Originally Posted by tphan
hi- in coaches this old there can be just enough greenish corrosion to prevent good contact in the fuse holders. So, you might try just disconnecting the battery and shore power and pulling out every single fuse, cleaning their ends and the holders with whatever- steel wool, fine sandpaper, etc. I also did this with the main cable coming from the battery to the univolt, and suddenly everything worked! Just clean things up, and maybe tighten up the fuse holders so there is good contact, reconnect power and see what happens. -tim
Good advice!
One of the things I've learned from playing around with old tractors is that you need to periodically check all your electrical connections. Loosen each connection (one at a time) and clean off any corrosion.
It's a mantra with old tractor folks: "Keep em clean, bright and tight".
I have found that what works very well is a called a fitting brush - used for polishing the insides of copper fittings used in water lines before you solder them together.
Good Luck
and keep us posted on your progress.
