Join Airstream Forums Today
Old 01-15-2012, 04:13 PM   #1
ND10CentCan's Avatar
1976 31' Sovereign
1959 17' Pacer
1966 22' Safari
Bismarck , North Dakota
The Albatross
Thought I should start a separate thread that shows the progress on our 1976 Sovereign-the Albatross. It didn't make sense to keep putting updates on the frame repair thread so here it goes. I am putting up some pictures of the work that we have been doing lately. Some looks pretty good and some looks scary.
One of the pictures shows a tiny little dental type tool I am cleaning all of the exterior window frames with....very carefully...one dirt molecule at a time. The PO's must have been silicone investors because they put enough of it on the windows to sink a ship. What a job to get that stuff off the exterior. Can't say I am done with that job unfortunately....the saga continues.
I love the color that is going up on the walls especially once you see the fabric I have for the curtains and cushions. Let's get sewing!! Oh wait...I guess I have to help get the walls up first.
Sandy
Name:	Christmas 2011 254.jpg
ID:	148969   Click image for larger version
Name:	Christmas 2011 246.jpg
Name:	Christmas 2011 262.jpg
ID:	148971   Click image for larger version
Name:	Christmas 2011 258.jpg
Name:	Christmas 2011 250.jpg
ID:	148973   Click image for larger version
Name:	Christmas 2011 245.jpg
ND10CentCan is online now   Reply With Quote
Old 01-16-2012, 06:23 PM   #2
1976 31' Sovereign
1959 17' Pacer
1966 22' Safari
More accomplished today
Spent all day working on renovating the screen door, bucking some rivets, painting, and cleaning up the access doors. I now have all of the inside skins painted with two coats of paint, about half of the screen door done, rivet duty caught up for now, and the access doors are almost done.
The wiring diagram has wires going to a step light but there is none on our trailer. Are we missing something? Can we add one? If so, which one? Another question, where do we find a replacement over the door light? The light is right over the door frame and ours is toast. Sources would be good here...thanks in advance of advice, direction, and guidance.
Sandy
Old 01-16-2012, 06:51 PM   #3
1971 18' Caravel
1974 Argosy 20
1975 Argosy 22 Rear Door
Kooskia , Idaho
On the "step light": I think that is your "over the door light". Airstreams of that vintage had two switches, one for the outside flood light (scare light) and the other for the over the door light.
On my recent renovations I have taken the over the door light apart, put an opaque piece where the white plastic light cover was, and fastened a small yellow LED running light to that cover. On mine there was enough clearance over the door for the LED light I picked out. It takes so little current it can be left on all night if you want. Being yellow, it is also more bug resistant. The original incandescent light took over an amp to run, and did almost no lighting. This is much better, and looks good. So, consider changing the over the door light from original to an LED.
Old 01-16-2012, 07:38 PM   #4
1976 31' Sovereign
1959 17' Pacer
1966 22' Safari
Am I to understand...
So do we have two lights on our AS? I can see only the over the door light and no scare light. I would like to add a light that would illuminate the steps at night if possible. Where do I find the small yellow LED to replace the over the door light. Thanks for your help.
Sandy
Old 01-16-2012, 09:34 PM   #5
wasagachris's Avatar
1973 31' Excella 500
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
Send a message via Skype™ to wasagachris
Hi Sandy, the best place I found for led's is LED'S for RVS.
LEDs 4, Recreational Vehicles
They have LED kits for the over the door light.
LED Bright White Multi Purpose Pad PDS70x32mmBW [PDS70x32mmBW] - $17.95 : LEDs 4, Recreational Vehicles
They also carry complete scare lights in LED as well.
LED Flush Mount 5.5 in Backup Porch Light 48x68BW-80423C [48x68BW-80423C] - $39.95 : LEDs 4, Recreational Vehicles
This one would probably do for under the steps.
13 Amber LED Bullseye with Light Guard A13LEDCZ12P [A13LEDCZ12P] - $9.49 : LEDs 4, Recreational Vehicles
1973 Excella 500 31ft Center Bath
1963 Overlander 26 ft
1961 Sovereign 30 ft Custom
1955 Overlander 26 ft
1947 Liner 22 ft.
2010 Ford F450 Crew Cab Dually Diesel
TAC ON-11
Every day is a gift, but does it always have to be a pair of socks.
wasagachris is online now   Reply With Quote
Old 01-17-2012, 05:34 PM   #6
1976 31' Sovereign
1959 17' Pacer
1966 22' Safari
Thanks and where does it go?
Originally Posted by wasagachris View Post
Thanks Chris,
I will check these out and see what I can figure out. Does the scare light go under the steps where they fold up? I am confused as to the exact location because whatever was there before is long gone. Does your 73 have it?
Sandy
Old 01-17-2012, 05:48 PM   #7
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
I'm surprised that your trailer didn't have a scare light. It is mounted in the curbside of the front end cap. It is aptly named because it is so bright when you turn it on it will scare away anyone or anything that is outside the trailer.
Yes my trailer does have the scare light. If you look at my thread a few of my pics of polishing show the scare light.
1947 Liner 22 ft.
TAC ON-11
Old 01-17-2012, 07:54 PM   #8
1976 31' Sovereign
1959 17' Pacer
1966 22' Safari
Definitely not there...I double checked
Hey Chris,
I checked your thread and found the scare light that you are talking about. We definitely do not have that on our trailer and it is strange because we have the wiring for it on the manual but not the actual light. I am wondering if we should add it but am nervous to cut a hole in the skin....but I like the idea of having a light to see out. Hmm....do you think the best ones are LED? We didn't do LED on the outside lights because we wanted to stay vintage. Advice?
Sandy
Old 01-17-2012, 08:05 PM   #9
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
Hi Sandy the regular incandesent scare light is plenty bright. I'm going with LED's everywhere to cut down on battery consumption. My idea is to build my trailer with every possible type of camping scenario. It will be able to boondock for a long time and it will also be able to be used with full hookups too.
The LED's are very bright. Last year I was testing my clearance lights and I could read papers just from the light from them inside a darkened shop at night. The scare light probably could be used to signal UFO's from space it was so bright.
I wasn't that concerned about keeping the 73 to an exact period vintage look. The LED's for stop/turn and clearance lights are in my opinion better from a safety point of view.
as far as installing a scare light I would miss mine if it was not there. It's good for those noises in the night and also very helpful finding your way back to the trailer on dark nights.
1947 Liner 22 ft.
TAC ON-11
Old 01-17-2012, 08:13 PM   #10
1976 31' Sovereign
1959 17' Pacer
1966 22' Safari
Thanks....
Thanks Chris,
I will mention it to the boss when he comes in from installing more belly skin/banana wraps. We should decide this pretty soon because we plan to start insulating this weekend if all goes well. I think it would be very helpful to have and now is the time to add it.
Sandy
Old 01-22-2012, 05:25 PM   #11
1976 31' Sovereign
1959 17' Pacer
1966 22' Safari
No scare light here
Chris,
I took this picture today where I think we were supposed to have a scare light. No evidence of any scare light now or in the past. I did get the LED light you suggested and we are going to try one under the steps (?) I have no idea if we can make it work or not. Also got the over the door LED pad so that should be interesting as well.
Sandy
Name:	January 2012 Albatross 029.jpg
Old 01-22-2012, 05:46 PM   #12
1976 31' Sovereign
1959 17' Pacer
1966 22' Safari
More progress even if it is kind of slow
Here are the latest photos of all the work that has been going on with the Albatross. The first interior panels are up, the insulation is proceeding, wiring is about done, and the exterior windows are cleaned up all the way around the trailer. Phew!
I took the screen door in to get a new screen put in it and a door guard to keep the dogs from punching through it the first fifteen minutes we are out for the first time with the trailer. We have one dog that jumps at the door when she wants to go out and one dog that stands and stares at the door when she needs to go out. It is dog number one that I could see punching a hole in the screen in no time or else launching herself out of it when she saw someone or something come by.
The tedious work of cleaning every old bit of dried/semi dried piece of vulkem, dirt, alien life forms, and other interesting tidbits out of the window edges took me about five days worth of work. The only way I could do it was with an entire set of dental tools, a bunch of rags soaked in mineral spirits, and a long platform to work from. I worked on that the three days of last weekend and all of this weekend. I can say I am done and don't want to do that again for a long time.
I am wondering if I should touch up all the rivets with paint on the interior or just leave them as they are. The wall color is going to be really nice once I get the fabric up and the cushions made. Of course that is personal opinion What have other people done with the interior skins if they painted them while they were flat stanleys? Do you leave the rivets their aluminum color or touch them up with the wall paint?
Next up is replacing all the screens. My dearest says that will be my project because he doesn't want to mess with it. Should be a learning experience and an opportunity to figure out another part of Airstream restoration.
Sandy
Name:	January 2012 Albatross 010.jpg
ID:	149395   Click image for larger version
Name:	January 2012 Albatross 025.jpg
Name:	January 2012 Albatross 037.jpg
ID:	149397   Click image for larger version
Name:	January 2012 Albatross 015.jpg
Old 01-22-2012, 05:55 PM   #13
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
Sandy yes I did see in one of your other pics that you don't have a scare light. That is very interesting as I have never seen an A/S without one. The only thing I can think of is that the segment was replaced and they opted not to reinstall the scare light. Is there any evidence that it has been replaced? Are there olympic rivets on that panel?
Your DH can easily install the scare light. He just needs to cut open a hole in the skin for it.
To install the under the step light just make sure it will not interfer with the steps while they are in the closed position.
The over the step light pad is easy to install in a few minutes.
1947 Liner 22 ft.
TAC ON-11
Old 01-23-2012, 01:40 PM   #14
1976 31' Sovereign
1959 17' Pacer
1966 22' Safari
You are RIGHT!
I asked my chief renovator when he came in and he said that segment had been replaced at some point in the past. So you were absolutely right about that. He doesn't want to cut any holes in the skin so will be going with a light under the steps. Right now he is trying to figure out the wiring plan from the manual. Seems we don't have a pink wire (12V) that is supposed to go to where the side table was. Plus there is a blue and white wire that he is not sure of what that is. Every step is a learning adventure but thankfully it isn't too bad....yet.
Sandy
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ND10CentCan
Seems as if fixing the frame will be a DYI job ND10CentCan Repairing/Replacing Floor &/or Frame 273 01-05-2012 07:28 PM
Future home of the Albatross ND10CentCan 1976 Sovereign 46 06-24-2011 05:11 PM
Your Airstream's Name? Roadrunner Fun & Games 47 03-28-2011 04:39 PM
