Old 09-12-2012, 06:38 PM   #99
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
You DO know that we wives are on to you guys. We know all the tricks you use for getting new tools. I've learned from the best how to get my own new quilting tools.
Kay
Old 09-12-2012, 08:05 PM   #100
Central , Mississippi
Oh yes...the shrinker/stretcher tool is a better deal...The only plywood that works is 200 year old mohogany, the hammer is made from a rare Oriental Multi Layered Bronze and it only works on Space Grade Aluminum Alloys... Don't all Airstream owners have those? ;0)
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 09-13-2012, 04:58 AM   #101
Bauxter's Avatar
Columbus , Ohio
Speaking about alloys...There is a place in Columbus that has a huge lot of 3003 4' x 8' x .032 seconds for $33/ sheet (cheap belly pan)...now how can I work out getting that space age bronze hammer, I know....., I will call it a roof flashing hammer, something I will need to repair the hacienda de bauxter...Mrs. Bauxter will fall for it hook, line, and sinker
Bauxter is offline   Reply With Quote
Old 09-13-2012, 05:58 PM   #102
I used 3003 .025 for the belly pan and it worked great. For yours the .032 should be perfect since you don't have to make the corner wraps.
I think I paid $44/$48 for 4x10 sheets, cutting and running it crossways.
Yeah, Hacienda de Bauxter flashing hammer...that works!
Old 12-06-2012, 02:04 PM   #103
Bauxter's Avatar
Columbus , Ohio
Things we can do when it's cold outside.
So, I went out to the AS trying to figure out what I can do through the winter, and noticed that my tail lights were leaking when it rained. I temporarily sealed the outside joints that meet the aluminum with some vulkem. The leaks slowed a lot, but there is still a trickle. The AS has had some body damage and repair, and it looks like the tail light housings are not the same as each other.
Are there rebuild kits for these things? It seems that I have seen some lenses, but not sure about gaskets. Maybe I should just remove, and duct tape the holes until I have fixed or replaced.
Any suggestions? Does anyone have a link to a good thread on the subject, or a blowup diagram of the light assembly?
ID:	174024   Click image for larger version
Old 12-08-2012, 11:11 AM   #104
Minno's Avatar
1972 31' Sovereign
Check LED 4RV website. I think they have all the replacement parts including the tuna can liners. Chris rebuilt ours himself before the other stuff came out (of course, that's how it always goes!), and used LED lights for improved safety.
Kay
Old 12-10-2012, 07:10 AM   #105
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
It looks like you are missing the interior cover on the lower picture. I have a pair of them I,m not using.
Old 05-15-2014, 02:24 PM   #106
Bauxter's Avatar
Columbus , Ohio
OK so it's been a while
Seems like it took me a year to do not much of anything, but I did get the belly pan, wraps, fresh and waste tanks, spare tire, and running lights installed. Rear tail lights have new LED's. I did not use the Grote cans, as I used the sealed LED's. I used black Vulkem 116 around each light, which has the appearance of a rubber gasket.
In case you can't tell, the trim is going to be black (non-conformist, rebel punk that I am).
I also did away with the rear hatch. I plan on building an exterior aluminum trunk, or buy an aluminum truck tool box if I get lazy, and mount on the rear. I have a 3/16 C channel frame now, so hopefully the little extra weight in the rear won't be an issue.
The tank enclosure is complete, but the removable face plate is not on, in the picture. The gray is 27 gallons, and the black is 24.
The plan is to launch Labor day, so there is a lot to do in the next 3 months.
I will be removing the 3 vista view windows, and installing patch panels this weekend...stop by if you need practice on buck riveting.
More to follow in the next few weeks
ID:	211983   Click image for larger version
ID:	211985   Click image for larger version
Old 05-24-2014, 08:12 PM   #107
Bauxter's Avatar
Columbus , Ohio
Goodbye vista views, I will miss you, NOT
Removed the first of 3 Vista Views today. I can see why the windows leak.
ID:	212712   Click image for larger version
Old 05-26-2014, 08:31 PM   #108
Bauxter's Avatar
Columbus , Ohio
Removed the antenna while I was at it
I really like the looks of the trailer without the vista views and antenna.
Thank goodness my son was around to buck some rivets. Olympics would have cost a small fortune to do the 3 vista views. I will remove and replace the antenna cable cover next.
You may have noticed the crud on the roof....Time for a wash.
ID:	212944   Click image for larger version
Old 05-26-2014, 09:22 PM   #109
1973 31' Sovereign
Boerne , Texas
I'm new, so pardon me if this is a stupid question, but why remove the vista views?
Gwendolyn
campindaisy is offline   Reply With Quote
Old 05-27-2014, 05:20 AM   #110
Bauxter's Avatar
Columbus , Ohio
vista views
They are a leak source. I didn't like them anyhow. Since I am not restoring, but remodeling, I wanted to simplify my full-timing experience, minimizing maintenance, so I did not worry about keeping the old trailer in its factory-made form.
Plus, I already mentioned that (I am a non-conformist, rebel punk.)
Regards
mike
Old 05-27-2014, 06:15 AM   #111
1981 31' Excella II
New Market , Alabama
If you are going to make everything black then maybe you should change your handle to Blackster.
I would have nixed the vista views for the same reason, they are a pain in the A__. It does look like someone has replaced one of the tail lights. The older one looks like it is less likely to leak since it has a plastic cup behind it. My tail lights both have the plastic cup. Once that is sealed it does not matter if the tail lights leak. Water will leak in and leak out.
Perry
Regards
mike
Old 05-27-2014, 06:37 AM   #112
Bauxter's Avatar
Columbus , Ohio
Perry
Perry, The tail-lights are a whole nother conversation... 1973 tail-light assemblies are riveted to the body...the body being sheet, and the tail-light being cast. Since the body was not in the original factory perfect shape, I could not rivet them, as the rivets did not draw the assembly tight enough to the body for a leak-proof deal. I tapped the holes in the assemblies, and use stainless 10/32 screws to draw the assembly to the body. It worked great, but now, I am afraid to loosen the screws to instal the inside covers to the lights. I am still thinking on the situation, maybe an epiphany will occur, or more likely a knowledgeable member will advise me of what to do.
BTW, only the trim lines will be black, kind of a pirate mind-set kind of thing. OK, there may be some pink too, as in flamingo.
mike
1973, 31', remodel, skin replacement, sovereign
Restoring 1973 Sovereign Baton Rouge BWMorgan225 1970 - 1973 Sovereign 76 04-15-2014 05:55 AM
1973 Airstream Sovereign Land Yacht Southern California eBay Watch Airstreams on eBay 0 02-22-2011 12:40 PM
1973 Airstream Sovereign Land Yacht Southern California eBay Watch Airstreams on eBay 0 02-11-2011 09:10 PM
Towing 31' sovereign 1973 model Flaboy67 Tow Vehicles 1 02-04-2011 06:17 PM
Great 1973 Airstream Sovereign with screen room eBay Watch Airstreams on eBay 0 01-30-2011 06:50 PM
