Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1970 - 1973 Sovereign
Old 11-27-2013, 06:58 AM   #1
1973 31' Sovereign
DeFuniak Springs , Florida
Working on and inspecting the belly...
What is the best way for me to get the girl up so that I can check and work on the belly... Thanks
dbdefuniak is offline   Reply With Quote
Old 11-27-2013, 07:17 AM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Hydraulic floor jack & assorted jack stands positioned under the main frame rails.
Colin
Colin H is offline   Reply With Quote
Old 11-27-2013, 07:37 AM   #3
1973 31' Sovereign
Thanks.... Will have to wait... Its cold and rainy here... I know were weather wimps in FL
Old 11-27-2013, 07:50 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
When I was working on my underbelly, I made a small "lift" that was basically a stack of two 2x12 pieces of wood, with enough room for a wheel chock at each end. I jacked up the trailer and inserted these under each wheel. I found that the extra 3" gave me adequate room to roll around underneath the trailer on a mechanic's creeper.
Interesting side note--I drove from Houston to Defuniak Springs, FL to buy my trailer 2 years ago--been working on it ever since!
Good luck!
Old 11-27-2013, 09:12 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Depends... I built a set of ramps out of 2x12's that were about 6" high. I have also used a hydraulic jack and jack stands. Prefer the 2x12 method.
Aaron
WBCCI #XXXX AIR #2495
