Join Airstream Forums Today
Old 11-21-2010, 10:39 PM   #1
Trex's Avatar
1972 31' Sovereign
Shasta Lake City , California
The old girl needs new shoes....
I am going back and looking at all my blogs and threads and plan to submit here, so I can have a record of repairs in one location on the forum. My hope is that other new 72/31' Airstream owners don't make some of the same mistakes that I have made over the last two months. And as I progress thru this process, my hope is that others who have been down this same "Road", can pass on some of their knowledge to me and others who may read the following....
My first blog about my new, (to me) 72/31' Airstream was 10-03-2010. At that time, I really couldn't see "The forest from the Trees". Meaning When I first saw her I wanted her. The skin looked good, and the interior was all original. I didn't pull back any of the old carpet and check for water damage. For some reason, I had it in my mind that Airstreams don't leak water, the axles last forever, and the wheel wells are bullet proof!
BOY-O-BOY... was I wrong! I take the old girl to the Wheel Doctor on 10-07-2010. They replace one small spring and tell me that the wheels/axles look "Like New" overall. But after reading some of the threads about axles and "How to test axles", and then perform that test on the old girl, I discover that I will be replacing the axles sometime early winter!
This shop works on RV's all the time.... but they don't have any basic understanding of Airstream Axles and the fact that Airstream axles have a shelve life. If you'er thinking about buying a 70's Airstream, or older, you will be buying new axles for your new baby. "YEP, your baby needs new shoes"!
On 10-09-2010 The Bunny and I take the old girl on a quick trip to Rolling Hills Casnio in Corning, Ca. Approx. 1 1/2 hours south of Shasta Lake, (were we live). We wanted to camp in her once, before I started the process of remodeling.
I connect to shore power and water in the RV park behind the Casnio. Water lines and sewer drain line are leaking under the kitchen counter! So, for the rest of the weekend we do without water service.
That following monday, I started gutt'en out the Old Girl, and that was like openning a "Great Big Can of Worms".
The Bunny and I at Rolling Hills
Our dog, Jacky Russell, watching me head over to the restroom.
On 10-12-2010, I posted a blog about removing the kitchen cabinets, stove top, over, etc. That is when I discovered that the plastic wheel wells needed to be repaired and/or replaced. At the time I was thinking that the PO had a tire blowout.
What I know now is.... my worn out axles caused the damage to the wheel wells and may have caused the sewer line under the sink to break at the 1st fitting. Trex "May Wally be with you"
Trex is offline   Reply With Quote
Old 11-21-2010, 10:56 PM   #2
Trex's Avatar
1972 31' Sovereign
On 10-15-2010 I posted my first Thread on water damaged floors in the "Old Girl".
At that time I was feeling like.... what and the hell have I gotten myself into. But with the Help of Wasagachris, Barts, Wahoonc, RedhawkerII, Andy, and many others, they helped to walk me thru the process. Thanks Guys and Gals....
Floor in the bulkhead... before and after
Name:	DSCN0343 (640x480).jpg
Old 11-21-2010, 11:15 PM   #3
Trex's Avatar
1972 31' Sovereign
RE: 1972/31' AS wheel well patch
On 10-21-2010 I started on another new Thread concerning patching the wheel wells. Following is from that Thread.....
Now that the floor replacement is done, its time to move on to the wheel wells. Pulled the outer plastic wheel well cover to inspect the black inter wheel well. I found four cracks in the black wheel well, one in each lower corner, and two on the topside of cover. I have decided to use that Rubber roof patching tape.
Cleaned wheel wells with TSP….let dry and applied Tape over the cracks. Hope it works! What other produces are out there in Airstream land to patch cracks like this, (see Photos).
Name:	Wheel well 015.jpg
Name:	Wheel well 016.jpg
As you will see later in this Thread, I went back and patched wheel wells the "Right way". Trex "May Wally be with you"
Old 11-21-2010, 11:38 PM   #4
Trex's Avatar
1972 31' Sovereign
RE: Taken it...one leak at a time
I started this thread on 11-01-2010, the following is my first post, that is when I got my "leak fix'en kit" from Inland RV. Thanks for you advise CrawfordGene and many other Rivet Master's for their help.
Weather report says 4 days of sunshine in SLC, so it’s time to pull the tarp off the old girl and start cleaning, prepping, and sealing. Looks like “The Old Girl” is leaking water around the wing windows, the vista windows, the awning, and possible water leaks around all the vents, sky lights, and AC. Today I will clean around the vents, awning and AC. Tomorrow I will start sealing around the above said areas.
The task is feeling a little over whelming, but I will try to take it… ”one leak at a time”. I will post photos as I go and I am sure I will have some questions for you Streamers who have already gone thru this process. I keep re-reading other threads concerning this task and you folks make it look easy. "Learning How To Become" a good RV tech in harder then I though it would be. trex
Name:	Cleaning with razorblade.jpg
Note: razor blade in wing window sash.
This part of the process took almost two weeks to find all the leaks. I was starting to think that I would never get the awning leak sealed! Trex
"May Wally be with you".
Old 11-22-2010, 12:00 AM   #5
Trex's Avatar
1972 31' Sovereign
Install new wheel wells/patch on 72/31' AS
On 11-10-2010 I started a new Thread on well wheesl because I decided to redo the wheel wells the correct way. It took me a couply of days for the comments that Andy and others had posted to sink into my brain...
Finally got to install one of my new wheel wells, and patch the black plastic wheel well with Alum. sheet medal, vulken, and pop rivets. I still have leaks to run down....Damm awning supports leak'en.
I really like my new Alum. wheel wells. trex "May Wally be with you.
Old 11-22-2010, 12:18 AM   #6
Trex's Avatar
1972 31' Sovereign
One of my main leaks was coming from the old roof vent. The following are the photo's from post 23 & 25 under "Taken it....one leak at a time.
Name:	Fixen leaks roof 011.jpg
Name:	Fixen leaks roof 016.jpg
Name:	Fixen leaks roof 022.jpg
Name:	Fixen leaks roof 023.jpg
Old 11-22-2010, 12:33 AM   #7
Trex's Avatar
1972 31' Sovereign
RE: Remove interior acrylic vista window...easy!
On 11-15-2010 I posted this thread concerning the plastic/acrylic vista double pane. As most owner's of a 72, this is one of the only ways to clean out the crap between the two window pane's.
After looking at a thread on "How to remove the plastic acrylic interior vista windows", I thought that I would give it a “go”. It took less than an hour to do the whole operation, and a lot easier than I thought it would be.
Using a Dremmel drill tool, I set the depth gage so I wouldn’t contact the corning glass exterior window and simply went around the window frame work, using it as my guide for the tool.
Once I cut out the main body of the old window, I made vertical cuts towards the aluminum window frame.
Than using “vise grips”, I started pulling out the sections of acrylic left in the rubber gasket and aluminum framework, starting at the bottom.
Once I had the bottom section removed, I pulled on the rubber gasket and the rest of the top half of the acrylic window fell out.
Each vista window in my 72/31’ has a separate channel framework for the acrylic window and the corning glass window, so removing the interior acrylic has no effect on the exterior window.
Make sure you use eye, ear protection and gloves!!!!!
Old 11-22-2010, 01:03 AM   #8
Trex's Avatar
1972 31' Sovereign
RE: Low VOC paints by Further99
I posted this reply under Futher99 Thread concerning interior primer and paint under the "General Repair Forum".
Smart Prime
I have been looking at many of the Threads concerning priming and painting the interior walls. Looks like "Plasticizers" is the major issue, which is the magration of plasticzers to the surface of the vinyl wall cover in 70's/80's Airstreams. I think it was the bonding agent between the Alum.&the vinyl, after 20 plus years it starts to break down and shows up as a sticky subtains on the surface of your walls.
Anyway.... I went to my local paint supply store today,(Cascade Paint), with my notes. To see if they have anything that may stop and/or block the migration of the plasticizers.... I had a small sample of the, (3"x3"), vinyl wall with me. Casey the owner said that Smart Pimer by Zinsser, is a new interior/exterior primer that offers the performance of an oil-base primer in an advanced water-base formula.
So, I got a Qt. of the stuff and painted on the street side wall to test and see how it performs. Its been raining all weekend, so next week once it has dried out a little and the primer is not sticky. I will prime the rest of the trailer. Maybe three coats...maybe two!
So, now that I have all of my threads posted in one place. It should be a little bit easier for me to stay on track.
Trex "May Wally be with you".
Old 11-22-2010, 06:49 AM   #9
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
At times I feel the same way about my refurb. but when I look back to last fall and then to this fall I look at how much better the inside looks I think to myself. "It has been worth it, can't wait until next year for the shack down trip to South Texas.
Good luck and it does look better.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 11-22-2010, 08:03 AM   #10
SilverHoot's Avatar
1967 24' Tradewind
Redding , California
Rex,
Great reading your thread. I am STILL tracking down leaks in mine. Have one in the rear that is making me crazy and until I get all the leaks I can progress no further. Last rains revealed that while I fixed most, not all. If you are going to be around I'm going to try to make it over to check yours out...
SilverHoot is offline   Reply With Quote
Old 11-22-2010, 10:44 AM   #11
wasagachris's Avatar
1973 31' Excella 500
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
Send a message via Skype™ to wasagachris
Hey Rex & Silverhoot. I recently pulled all the inner panels in mine. So now I have an empty shell. A lot of the leaks that I attributed to roof vents, windows and the like were not in fact leaking there. I found significant corrosion all along the roof to side skin seams. There is evidence of the seam leaking and the water running down the inside of the shell until it reached a window frame. At that point it would run around the window frame and exit through the inner panels to drip into the trailer. the inside of the vent and window frames have lots of vulkem around the inside of the frame against the inside of the shell and do not show any trace of leaking. If you have a persistant leak try sealing the seams from outside unless you have the inner panels off then seal there too.
wasagachris is online now   Reply With Quote
Old 11-22-2010, 11:04 AM   #12
Trex's Avatar
1972 31' Sovereign
Hey Hoot.... I would be working on the Old Girl thru weds of this week. With your inside skin off, have you though about the leave blower trick and seal the rest of the trailer off with blue tape and plastic? If you try this, give me a call I would like to help, and I would like to see this done. trex
Old 11-22-2010, 11:11 AM   #13
Trex's Avatar
1972 31' Sovereign
Hey Wasagachris, The Old Girl was painted silver maybe 20 years ago, so there could be corrosion under the paint, I hope not. You must have a place for your trailer to sit out of the weather. Or are you done with your projects... I was think'en that once you buy an Airstream the projects are never ending. trex :0
Old 11-22-2010, 11:18 AM   #14
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
Rex My exterior seams showed only small corrosion lines along the seams (maybe 1/16" wide but inside the seams at some points showed 3 " wide corrosion.
Mine is temporarily inside my workshop. It has to come out for the winter because I can't get the door closed all the way and I need the space for snow(white frozen rain for you So. Cal. folks LOL) removal equipment.
Yeah they are a lifetime commitment. Good thing they last alifetime. I started mine in June and hope to finish it next summer. I have the luxury of working on it almost full time because it is at my workplace which is also my residence.
P.S. thanks for the thumbs up in post #2.
1972 sovereign, 31', floor, leak, patch, refurb, vista view
« Little Girl Refurb | Top | - »
Biker Girl is Back she ran off Match.com Girl Jim Clark Off Topic Forum 6 07-23-2008 08:09 AM
