Old 02-06-2009, 08:37 PM   #1
86Scotty's Avatar
1973 31' Sovereign
Maryville , Tennessee
31' Sovereign's black tank size?
Hello out there. This may be a no brainer, but i'm fairly new and trying to find out the capacity of my black tank. I've got a 73 Sovereign 31 with a rear bath, and unfortunately, it's a model with only a black tank. Does anyone know the black tank size or capacity?
thanks
86Scotty is offline   Reply With Quote
Old 07-17-2009, 09:15 PM   #2
1973 31' Sovereign
Amherst , New York
here you go
I just replaced mine as part of a renovation. Here are the details of the exact replacement part, from the tank manufacturer:
Inca Plastics Inc. - 20 gal
Others may know for sure, but I believe this is a 25 gallon tank.
Cheers -
expat5 is offline   Reply With Quote
Old 07-17-2009, 10:30 PM   #3
Ottawa , ON
Can't guarantee a '73 black tank is the same size, but I can tell you that the '74 tank is 20 US gallons.
Look at your link - it says 20 gal.
Old 07-17-2009, 10:57 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Maybe it's a Canada thing...
Our black tank is 25 gallons (listed), closer to 30 gallons actual. The grey tank is supposed to be 10 gallons (wheee!), but is really 15.
Old 07-18-2009, 04:24 AM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
20 gallons, in my '72.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-18-2009, 07:53 AM   #6
1973 31' Sovereign
Amherst , New York
Aage-
yes, I know the link says 20 gallons, but Inca has their website divided drawings for holding tanks divided into 10 gallon increments. There are multiple cases of tanks in the 30 gallon section being 33, 35, and 37 gallons for instance.
That said, the specific drawing for the H4 does say 20 gallons...
My manual says 25 gallons from the factory. The new tank from Inca was dimensionally identical to the original factory tank I took out. It had two exceptions:
1. the "pilot" marks for the 2" vent line and the 3" inlet connection were in slightly different positions. I ordered the tank without holes or fittings in case this was the case, so it wasnt a problem. The 3" slip outlet was perfect.
2. The Inca tank was black; the original was white.
3. The Inca tank was half the cost (including shipping across country) than buying it from any Airstream dealer who had the tank in stock.
A quick calc of the "rectangular" dimensions provided in the drawing yields an internal volume of 25.8 gallons. From this dimension we need to remove the effect of the slope inside the tank, which is roughly 3.5 gallons, and the volume of the "notch out" by the slip fitting which is about 2 gal. I've rounded and not done super precise geometry, but I think its close enough for our purposes.
So in the end, somewhere around 20 gallons is probably about right. Looks like the manual is stretching the truth a bit!
Old 07-18-2009, 08:34 AM   #7
Ottawa , ON
Terry,
Are your two tanks original, or replacements?
How do you know the actual capacity? Have you done some measurements?
In other words, curious why the Owner's Manual would list different numbers than you have...
Old 07-18-2009, 08:36 AM   #8
Well Preserved
1993 21' Sovereign
Math, schmath...
I checked the capacity of ours the hard way--a gallon milk jug of water at a time. I've experienced the difference between "official" and "actual" figures many times, and wanted to know for sure what we had, especially being the third owners (you never know what they may have done).
So, if you really, really, REALLY want to know, you can find out--one gallon at a time.
Black water tank valve flange Safari64 Waste Systems, Tanks & Totes 1 09-22-2011 08:50 AM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 09:19 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 05:53 PM
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 07:50 AM
