Old 08-17-2013, 05:22 PM   #621
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We had thought about putting a 12 volt outlet in the bathroom for a 12 VDC hair dryer, but decided not too.
Old 08-17-2013, 05:33 PM   #622
Minno's Avatar
1972 31' Sovereign
Did a few things today.
Name:	0817 screen door 01.jpg
ID:	193434Click image for larger version
Name:	0817 screen door 02.jpg
Replaced the screen door. We had bought one from someone that was parting out his trailer after a tree fell on it last Spring, and finally got around to cleaning it up and installing it. Looks much nicer than the one we had, which was not only really dirty and pitted, but also had a check taken out of it by a PO to clear the door knob they installed.
Name:	0817 door trim 01.jpg
ID:	193436Click image for larger version
Name:	0817 door trim 02.jpg
Painted and installed the inside door trim. Painted it the same hammered aluminum color we used on the kitchen window.
Name:	0817 old batt hatch.jpg
Fixed the hinge on the old battery box cover so it closes properly now. There was about a 3/8" gap at the top before.
Name:	0817 2nd hatch 01.jpg
ID:	193439Click image for larger version
Name:	0817 2nd hatch 02.jpg
Cut a hole in the side of the trailer and added a second hatch. Bought it on E-bay. It's the exact same size as the original side hatch.
Name:	0817 2nd hatch 04.jpg
Now, we have much better access to the outside storage compartment that's under the bed. I think I'll build a false floor to cover and protect the pex pipes.
Chris
Old 08-18-2013, 01:39 PM   #623
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Chris, do you have any pictures of the stove vent from the outside with the cover removed, I am adding one to my GT and it would be nice to see an original install. My original stove vent location is being re-tasked as a bath vent and the pass through had been previously removed, but the outside cover remained. I found another outside cover for the stove so that both vents will match.
Old 08-18-2013, 06:23 PM   #624
Minno's Avatar
1972 31' Sovereign
Hi Kip
No, I do not have a picture of the vent with the outside cover removed. The original vent, if memory serves, was just a vent pipe cut to the contour of the shell stuck up in the wall/ceiling. I don't even think it was vulkumed in place, because I do remember simply pulling it out of the wall during our demo.
When I installed the new vent pipe, after cutting the opening in the shell, I slid the vent pipe through the opening, and holding it level, I drew a line on the pipe where it exited the shell. I added about 3/4" to that line to make the cut. I cut fingers in the end of the pipe so I could rivet it to the shell. Lastly, I vulkumed the heck out of it before installing the cover. I took a couple of pictures of the opening inside the cover. Hopefully, they will give you a visual reference on how I installed the vent pipe. Not pretty, but it doesn't leak!
Name:	0818 outside vent 01.jpg
ID:	193532Click image for larger version
Name:	0818 outside vent 02.jpg
Chris
Old 08-19-2013, 10:21 AM   #625
Aerowood's Avatar
Arvada , Colorado
Old 08-19-2013, 02:22 PM   #626
1981 31' Excella II
New Market , Alabama
Kip you going to start making those scoop vents?
Perry
Old 08-19-2013, 03:48 PM   #627
Bauxter's Avatar
Columbus , Ohio
stove vent
My 73 has a 5 1/2" hole with a rubber collar that surrounds the 5 1/2" vent pipe as it passes through the hole, coming out of the factory vent hood. had some pics, but they were lost in a cloud somewhere between my phone and my gmail acct. looks pretty straight forward.
I wonder if there is a HVAC piece with a collar (aluminum of course) that would fit? Something like the fingers Chris talks about.
mike
Bauxter is offline   Reply With Quote
Old 08-19-2013, 04:53 PM   #628
Minno's Avatar
1972 31' Sovereign
The problem with the premade starter duct pipes with the fingers is that the shell of the trailer is curved, not flat. That's why I made my own. The premade one I bought just wasn't going to work.
Chris
Old 08-19-2013, 06:17 PM   #629
Bauxter's Avatar
Columbus , Ohio
Stove Vent pipe
That danged curve again! I think how AS compensated was with the rubber collar. Mine was kind of glued to the outside in pieces, but it may have curved to the profile of the trailer. I think your solution is more dependable and water resistant.
Old 08-20-2013, 07:45 AM   #630
Minno's Avatar
1972 31' Sovereign
I compounded the curved shell problem by wanting the vent pipe to exit horizontally. The original vent exited the shell at an upward angle, which put it much closer to 90 degrees in relation to the shell.
Chris
Old 08-20-2013, 01:30 PM   #631
Aerowood's Avatar
Arvada , Colorado
Perry
I was until I found a couple of spares from donor trailers
Old 08-20-2013, 04:17 PM   #632
1981 31' Excella II
I think I want to get rid of my leaky flap door and put in a scoop type vent.
Perry
Old 08-22-2013, 08:03 PM   #633
Minno's Avatar
1972 31' Sovereign
I realized that I never posted pictures of the modifications I made to the inside of the range hood.
Name:	0818 vent 06.jpg
Here's the inside without the fan. The original rectangular opening out the back has been sealed, and the 4" vent going up into the cabinet is installed and sealed with foil tape. It's a starter duct, and the fingers are screwed to the range hood.
I installed the original 8" fan, but when it was running, not only was it noisy, but we were also getting a lot of backwash (air blowing own back through the fan blades). I figured it was because only part of the fan was directly below the duct, and the air was bouncing off the top of the rang hood and blowing back down. I may have been wrong on that - more later.
To solve the problem, I bought a 4" 12 VDC computer fan from radio shack. However, the 4" fan blades are about 1/4" wider in diameter than the 4" duct. Go figure...
Name:	0818 vent 01.jpg
ID:	193871Click image for larger version
Name:	0818 vent 02.jpg
So, I made an adapter out of 1/2" plywood. I drilled a 4" hole, and then used a rasp to flare the hole out to the diameter of the fan blades. I then lined the opening with foil tape since this is inside a range hood and I didn't want the plywood getting all yucky down the road with grease sticking to it.
Name:	0818 vent 04.jpg
Picture of the fan I bought next to the adapter I made.
Name:	0818 vent 07.jpg
Fan installed in the range hood with the adapter.
Turned it on, and fully expected all my air flow problems to be solved. Not so. Still had a lot of backwash.
Opened up the vent box in the cabinet, and found the problem. The damper I installed was not opening. I hadn't noticed this before, but the vent pipe where the damper is installed is no longer round, so the damper binds. Took the damper out, and the fan works great! Good air flow, and it's really quiet.
I ordered a different damper, so I'll try that when it gets here and see how it works. Other wise, we're seriously thinking of going without a damper.
More to come.
Chris
Old 08-22-2013, 08:13 PM   #634
2007 22' International CCD
If you don't run with a damper, at least install a well-fitted removable insect screen somewhere in the system. Learned this the hard way when I installed a high-volume home stove hood in Alabama--the mosquitoes are quite capable of finding their way into the house through almost 10 feet of duct work and getting to you...
A removable fly screen that can be taken out and cleaned of grease is vital for any hood that does NOT include a fine mesh grease filter or a well-fitting damper--trust me on this one...
Old 08-22-2013, 08:23 PM   #635
1981 31' Excella II
Those computer fans are mighty handy. I am thinking of making my own fantastic fan by adding some computer fans to the existing roof vents.
Perry
Old 08-23-2013, 07:33 AM   #636
Minno's Avatar
1972 31' Sovereign
Screen's a good idea - thanks! In thinking about it more, I can see wasps or hornets taking up residence inside the vent tube. I need to come up something for the outside opening. Thought processes are working on it now...
Old 08-23-2013, 08:45 AM   #637
1981 31' Excella II
Just get you some stainless steel screen and make a custom screen for the outlet. You could put an aluminum frame around it and pop rivet to that and then put the frame inside the vent with a few sheet metal screws to hold it in there. That way you can remove it to clean it. Won't hurt to put some EDPM foam tape around the perimeter as well. You can get all the above at mcmaster.com.
Perry
Old 08-26-2013, 05:41 PM   #638
Minno's Avatar
1972 31' Sovereign
Got a couple of things accomplished in the 90+ degree heat yesterday. Yes, we had the a/c running while we were working in the trailer.
Kay shaved the rivets on the new hatch door we installed (see post 622). She did that in the morning before it got beastly hot.
Name:	0825 Counter Ttrim 01.jpg
ID:	194238Click image for larger version
Name:	0825 Counter Ttrim 02.jpg
We installed a trim piece of aluminum across the back of the kitchen countertop to hide the lower edge of the backsplash and hold it in place.
Name:	0722 tour 01.jpg
The stereo shelf over the front window sagged. Actually, it sagged as soon as we installed it. I think if you look at it in the picture above, you can see that it's slopping down away from the wall. The headliner just has too much give it to hold the shelf level. We had thought about different ways to try and prop the self up with brackets underneath it, but the window is really in the way. Then I saw a thread where folks were using strips of aluminum to hold their ceiling liners in place, and I got an idea...
Name:	0825 shelf 01.jpg
Here's what we came up with. Two 1/8" thick by 2" wide aluminum bars. They are riveted to the frame that runs across the top of the window and the first rib. We riveted them to the window frame first, then pushed them as hard as we could into the curve of the headliner, and then riveted them to the first rib.
Name:	0825 shelf 04.jpg
Close up of the rivets. Used 3/16" rivets for strength. And the strips are long enough the fan trim piece hides the edge. Got lucky on that - I bought an 8 foot long piece, cut it half, and it was long enough to reach the fan trim ring.
Name:	0825 shelf 06.jpg
Here's the top part of the shelf dry fitted in place.
Name:	0825 shelf 05.jpg
Close-up of the brackets that mount the shelf to the strips. It's pretty solid now, and the shelf is level. And, we're no longer worried about it falling off the wall...
We'll paint the aluminum strips the same color as the interior so they'll blend in better.
Chris
Old 08-27-2013, 07:26 PM   #639
Minno's Avatar
1972 31' Sovereign
Forgot to post where we got the backsplash from. It came from www.ceilingtilesbyus.com. It's a continuous PVC sheet and comes in multiple looks. Good customer service: they called us after we received the order to make sure we knew how to install it and answer any questions! It comes out of the box very curled up and we were concerned that it wouldn't flatten to the trailer very well but our fears were unfounded. It grabbed on the Powergrab very quickly and flattened right out to the wall. No having to hold it in place once we smoothed it out. We had seen it used on a backsplash last winter on the DIY show "I Hate My Kitchen" which is filmed in the Twin Cities. We're happy with the product!
Kay
Old 08-27-2013, 07:41 PM   #640
1981 31' Excella II
The Kitchen counter and back splash looks great Kay. Have you given any thought about what happens when the counter gets wet and where the water will go? I was thinking mainly to the right of the sink. It would be ashamed if that pretty wood divider got stained or water damaged. I am sure Chris used real plywood for the counter top and not that particle board stuff that explodes and falls apart when it gets wet.
Perry
1972 sovereign
Biker Girl is Back she ran off Match.com Girl Jim Clark Off Topic Forum 8 09-13-2012 04:43 PM
New member, looking to get 22' refurb daninsatx Member Introductions 1 10-23-2006 10:09 PM
Interior refurb on Argosy RV abridges01 Classic Motorhomes 5 09-02-2006 03:24 PM
Armstrong A/C Shroud Refurb Ideas roadeo Furnaces, Heaters, Fireplaces & Air Conditioning 13 04-17-2005 12:31 AM
