Greetings kl8ton!
Originally Posted by kl8ton
Can I run without a battery if I put the Intellipower in?
I dont have one yet, but looking in to it.
Even with a modern converter (or inverter/charger as I have in my Overlander), it is never considered to be a good practice to operate for any significant amount of time without a coach battery (I suspect that the owners' manual for the IntelliPower likely makes a similar recommendation as found in the manuals for the new converter in my Minuet and the inverter/charger in my Overlander). In addition, the coach battery is required for the breakaway switch to function properly -- it is a required safety device in many states.
Good luck with your coach!
Kevin
