Old 08-09-2014, 07:16 PM   #741
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Got the awning installed today! First off, the instructions that same with the awning are very good, and following them makes the installation fairly easy. The two of us did the installation today without any issues. Well, just the normal stuff like wondering where I put that tool down that I need now...
Name:	0809 awning rail 01.jpg
ID:	218715Click image for larger version
Name:	0809 awning rail 02.jpg
Awning rail installed. As mentioned in a previous post, the top of the awning rail is 16" below the roof panel seam. Held in place with large Olympic type rivets into the ribs and then 5/32" rivets every 6" in between the ribs.
Name:	0809 awning 01.jpg
Awning installed. We thought sliding it into the awning rail was going to a major challenge, but it slid in fairly easily. I held it up on scaffolding in front of the trailer, and Kay guided it into the rail while on the scaffolding next to the trailer. Although it's kinda hard to see, we installed the travel latch in between the two front windows.
Name:	0809 awning 05.jpg
ID:	218718Click image for larger version
Name:	0809 awning 06.jpg
Awning unrolled. Looks pretty darn good!
Name:	0809 awning 03.jpg
After installing the awning, I relocated the side marker light about 3 inches below the awning. Almost puts it in line with the front and rear marker lights. Funny thing, when I drilled the hole to fish out the wires, I found 6 wires in the wall. Here's where my color coding paid off - I knew I needed a green and white wire, not a red, blue, or brown wire.
Name:	0809 cieling patch.jpg
Also today, Kay painted the ceiling patch from when I removed the middle vent.
Chris
Old 08-10-2014, 06:32 AM   #742
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
That street side awning looks great! And it will help keep the sun out and offer a bit of privacy while parked next to a huge motorhome. The travel latch is important as this street side awning is the one that billowed open on me in high eastern Colorado cross winds.
Little Girl now has a new white hat and a new sun umbrella! And pretty blue shoes and a new blue earring (scare light lens.) She is going to be the star of the campground.
David
Old 08-11-2014, 06:45 PM   #743
Swahealy's Avatar
1972 31' Sovereign
Valparaiso , Indiana
Wow. That looks great. I'm so looking forward to the day I can start putting Paulie back together. Labor of love these AS's.
Swahealy is offline   Reply With Quote
Old 08-22-2014, 09:45 AM   #744
Minno's Avatar
1972 31' Sovereign
White Roof Report
Been in New York for a week now on our first trip after putting the white roof coating on. Although it hasn't been beastly hot and we have not used the a/c, we have noticed that inside the trailer is noticeably cooler when she has been exposed to full sun all day. Unfortunately, I can't really give you a temperature difference as we never recorded inside temps before coating the roof. But, when we have stopped for lunch and at the end of travelling all day in full sun, we've become accustomed to having the inside temps being much warmer than they are now. We noticed this at home before the trip as well. So, the roof coating was well worth it in our limited experience so far.
The window awning is working very well too. But, hindsight being 20/20, we wish we had ordered a longer one. One that would have gone to the next rib aft behind the bedroom window. Extending the awning longer to the rear would help protect the bedroom window more in the rain. It currently ends at the rib right behind the window, so if the wind is blowing from the rear of the trailer, rain still comes in the side of the window even with the awning deployed. Oh well. It does a good job protecting the windows from rain in light winds or winds from other directions. Plus, it shades the windows nicely. So, still a very worthwhile addition.
Chris
Old 08-22-2014, 09:54 AM   #745
aquinob's Avatar
Portsmouth , Virginia
Looks great. I can tell you that the white will keep it cooler for sure.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 08-22-2014, 11:19 AM   #746
1981 31' Excella II
New Market , Alabama
You should come south and really give it a test.
Perry
Old 09-04-2014, 10:54 PM   #747
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
I just love Little Girl. I hope to see her some day now that she is all grown up.
GAStreamin is offline   Reply With Quote
Old 04-12-2015, 03:35 PM   #748
Minno's Avatar
1972 31' Sovereign
Spring is here! 76 and sunny today, although it's a tad windy.
A couple of weeks ago, it was warm enough that we opened up Little Girl and measured for the last cabinet, which will be an overhead cabinet on the side wall over the bed. Started building it last week. Took a break from that and another woodworking project and installed a new overhead light for the dinette table. Kay wanted more light when sewing and doing other projects on the table, so this lamp looked like it would fit the bill nicely.
Name:	0412 table light 01.jpg
ID:	236137 Click image for larger version
Name:	0412 table light 02.jpg
Name:	0412 table light 04.jpg
No, it's not centered over the vista view, but it is centered over the table.
Got lucky and I was able to fish wires from the center ceiling light to the new light fixture using a couple of wire coat hangers with hooks on the ends of them. Still took about 20 minutes before I was able to snag the two hangers together and then pull the wires through. I was very careful not to disturb the insulation too much.
Name:	0412 table light 03.jpg
Here's a picture with the light on. It's controlled by the ceiling light wall switch, but since it has it's own switch on the fixture, we can turn it off when we're not using it.
Photos of the new cabinet and some other projects will be posted in the next few weeks. Of course, I still have to finish building the cabinet...
For those of you counting, this is the start of year 7 on my estimated 5 to 6 year project.
Chris
Old 04-12-2015, 04:31 PM   #749
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Painting the roof
Minno do you have a pic of how far you took your roof paint on the end caps, I am in the processing of getting ready to paint my 1972 31" Sovereign. I figured to take the curb side to the awning rail and the street side about 1" below the rivet line on the street until I get my awning up. I have followed your Thread while rebuilding mine and it has been a lot easier. Thanks Jim
cole3444 is offline   Reply With Quote
Old 04-12-2015, 09:18 PM   #750
Minno's Avatar
1972 31' Sovereign
Hi Jim,
We stopped the white at the end cap seams. We only extended the white roof down to the main awning rail. Other than that, we stopped at the roof seam on the other side and the ends. I can try and get a better picture for you tomorrow. Right now it's dark and pouring rain.
Chris
Old 04-13-2015, 06:50 AM   #751
1981 31' Excella II
Do you have some specs and source on the LED light bar? How much extra light does it provide?
Great job as usual.
Perry
Old 04-13-2015, 06:53 AM   #752
1971 31' Sovereign
1972 31' Sovereign
Painting the roof
Thanks Minno that is what I was needing to know. I'm having to wait on the rain now and all of the pollen around here. If you get a pic that would help me and probably others if you have the time.
Old 04-13-2015, 08:37 AM   #753
Minno's Avatar
1972 31' Sovereign
Hi Perry,
We bought the light at LED 4 RV. Link: LED Directional Barrel Light with 30 Warm White LEDs SKU1344 [DrBar30Ww] - $34.95 : LEDs 4, Recreational Vehicles
It comes with either Warm White or Bright White LEDs. They have a smaller version as well, but that only comes in Bright White. Our dinette table is 24 inches wide, so we went with the Warm White 18" light. I'll try to remember to get a picture after it's dark this evening and post that so you can see how much light it throws out.
Jim, here's the roof picture you wanted:
Name:	0413 white roof end cap.jpg
I took it this morning from a second floor window. Not the best, but you can see the end cap seam and where we stopped the white coating. This is the rear end cap. The front end cap seam is the same. We used green frog tape to mask the trailer and give crisp lines. Blue painters tape would probably work just as well. It's hard to see, but if you look closely at the roof under the rear awning arm where the roller goes into the arm, you can just see the roof seam behind the awning and that we extended the roof coating on this side of the trailer down to the awning rail.
Chris
Old 04-14-2015, 07:59 AM   #754
1971 31' Sovereign
1972 31' Sovereign
Painting roof
Chris
Thanks Minno that pic is what I needed. Thanks Jim
Old 04-14-2015, 09:21 AM   #755
1981 31' Excella II
Thanks Chris
Did you run the wires for that prior to putting the inner skins back on?
Perry
Originally Posted by Minno View Post
Hi Perry,
Attachment 236192
Chris
Old 04-14-2015, 01:02 PM   #756
Minno's Avatar
1972 31' Sovereign
Originally Posted by perryg114 View Post
Thanks Chris
Perry
Hi Perry,
No, I didn't. I drilled a 1/2" hole for the new light, and removed the center ceiling light. I was able to fish wires from the new hole to the existing hole using a pair of wire coat hangers with hooks on the end. It was a long shot, but worth trying, and I got lucky. Otherwise, I would have had to drop enough of the center ceiling panel to run wires down to the new light.
Chris
Old 04-20-2015, 10:56 AM   #757
Minno's Avatar
1972 31' Sovereign
Hi Perry,
I finally remembered to get out to the trailer after dark and take a couple of pictures of the new table light in action.
Name:	0419 table light off.jpg
Overhead lights on, but table light off.
Name:	0419 table light on.jpg
Overhead lights and table light on.
The picture doesn't do justice to the difference in light. If you look at the light difference on the curtains and blinds, you get a better idea of how much more light the bar light throws off. Well worth the money and time to install it.
Chris
Old 04-27-2015, 02:16 PM   #758
Minno's Avatar
1972 31' Sovereign
Built and hung the last cabinet. And I see Kay has put towels in it already!
Name:	0426 bedroom cabinet 02.jpg
ID:	237186Click image for larger version
Name:	0426 bedroom cabinet 03.jpg
Name:	0426 bedroom cabinet 04.jpg
This is over the bed on the outside wall, over the foot of the bed more than the head of the bed. I hung this cabinet the same way I did the overhead cabinet in the kitchen, with a piano hinge on the inside of the face frame at the top and pocket screws hidden in the bottom frame. The hinge is screwed to the back of the face frame, and then riveted to the inner skin and ribs. All screws are held in place with red Loctite.
Now to build the cabinet doors in between all my other projects.
Chris
Old 04-27-2015, 05:43 PM   #759
1981 31' Excella II
Thanks Chris. I used Kay's Sunbrella covered valance idea and it works great. I have yet to experiment with LED lighting inside.
Perry
Hi Perry,
Attachment 236675
Attachment 236676
Chris
Old 04-27-2015, 07:01 PM   #760
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You folks have built a wonderful vintage Airstream. It looks great.
I must remember the piano hinge idea for attaching overhead cabinets. A great way to account for the odd angles of the curved side walls.
David
1972 sovereign
Biker Girl is Back she ran off Match.com Girl Jim Clark Off Topic Forum 8 09-13-2012 04:43 PM
New member, looking to get 22' refurb daninsatx Member Introductions 1 10-23-2006 10:09 PM
Interior refurb on Argosy RV abridges01 Classic Motorhomes 5 09-02-2006 03:24 PM
Armstrong A/C Shroud Refurb Ideas roadeo Furnaces, Heaters, Fireplaces & Air Conditioning 13 04-17-2005 12:31 AM
