Old 07-31-2013, 09:56 PM   #1
1971 31' Sovereign
Southern Pines , North Carolina
Window rehab
I'm restoring a 1973 airstream sovereign. We gutted the whole thing over the winter, and are working on making it water proof, before redoing the floor. I've got a question about the windows/frames. How do I remove the window frames and windows? Which do I do first? What steps do I need to take to put the windows back together properly. I've never taken a window apart and I like to buy what I need next before I get pieces apart and then have to wait for parts to ship.
GHFdaja87 is offline   Reply With Quote
Old 08-01-2013, 08:33 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
In the 70's trailers, the window hangs from a hinge that will release if you lift it up high enough (ie., well past horizontal). If you want to remove the glass from the frame, it depends on the window. For example the front center window and back center window will come out of the frames by first drilling out the rivets that hold the hinge to the top of the frame, then there are two rivets at the top center, and two at the bottom center that if drilled out, will allow the frame to separate into a right and left half, and the glass to slide out from in between.
Finding the rubber gasket that fits perfectly around the glass and into the frame is a challenge. Not being able to find what I was looking for, I ended up sealing mine back up with a generous amount of vulkem and calling it good. The stack or vista-view windows are completely different, as they don't open--there are several threads on the forums regarding their rebuild. The front wing windows are also have a unique set of challenges.
I rebuilt my front and back windows because they were made of some kind of acrylic and were cracked. Also did the vista views to deal with the double panes and the peeling tint. Recently did one of the wing windows to rebuild as a single pane (the other is on my list as well). The other windows, I simply trimmed the edge of the dried out rubber gasket away and ran a bead of vulkem into the junction of glass and frame. Sealed them up just fine.
Good luck.
Belegedhel is online now   Reply With Quote
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
