Old 04-12-2014, 10:31 AM   #1
wseeloff's Avatar
1972 31' Sovereign
Woodhaven , Michigan
Angry Toilet Removal
How do I get the toilet on my 72 Sovereign?
wseeloff is offline   Reply With Quote
Old 04-12-2014, 10:52 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If memory serves there are four bolts (studs) at the units base.
If you remove the nuts and the water line it should lift right off.
Old 04-12-2014, 10:59 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
In spite of the wrong information in my profile, we are both 72 Sovereign owners..... . I can't be more definite about my above answer because I changed everything, but I am 99% sure of my above answer.
If the nuts are stuck and the studs are just spinning in the floor, it is a bit more tricky. I think one of my bolts did spin.
I don't know, I think I might have used a cut off wheel to cut the bolt?
Old 04-12-2014, 11:16 AM   #4
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Have you located the bolts? They are hidden pretty good. My toilet only had 2 nuts, 1 under the step flush mechanism and the other required a little access cap removal and needed a n extension to loosen the nut.
How about pictures of your toilet.
desertair27 is offline   Reply With Quote
Old 04-12-2014, 12:22 PM   #5
1976 31' Sovereign
Oswego , Illinois
Smile toilet
My 76 AS had only 2 bolts stated above but had to cut front apron off w/sawzall because back bolt spinning, had to replace toilet any way had some problems
AC removal before interior wall/shell removal? TexasAir67 Exterior Restoration Forum 1 07-25-2013 08:58 AM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 02:00 PM
Improved Toilet Removal Procedure Buttercup Sinks, Showers & Toilets 9 05-24-2005 11:24 AM
Toilet removal advice requested Lockwasher Sinks, Showers & Toilets 5 11-14-2004 09:43 AM
Toilet removal? earlflew Sinks, Showers & Toilets 8 10-17-2004 03:40 AM
