Old 07-06-2010, 08:23 PM   #1
1973 31' Sovereign
Del Rio , Texas
Unhappy electrical help
we have a 1973 sovereign the lights went off the other day and i cant get them to come back on the ac works as well as the fridge and outlets i only see one fuse box with bus fuses but i dont see one that is blown is there another fuse box or is there a reset on the inverter i think it is a simple fix i just dont know were to look any help would be great thanks b2b
back2basics is offline   Reply With Quote
Old 07-07-2010, 04:30 AM   #2
Dan@LED4RV's Avatar
Kernersville , North Carolina
Electricity you have to chase. Start with the converter. Make sure it is getting power, then make sure it is putting out power. The AC and fridge are 110 volt and the lights are 12 volt. They are two different systems.
Dan Brown
High Point NC
Dan@LED4RV is offline   Reply With Quote
Old 07-07-2010, 05:57 AM   #3
richinny's Avatar
2011 34' Classic
do you have 12v at the battery?
do you have 12v at the fuse panel?
since all the lights went out, i'd guess that you would find the problem somewhere near the battery/fuse panel. sometimes the fuse holder ends get corroded or the fuse goes bad at the metal ends where you can't see it.
Ricky
Old 07-07-2010, 08:32 AM   #4
1973 31' Sovereign
Del Rio , Texas
we have a battery and a fuse panel is there a reset on the converter anywhere any ideas on what to clean the fuse terminal with thanks b2b
Old 07-07-2010, 08:45 AM   #5
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
There are circuit breakers for the 12 volt systems at the control center. they may have gone bad. I had that happen in my safari
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 07-07-2010, 11:20 AM   #6
richinny's Avatar
2011 34' Classic
it would depend on which converter is in there. there should be fuses on the positive and negative 12v side. i've used fine sandpaper or a fine file to scrape the terminals. disconnecting the battery and unplugging the converter first, is advised.
Ricky
Old 07-07-2010, 04:13 PM   #7
1973 31' Sovereign
Del Rio , Texas
Thanks for all the tips going to try to work on it tomorrow night where is the control center is that where the clock and water pump switch is thanks
Old 07-07-2010, 04:17 PM   #8
1969 25' Tradewind
1983 34' Limited
Images: 85
Yes its where the clock and switches are. On mine there were something like 3 circuit breakers attached to a copper strap then I think to separate wires going to differen lights
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
all new electrical... Help! photocodo Electrical - Systems, Generators, Batteries & Solar 9 09-20-2009 09:27 PM
Electrical miljac Lights - Interior & Exterior 0 03-23-2009 07:10 PM
Electrical jcandjc Electrical - Systems, Generators, Batteries & Solar 5 01-11-2009 01:34 PM
Electrical all over again Melody Ranch Electrical - Systems, Generators, Batteries & Solar 6 04-17-2006 10:34 PM
electrical help. poorboycjs Electrical - Systems, Generators, Batteries & Solar 1 09-16-2003 08:53 PM
Copyright 2002-2015 Social Knowledge, LLC All Rights Reserved.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
