Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1970 Sovereign
Old 07-08-2008, 04:16 PM   #1
UpNorthAir
UpNorthAir's Avatar
Profile:  1970 31' Sovereign
Horton Bay , Michigan
The Adventure Begins 1970 31'
Well, I gutted my trailer ( 1970 31' Sovereign ) to find that there was floor and frame rot in the rear end, suprise suprise! I started to remove panels and banana wrap to remove the rotten flooring. Debating whether to do the full monte frame off or get by with just replacing the last peice of flooring.
Seems like I will have to remove all the belly wrap (I want to POR15 the frame and drop the fresh water tank) and remove half of the bottom interoir skins just to replace the rotten floor... hmmm might just do the full monte, keep finding signs of mice.......
Also started prepping the old bathroom fixtures for a coat of Interlux Brightside Polyurathane Paint. So far no surpises there. Good Rainy Day project.
Going to try welding a crack I found on the black tank. It is right where the threads stop on the tank. I have a friend who can do it, at least he says so .
My end goal is the following:
1. Make structuraly sound
2. Update Converter, Water Pump, Hot Water Heater
3. Replumb with Pex
4. Recoat bathroom
5. Build 2 sets of bunks, like PizzaChop's trailer
6. Linoleom Floor
7. New Kitchen / reuse cooktop
8. U-Shaped Dinette / Convert to bed.
9. Shiney Kewl Outside
10. New Hitch and Axles
11. New Awning
12. If there is any money left a new airconditioner
Here is a link with pics of how I found her.
Hello All
Here are some pics, I'll log the process here on this thread.
Joe
ID:	63367  Click image for larger version
ID:	63369  Click image for larger version
UpNorthAir is offline   Reply With Quote
Old 07-08-2008, 04:30 PM   #2
vhord
vhord's Avatar
Profile:  1970 27' Overlander
Crosby , Texas
Images: 95
Welcome to the 1970 club! You have gotten a lot accomplished since your member introduction. Looks like you are well on your way. I just finished the floor in mine so if you have any questions I might be able to answer them while it is fresh on my mind. Then when you pass me up I can ask the questions.
Vernon
1970 27' Overlander Restoration ("The Silver Belly", aka The SB)
Photo gallery
AIR #26858
vhord is offline   Reply With Quote
Old 07-08-2008, 04:31 PM   #3
Airdog
Airdog's Avatar
Profile:  1972 31' Sovereign
Pittsford , Michigan
Good luck Joe, I got a 1972 a few months back and look forward to learning from your efforts.
thanks, Bill
Airdog is offline   Reply With Quote
Old 07-10-2008, 10:08 AM   #4
UpNorthAir
UpNorthAir's Avatar
The Mouse Subdivision
Wow! Started taking off some off the interior skins in the lower rear and found what looks like a mouse housing subdivision! I am for sure going to take all the inside skins off and replace all the insulation. Good news is I have a bunch of the double bubble foil insulation left over from building my house. I used it for insulating my in floor heat system. Hopefully it we be enough to do the trailer.
I also got the old univolt disconnected and the wires marked. I have to say, Airstream did not "chince" on the wiring of these things. The new converter should go in the same place so the electrical won't need much alteration.
Taking down the belly pan is one dirty and dangerous job. Lots of sharp objects under there plus the mice condo units .
I just go two more jack stands from a friend, so I'm going to jack the trailer up and put it on jack stands to get more room underneath for working. Then I will continue with the interior skin and belly pan removal.
Laters,
Joe
BTW got a lead on a 1973 that a tree fell on that was in great shape..... already thinking about the next project
ID:	63447  Click image for larger version
The fulltiming adventure begins overlander63 Full-Timing 859 11-15-2008 11:08 PM
The adventure begins.... in more ways than one! katzklaw 1958 - 1963 Overlander 155 11-02-2007 12:16 AM
The Adventure Begins..... Chief 2007 Safari SE 6 10-09-2007 09:40 AM
A New Adventure Begins jpurdy Off Topic Forum 26 08-29-2004 01:00 AM
Off to LA....The Adventure begins JodynJeep On The Road... 29 11-20-2003 01:23 PM
