Old 01-24-2011, 11:47 AM   #1
BW
1973 31' Sovereign
Baton Rouge , Louisiana
Send a message via Skype™ to BWMorgan225
Restoring 1973 Sovereign Baton Rouge
I just purchased a 1973 Sovereign and starting to cleanup and restore. I have several questions. Any and all advice will be welcomed!!
BWMorgan225 is offline   Reply With Quote
Old 01-24-2011, 02:10 PM   #2
x
XXXX , XXXX
Welcome BW. I have a 73 Excella which is the same size as a Sovereign and I'm in the middle of a shell off restoration and would be glad to help with any questions you have.
Is yours rear or center bath? The rear bath models suffer from a condition known as rear end seperation. The weight of the rear bath combined with a basic design flaw in the rear bumper area which allows water to penetrate the shell and rot the floor will given enough time actually let the shell seperate from the frame.
Are you planning a full restoration or just some cosmetic changes.
The first task you do is to seal the shell to stop any water leaking in. Things like widow seals and gaskets, roof vent seals and gaskets,ventpipe seals etc. Basically any opening in the shell should be checked for leaks.
Then thoroughly inspect the floor around the perimeter where the shell meets the floor for wood rot. Pay careful attentio to area below the windows and across the front and rear of the shell.The floor is the main structural component holding the shell to the frame.
Inspect the belly pan for signs of corrosion which should give you a good indication of the condition of the frame.
Check the water system with pressurized air for leaks before watering up. That way if it is leaking no water will be spilled into the trailer.
If all is good from there test the propane system for leaks and if it is good test the appliances for proper operation.
There is lots more to inspect and test but this will get you started,
Chris.
wasagachris is offline   Reply With Quote
Old 01-24-2011, 02:32 PM   #3
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Welcome BWMorgan225!
Get those questions posted as this community loves to help out.. oh and we love pictures too.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 01-24-2011, 05:41 PM   #4
BW
1973 31' Sovereign
Smile inspection/restoration
I plan on a cosmetic restoration. I have a center bath 73 sov. Someone gave me good advice when I joined forum to find center bath models because they pull better. I just got it home so I plan to start the inspection on the roof and window openings. and will strip the floor to see what the condition of the floor is around the edge of wall.
excellent advice on a check list. I will follow your advice to the letter.
Is there a particular product that you recommend sealling the roof vents. acrylic?
I am jealous about the excella. I missed getting an excella by one day. just about killed me. thank you and keep info coming this way...
Any special cleaners for cleaning the skin that you recommend. My wife and i are already talking "fix, restore, keep for a while ,,,,,then upgrade" love AS
Chris.
Old 01-24-2011, 05:42 PM   #5
BW
1973 31' Sovereign
thanks will do...all advice welcome!!!!!!!!!!!!!
Old 01-24-2011, 07:05 PM   #6
x
XXXX , XXXX
BW the sealers that you want are polyurethane not silicone. Vulkem, Parbond, Alcoa Gutter Seal, and Dicor Lap Sealant are some brand names to use. Vulkem can be bought at Fastenal, Parbond is available from a/s dealers or several resto sites on the web, Alcoa is available at big box hardware stores and Dicor can be found at most RV shops.
Here are a few links to parts and resto sites for you to look at.
Inland RV Center - The Nations Leading Expert in Airstream Innovations
Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
BestConverter - Converters, Inverters, Electrical Supplies, Electronics
http://led4rv.com/
Home
I don't know about a special cleaner for the shell just use a soft bristle brush to avoid scratching the aluminium when washing it.
Congrats on getting a center bath,they are harder to find than rear baths.
BTW your 73 does not have a grey tank to hold the water from the sinks and shower. They did not start installing them until 74 with the exception of the Excellas which started in 73. Your gray water will just drain out the waste outlet so if camping without a sewer hookup site you will either just empty on the ground(not usually allowed in most campgrounds) or you will have to buy a blue tote tank to capture your grey water and transport it to a dump station.
Once you get into things if you have any questions or problems just ask.
Chris.
Old 01-24-2011, 07:11 PM   #7
Central , Mississippi
Welcome to the forums neighbor! Everytime I start to say 'just look around in here...it's all be covered'...somebody posts something NEW!
This place is a wealth of info...and if you don't find what you are looking for by using the Search feature...just ask...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-24-2011, 07:35 PM   #8
oleschool's Avatar
1973 31' Sovereign
chapin , South Carolina
Welcome BW........glad to see another 73 coming back to life.
watching the stars through the vista view windows= priceless
TAC# SC-2
AIR# 41283
oleschool is offline   Reply With Quote
Old 01-28-2011, 03:57 PM   #9
BW
1973 31' Sovereign
HiHo
Will have to come see those "Silvers" sometime. I was born and raised in Jackson, went to Central High School finished 1962. Although I live in Baton Rouge, my wife and I own land/camp west of Brookhaven near Union Church. Wife is from Union Church. How do you like that 26'.
Old 01-28-2011, 04:05 PM   #10
BW
1973 31' Sovereign
Chris...quick update
Cleaning, cleaning!!
AC runs (owner had bought it in an estate sale and he didnt know if it worked or not)
I need to replace the AC cover. Too many dents.
Looks like I have a major window gasket project. All window gaskets need to be replaced. Any sources for gaskets you recommend or go to Airstream? Is there a different sealant I should use on the windows?
Old 01-28-2011, 05:41 PM   #11
x
XXXX , XXXX
BW. The cleaning seems like it will never end and it won't. It's like painting the Golden Gate Bridge as soon as you get to one end it's time to start over.
I'm glad the a/c works. These old armstrong units are great air cons. The shroud can be purchased from INLAND RV. The replacement one is fiberglass unlike the original plastic one. I painted mine to match the skin of the trailer. It took quite a bit of time to get the fiberglass perfectly smooth to paint. You may not want to spend so much time as nobody really sees it that closely. Be careful removing the bolts holding the fan guard on. After 38 yrs they will be rusted solid. If you break them it will take some sourcing to get new ones as parts are not available. The bolts,nuts and washers I used are stainless steel. I got them from Fastenal. The hard part was finding the rubber vibration isolaters for the fan motor. I ended up ordering bushings for a different brand Air con. They are a little smaller but work.
When you talk about window gaskets do you mean the ones around the window frame or the ones between the frame and the glass. The frame gaskets are also available from Inland RV. The glass gaskets are not available.
Where exactly do you want to use sealant on the windows. I suspect that Parbond or Alcoa Gutter seal will be what you need.
Old 01-30-2011, 05:24 PM   #12
Originally Posted by BWMorgan225 View Post
HiHo
The 26' is doing a GREAT job of
1) killing the grass in the parking area and
2) keeping the Garage full of stuff!
It's gonna be a hobby resoration and so far it has been taking back seat to camping in the 34'...
I've never been in the part of the state south of Natchez/west of I-55...I need to get down that way and play!
Old 01-30-2011, 06:28 PM   #13
Viper2's Avatar
Jay , Maine
Welcome to the club. I have a 74 sovering 31Ft that was built in 73. SO If I can help I will be glad to return the favor for all the wisdom Ive gotten on here
Viper2 is offline   Reply With Quote
Old 01-30-2011, 06:45 PM   #14
1972 31' Sovereign
Des Moines , Washington
Welcome fellow 73 sovereign! Ours is the twin bunk rear bath! Very versatile!
Curt
2wheelin is offline   Reply With Quote
1973 sovereign, mid bath, sovereign
1973 26' Argosy Restoration bbnaugher All Argosy Trailers 14 10-09-2011 07:35 PM
1973 avion le grande 31' like airstream eBay Watch Airstreams on eBay 0 01-22-2011 08:10 PM
Airstream 31' 1974 sovereign eBay Watch Airstreams on eBay 0 01-10-2011 03:20 PM
International Sovereign Airstream Ready to Use 31 foot eBay Watch Airstreams on eBay 0 01-06-2011 07:00 PM
