Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1973 Sovereign
Old 05-24-2004, 04:05 PM   #15
mtpalms
mtpalms's Avatar
Profile:  1971 23' Safari
Joshua Tree , California
Originally Posted by malconium
4 questions plus:
P.S. I don't see a spell checker in the reply area. Am I missing something? Also the image that I sent is pretty high resolution - are there guidlines or suggestions for what res should be used for attached pictures?
[img]file:///C:/My%20Documents/Airstream/Before_shots_052304%20011.jpg[/img]
Welcome Malconium.
Most of your questions have been covered, so I will post some links to get you started, beginning with pictures, 'cause we all like visual aids if possible before we give advice:
How to up load photos: http://www.airforums.com/forum...ead.php?t=7664
SpellChecker: http://www.airforums.com/forum...ht=spell+check I wouldn't worry too much about spelling, no one here gets uptight about "i before e...."
Jacks? Try: http://www.airforums.com/forum...ighlight=jacks (this topic is a bone of contention amongst members - mainly because your life and the life of your trailer depend on doing this properly)
For your bolts question: Hunt or post here: http://www.airforums.com/forum...isplay.php?f=4
Q4 "The fender well material on the curb side appears to be a bit torn where the body had pulled away from it. Is this going to be hard to replace/repair?" Lots of posts on this issue too, here's one:
mtpalms is offline   Reply With Quote
Old 05-24-2004, 05:09 PM   #16
malconium
Profile:  1973 31' Sovereign
Portland , Oregon
MtPalms,
Thanks for the information. I will following the paths you indicated. The first one I checked was about uploading photos. I made it through the process but the steps documented at the link you gave me is a bit out of date with some of the steps I think.
I am going to try attaching the photo again since it did not seem to make it. At least I don't see it when I look at the posting. I have reduced the resolution.
Malcolm
malconium is offline   Reply With Quote
Old 05-24-2004, 05:13 PM   #17
malconium
Portland , Oregon
Opps - still no photo...
I am going to try again about the photo...
Malcolm
Old 05-24-2004, 06:01 PM   #18
mtpalms
mtpalms's Avatar
Malcolm
Oh no....
...I mean..., boy, you're gonna fit right in!
Old 05-24-2004, 06:08 PM   #19
Sneakinup
Master Riveter
Sneakinup's Avatar
Profile:  1972 27' Overlander
. , Mobile-- as in transient
Images: 72
Now that interior appeals to me!
Consider yourself lucky to be able to start from scratch. I have always found it easier to start designing and building from a raw empty space, rather than having to retrofit, modify, and work with old stuff. Just my opinion.
Good luck!
1972 27' Overlander 72 Overlander
Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
Sneakinup is offline   Reply With Quote
Old 06-02-2004, 01:03 PM   #20
Ineedparts
Profile:
My 1973, 31ft. Land Yacht is a Soverign. I think that the length determines what it is named.
Ineedparts is offline   Reply With Quote
Old 06-05-2005, 07:25 AM   #21
ron.seymour
Profile:
1973 31 ft sovereign
Whats the going rate on a 73 thats in good shape, means ready to go down the road. because I bought mine for $950.00 and pull it home. so Is that a good deal?
ron.seymour is offline   Reply With Quote
Old 06-05-2005, 07:31 AM   #22
driftwood
Remember Burma Shave!
driftwood's Avatar
Profile:  1985 25' Sovereign
1965 22' Safari
Excursion V-10 , S.Florida
Images: 35
You did just fine.
driftwood is offline   Reply With Quote
Old 06-24-2005, 02:42 AM   #23
trucker101
trucker101's Avatar
Profile:  1972 31' Sovereign
Regina , Sask.
Rivet 1 more here.
Originally Posted by delbell
Where are all the '73 Sovereign people? I know I'm not the ONLY one. Let's go!
And a new member. We just bought a 73 that I will be towing with my 81 GMC Vandura2500. Long distance truck driver for a living.Live in central Alberta.And I look forward to reading the posts here when I have time...Regards...Bill
If you got it
A Truck Brought it!
trucker101 is offline   Reply With Quote
Old 07-02-2005, 10:09 PM   #24
ron.seymour
Profile:
hey here the question!!! on my 73 31 ft airstream the full size bed in the back, well I put a water bed back there, its the kink of bed that it has 6 tubes of water in it. I wondering if its going to be too much weight for it? or do I need to put a reguar bed back there instead. the othere question is It got reguar car tire on it 215 75r15 on what do I need to put on so I do have to worry about it going down the road. load range and size. thank ron at edmond,oklahoma.
Old 07-02-2005, 11:49 PM   #25
desi arnaz
desi arnaz's Avatar
Profile:
HOW MANY GALLONS IN THE WATERBED?: remember each ounce of water weighs one ounce............128 ounces =8 POUNDS..........
8 POUNDS TO THE GALLON............100 gallons is 800 pounds.......
that is a lot of weight......
desi arnaz is offline   Reply With Quote
Old 07-03-2005, 06:09 AM   #26
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
Originally Posted by ron.seymour
hey here the question!!! I wondering if its going to be too much weight for it? or do I need to put a reguar bed back there instead. the othere question is It got reguar car tire on it 215 75r15 on what do I need to put on so I do have to worry about it going down the road. load range and size. thank ron at edmond,oklahoma.
Ron, the waterbed is waaay too much weight. Many homes and apartments will not stand a waterbed, at least on the second floor. Not only do you have almost a thousand pounds of water, you also have several hundred pounds of particle board, and steel framing. Even if (and it's a big if) the frame of the trailer will stand the weight, you will almost certainly have a negative tongue weight, which makes a very unstable, even dangerous, tow. You MAY be able to get away with a waterbed frame, and air tube mattress, if you can find one in the proper size.
Your second question is easier to answer, you need tire size ST225/75R15, load range D. ST is a trailer tire, you need to use it instead of, say, an LT (light truck) tire, as it is constructed differently, with different rubber compounds for the unique conditions encountered for a towed trailer.
If you want a numerical tire, a 7.00x15 D tire will work, they are only available in an LT tire, though.
Change is inevitable, except from a vending machine
AIR#2611
Old 07-04-2005, 03:46 PM   #27
isis
Profile:
Thumbs up confused
My friend is going to buy a 1973 sovereign and is completely gutted.
The asking price is 3000.00 is this good or bad.
My friend isn't good with computers so I am asking for any help.
Thank you,
isis
isis is offline   Reply With Quote
Old 07-04-2005, 03:59 PM   #28
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Ron my recommendation is to dump the water bed and go with an air bed. We bought an Aerobed topper which is about 2 inches high when inflated. It has dual controls and works a lot like the Select Comfort mattress which I have at home. You just roll it out over the mattress. It makes a big difference in the comfort level.
You don't want the weight of that water in the rear.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
