06-18-2015, 07:39 AM
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert
Single wire with no connection
This brown wire is in the closet behind the curbside bed. The bed light works, I haven't tested the thermostat yet. The parking light on the curbside is not working. I looked in the grommet for the other end of the wire but I didn't see it. Has anyone done work in this area that can tell me what it goes to? I'll check it for power today.
06-18-2015, 09:18 AM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Ground wire?
06-18-2015, 09:29 AM
Biloxi
, Mississippi
Mystery wires. My Bambi II had them running all thru the trailer, the Safari also has several that have me baffled.
MICHAEL
06-18-2015, 09:34 AM
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert
I was thinking ground wire too. The problem is, the bathroom door slides between the closet wall and the wall behind the twin bed. I can't see to trace the wire. It also seems like a strange place for AS to put an electrical connection.
06-18-2015, 09:54 AM
1974 Argosy 20
Kooskia
, Idaho
Ground wires in Airstreams have been White for many years, including the '70's. Thermostat wires are in pairs, and are generally blue in Airstreams.
If it has + 12 volts on it, tape it off and don't worry about it. In 44 years lots of PO's have messed with things.
06-18-2015, 10:29 AM
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert
I'm the 3rd owner and the 2nd owner parked it and never used it. I bought it because everything's original and it hasn't been molested.
I'd love to just tape it off but I need to figure out why my curbside tail light isn't getting power.
06-18-2015, 11:32 AM
1974 Argosy 26
Morrill
, Nebraska
If it is associated with the tail/marker lights I would not think it would be inside the inner skin. Besides that, the fact that there is a connector on it tells me it was used or was intended for use to power some device.
Schematics are available. Some one should be able to help with that.
06-18-2015, 11:44 AM
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert
I have the service manual for 1972 but I don't think it goes into that much detail.
I looked inside the battery compartment towards the curbside brake light and I didn't see any wires so I thought they must be behind the skin.
I guess I should go to Harbor Freight and pick up one of those line tracer things. hopefully it works through the interior aluminum skin.
06-19-2015, 05:34 AM
1975 31' Sovereign
North Fort Myers
I bought a wire tracer just for this type of problem, will work through the aluminum no problem. Just be sure all power is off or won't work. It traces the a different frequency that's applied to one wire and traced with the tracer.
06-23-2015, 05:41 PM
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert
Well it looks like that brown wire is half of the thermostat wires. I pulled it out a bit from the hole and it's attached to the other half. Now I need to find the other half.
