewise, the first years of the prefinished aluminum had clearcoat deterioration problems and you should figure on paying to have them repolished and recoated.
Old 11-23-2009, 04:38 PM   #9
Ashland , Kentucky
Thanks. I'm looking at center bath models, so I guess I should be fine...
Old 11-23-2009, 06:51 PM   #10
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
How would one know if they have a trailer with a 5" frame? We have a 29' "78" Ambassador.
Roadrunner is offline   Reply With Quote
Old 04-06-2011, 08:42 PM   #11
chief5725's Avatar
1973 31' Sovereign
Lexington , South Carolina
Hi, how and where do I look to see if I have a 5" frame?
Two Blades
chief5725 is offline   Reply With Quote
Old 04-07-2011, 08:10 PM   #12
The frame rails exit the shell at the rear and go all the way to the bumper. That's one place to measure the height.
Happy new years Boondocker Off Topic Forum 16 01-01-2006 09:47 AM
Anyone discover a fuel friendly float setting? IPM Mechanics Corner - Engines, Transmission & More... 18 05-11-2004 11:04 AM
Models to avoid? drober05 Airstream Motorhome Forums 6 11-01-2002 08:03 PM
MH manufacturering Model years zamboni Airstream Motorhome Forums 3 06-19-2002 07:00 AM
Copyright 2002-2015 Social Knowledge, LLC All Rights Reserved.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
