Old 06-13-2005, 08:57 AM   #1
Images: 14
Couple questions
Does my AS requre an 1 7/8 ball or 2" ball?
Does my motorized toungue jack work from my car battery if the coach battery is not installed? If not, will it work if I plug in to shore power without the battery installed? My other 12v devices work without the battery installed if I am plugged in to shore power.
Clayton
kl8ton is offline   Reply With Quote
Old 06-13-2005, 09:04 AM   #2
RichardT's Avatar
Your trailer takes a 2 5/16" ball, you should always check the fit after attaching to your truck by jacking back up against the weight of the truck once installed and locked, that way you are sure it is installed correctly and all parts are working.
Your jack should work if the coach is plugged in to shore power as long as the univolt is working and hooked up to it.
Best of luck.
RichardT is offline   Reply With Quote
Old 06-13-2005, 09:09 AM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Clayton
Clayton, install a battery. It's important since your shore power converter is probably exceeding 12 volts on its output. Most of the Airstream manuals advise against running the 12 volt appliances without a battery present.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-13-2005, 09:17 AM   #4
Images: 14
Can I run without a battery if I put the Intellipower in?
I dont have one yet, but looking in to it.
Old 06-13-2005, 09:48 AM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Couple questions
Greetings kl8ton!
Even with a modern converter (or inverter/charger as I have in my Overlander), it is never considered to be a good practice to operate for any significant amount of time without a coach battery (I suspect that the owners' manual for the IntelliPower likely makes a similar recommendation as found in the manuals for the new converter in my Minuet and the inverter/charger in my Overlander). In addition, the coach battery is required for the breakaway switch to function properly -- it is a required safety device in many states.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 06-13-2005, 10:05 AM   #6
Images: 14
Excellent point about the breakaway switch. I do have the battery, I just haven't brought it to the airstream yet.
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 12:10 PM
Questions with regards to A/S Storage dbmarshall Our Community 12 11-01-2002 07:34 AM
Search Questions hex Forum Admin, News and Member Account Info 4 10-16-2002 12:38 AM
Tow Vehicle Questions George Zook Tow Vehicles 6 04-19-2002 05:16 PM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 08:21 PM
