Old 08-27-2013, 10:29 PM   #641
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We're going to install another aluminum trim strip on the side of the counter against the wall. In fact, we like the look so much, we'll do that same trim detail around the bathroom vanity as well. Some clear caulk under the trim is probably a good idea too. Should have though of that before installing the first piece of trim. Oh well - it can pop off easy enough. 7 rivets or so.
The counters are exterior grade 3/4'" plywood (BCX if memory serves).
Chris
Old 08-28-2013, 08:02 PM   #642
Minno's Avatar
1972 31' Sovereign
Name:	0828 shelf 02.jpg
Finished the stereo shelf this evening. Over the last couple of days, we installed the top shelf and sides and put 3 coats of poly on it all. Re-installed the stereo too.
Name:	0828 shelf 03.jpg
ID:	194389Click image for larger version
Name:	0828 shelf 04.jpg
Name:	0828 shelf 06.jpg
ID:	194391Click image for larger version
Name:	0828 shelf 07.jpg
I made the shelf retainer thingys out of 1/8" x 1/2" aluminum. Formed them pretty much free hand to match the curve of the shelf on each side. Made the 90 degree bends on each end by clamping the piece in my bench vise and bending it down by hand.
I'll build two small doors for each cubby next to the stereo. These will hold CD's & DVD's eventually.
Chris
Old 08-29-2013, 12:44 PM   #643
Minno's Avatar
1972 31' Sovereign
Went and got her weighed today. Mostly a dry weight, but we did not empty out the dishes or storage areas. Plus, both propane tanks are full.
Total weight: 6450 lbs
Axel weight: 5660 lbs
Tongue weight: 880 lbs (13.4% of total)
She weighs a bit more than I thought, but not by much. Maybe a few hundred pounds. But, now I know not to put that granite table top in for the dinette... Overall, we're fine for the additional cabinets we'll be adding.
For those of you in the Minneapolis area, we went to Mohawk Moving and Storage in Blaine to get her weighed. Very nice, friendly folks there. Even the semi driver that ended up waiting for us to finish smiled and waved. Cost $12.
Old 08-30-2013, 04:51 PM   #644
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
an "ooh" and an "ah" for your Shelf Retainer Thingys (actually for the whole shelf assembly) - nicely done
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 09-19-2013, 06:13 PM   #645
Minno's Avatar
1972 31' Sovereign
Been working on a couple of Airstream projects in between other household projects.
Name:	0919 bath counter 01.jpg
ID:	195974Click image for larger version
Name:	0919 bath counter 02.jpg
First one is the rear countertop in the bathroom. Kay did most of the scribing on this project, and she made the cardboard template we used to cut the plywood to shape. It's fastened to the shelf with screws, and also to inner skins with 1 by 2 inch blocks cut from basswood. The blocks are screwed to the skins and the underside of the counter.
Now we can work on skinning the lower part to hide all the plumbing.
The second project is a screen I made for the outside of the range hood scoop. I ordered stainless steel screening from McMaster-Carr, which comes in handy 12 x 12 inch sheets. Not knowing what gauge to order, I got a couple of them. I ended up using the 12 X 12 Mesh, .035" Wire Diameter screen, but if I had to do it over again, I'd get a slightly larger mesh. But this worked out ok.
Name:	0919 screen 01.jpg
ID:	195976Click image for larger version
Name:	0919 screen 02.jpg
Here's the screen cut and formed to fit. I made a template of the scoop opening out of plywood, and formed the screen over it for the most part. Fine tuning with wire snips, a dremel cut-off wheel, and my metal bending pliers finally got it to fit inside the scoop opening.
Name:	0919 screen 03.jpg
ID:	195978Click image for larger version
Name:	0919 screen 04.jpg
Installed in the scoop. I installed a pair of stainless steel screws, one on each side of the scoop, to hold the screen in place. The screws have Loctite on them to hold them in while bouncing down the road. Installing the screws was much harder than I expected. I figured that they would grab the screen and screw into it easily, but not so. I needed to drill a hole through the screen as well as the scoop.
It's a nice tight fit. No bugs or critter are going to get into the trailer through the scoop opening now!
Chris
Old 09-19-2013, 06:15 PM   #646
Streamline Owner
Nolavalkyrie's Avatar
Indianapolis , Indiana
Love the screen! Incredibly nice.
Julianne
Nolavalkyrie is offline   Reply With Quote
Old 09-20-2013, 11:00 AM   #647
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Did you put a screen over the fridge vent too?
Old 09-20-2013, 11:50 AM   #648
Ottawa , ON
As usual, really nice work, Chris!
Old 09-20-2013, 12:12 PM   #649
1981 31' Excella II
New Market , Alabama
Maybe I should be making some dies to stamp some of these vents out. It would take a big chunk of steel to make some dies.
Perry
Old 09-20-2013, 01:14 PM   #650
Minno's Avatar
1972 31' Sovereign
Kip: The fridge vent on the roof has 1/4 inch hardware cloth on it already. We put fiberglass screen on the inside of the fridge vent door too.
Perry: while you're at it, could you make dies for the banana wraps too? We'd buy banana wraps! The vents you can get now are fiberglass and not very pretty. that's why we modified and stuck with our old one. Apparently they are hard to come by so you could probably sell them.
Chris
Old 09-26-2013, 07:38 PM   #651
Minno's Avatar
1972 31' Sovereign
I've taken a break from working on Little Girl projects while I build an expansion to my workshop. But, Kay has been busy this week installing aluminum trim in the kitchen and bathroom.
Name:	0926 trim 01.jpg
Trim on the side of the countertop. She caulked the crack between the counter and the wall, and then installed the trim to cover the caulk.
Name:	0926 trim 02.jpg
ID:	196425Click image for larger version
Name:	0926 trim 03.jpg
Trim on the sides of the lower and upper cabinets where they meet the wall. Covers the pesky gap that was bothering me.
Name:	0926 trim 05.jpg
Trim around the vanity. Caulked the crack before installing the trim.
Name:	0926 trim 07.jpg
ID:	196428Click image for larger version
Name:	0926 trim 11.jpg
Finally, the trim around the rear shelf in the bathroom.
She also spent some time filling old rivet holes in the inner skins throughout the trailer. It's amazing how much that little project improves the overall look! The holes always caught your eye, but now that they're filled, everything just blends in.
Chris
Old 10-01-2013, 11:12 PM   #652
Trying to make memories.
vchatelain's Avatar
1976 27' Overlander
kiln , Mississippi
Oh my goodness! Ya'll are awesome. I am glad I found you! We purchased a 1976 Overlander 27' this summer and have taken it out twice already....many things to do. I will copy and paste many of your ideas. I hope there aren't any tanks to build in my future. We are mostly original. I have a jack and water heater to install soon and have fixed the leaks... I hope. We are going to use as is until funds and time are a plenty. I am going to forward this to my husband....I am the go-for.
Again, you are awesome!
vchatelain is offline   Reply With Quote
Old 11-17-2013, 12:55 PM   #653
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Yeah, every time I look at y'all's thread, I want to quit posting pictures of my work... Awesome job!
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 01-18-2014, 06:22 PM   #654
1974 27' Overlander
Sammamish , Washington
Bed frame with accommodation for a card table
Originally Posted by Minno View Post
Forgot the thank you, Hi Ho for the suggestion on the card table storage! Would have never thought of that on our own, and it is a great idea.
Kay
Hi from Chuck Neir,
I am now building our bed frame and wonder if you ever incorporated Hi Ho's suggestion for a card table. I, too, thought that was an outstanding idea.
Chuck
Chuck Neir is offline   Reply With Quote
Old 01-18-2014, 07:32 PM   #655
Minno's Avatar
1972 31' Sovereign
Hi Chuck
No we haven't gotten that far yet but haven't forgotten it either. We will be looking at again in the spring.
Kay
Old 02-28-2014, 05:26 PM   #656
Minno's Avatar
1972 31' Sovereign
It cold and there's about 3 feet of snow on the ground, but we got the bug again... Actually, we've had it again for well over a month, but a kitchen ceiling project came first. We started working on the dinette, which is going to be a single seat dinette next to the fridge. Just started working on it last weekend, so not very far along yet.
Name:	0228 dinette 01.jpg
ID:	206567Click image for larger version
Name:	0228 dinette 02.jpg
Partial frame for the seat set in place. The frame next to the outside skin isn't glued together yet. The two clamped together sections are glued and pocket screwed. I discovered this afternoon that the water fill is higher than the seat frame, so now I'm working on ideas to deal with that. The simplest might be to fabricate a cover out of sheet aluminum and notch the underside of the cushion. But, that would make the cushion non-reversible. Another idea is to build a box over it out of alder and make the cushion 4 inches narrower. Kay is away this weekend, and the temps are not going to be conducive to sitting out there contemplating ideas anyway, so it'll probably wait until later next week.
Name:	0228 dinette 03.jpg
I glued up the side panel as well as building part of the seat frame. It's oversized right now. I need to square it up and cut to fit, including making the front of the upper side piece nicely curved and pretty. I think it'll work well to hold the cushions in place and fit in with the rest of the interior.
Chris
Old 03-09-2014, 09:08 PM   #657
Minno's Avatar
1972 31' Sovereign
What a difference a week can make. 45 today!
I now have the dinette bench to the point where we can poly it before installing it.
Name:	0309 dinette 01.jpg
ID:	207145Click image for larger version
Name:	0309 dinette 02.jpg
Frame set in place. Re-did the side frame by the water fill to set the top and bottom boards on their sides to support the box I built to cover the water inlet.
Name:	0309 dinette 03.jpg
Water inlet cover set in place. The cushion will hide the pocket screws.
Name:	0309 dinette 04.jpg
Plywood seat set in place.
Name:	0309 dinette 05.jpg
Side panel in place. Pencil lines are the curve we decided to cut for the profile.
Name:	0309 stereo doors.jpg
I also built the two doors for the stereo shelf over the front window this weekend.
All these pieces are in my workshop again with the first coat of poly drying. I cut the curve on the side panel as well. Will post pictures again once it's installed.
Chris
Old 03-11-2014, 09:56 PM   #658
Minno's Avatar
1972 31' Sovereign
Finished and installed!
Name:	0311 dinette 01.jpg
ID:	207271Click image for larger version
Name:	0311 dinette 02.jpg
Name:	0311 dinette 03.jpg
Mostly installed anyway. My welting is in an outside storage pod, still covered with 2 feet of snow. Once I can get to it, I'll add welting between the water inlet cover and inner skin, and install all the screws to hold the cover to the bench.
Name:	0311 dinette 04.jpg
Aluminum bracket to support the top of the side piece.
The entire bench is attached to the fridge wall for support, floating on the floor.
Now to cut the cushions to the right size so Kay can make the covers for them.
Chris
Old 03-12-2014, 07:15 AM   #659
1981 31' Excella II
Nice bench Chris but where is it in the trailer?
Perry
Old 03-12-2014, 11:09 AM   #660
Minno's Avatar
1972 31' Sovereign
Hi Perry,
Directly in front of the fridge.
Chris
Name:	0312 dinette 01.jpg
1972 sovereign
Biker Girl is Back she ran off Match.com Girl Jim Clark Off Topic Forum 8 09-13-2012 04:43 PM
New member, looking to get 22' refurb daninsatx Member Introductions 1 10-23-2006 10:09 PM
Interior refurb on Argosy RV abridges01 Classic Motorhomes 5 09-02-2006 03:24 PM
Armstrong A/C Shroud Refurb Ideas roadeo Furnaces, Heaters, Fireplaces & Air Conditioning 13 04-17-2005 12:31 AM
