Old 08-09-2014, 08:55 AM   #1
1973 31' Sovereign
Kettle falls , Washington
Sewer cap size ????
73 land yacht sovern what size or do they even make a new replacement sewer cap. I bought one with garden hose fitting to run into my gray water tank and it is too small and wont fit .... help ! Lol
Dreedy650 is offline   Reply With Quote
Old 08-09-2014, 09:18 AM   #2
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Order one from your nearest Airstream dealer. The fittings are different than you will find at other RV retailers.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 08-09-2014, 09:55 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
If I understand your post this what you might need.
Amazon.com: Valterra T05-2285VP Thetford to Valterra Universal Adapter: Automotive
MICHAEL
Old 08-09-2014, 09:55 AM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
If your trailer has the original sewer connector, it's a Thetford connector that uses a Thetford-style (and size) cap. Most of what you find these days is Valterra, which is a slightly different size and has different tabs for the connection.
The Thetford parts are available, they're just not the most common now. This link just happens to be the first useful one that came up in a search, many other stores and websites stock what you need.
David
Old 08-09-2014, 10:11 AM   #5
1973 31' Sovereign
Thank you guys for your help... greatly appreciated
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 06:22 PM
2007 Safari Se/LS 20 sewer storage tube cap jamulian Waste Systems, Tanks & Totes 3 10-01-2009 09:21 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 02:42 PM
Sewer cap size? (newbie question) racoco 1974 - 1979 Sovereign 4 07-23-2006 08:56 AM
