Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1974 - 1979 Sovereign
Old 10-18-2006, 08:32 PM   #1
racoco's Avatar
1976 31' Sovereign
2007 19' Bambi
Midland , Texas
plug-in battery connection
Through lack of observation and misfortune, I am in need of the battery cable that connects to the battery and the "plug-in." Does anyone know a good resource?
Thanks.
racoco is offline   Reply With Quote
Old 10-18-2006, 10:36 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
A picture could be worth a thousand words. Right now only a similar vintage owner could reply to your question. Me? I'm lost on what you're asking about. Battery location and univolt location are variable across the years but there is a surprising amount of common equipment used in Airstream and Argosy products. If you could post a 600x800 digital photo of the area of concern I'd bet more folks could say, "Ahah!" and help you out.
Thank you!
5 meter Langford Nahanni
Old 10-19-2006, 06:12 AM   #3
Silver Mist
LI Pets's Avatar
Riverhead , New York
I have one.
Old 10-22-2006, 09:17 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
There is no source for replacement as original. Those that you do find, people want a premium. I had a company make up a set with Anderson disconnects, battery post lugs, etc. and replaced the wire from inside the battery box to the fuse box. I'd have to look up the address but the company was Baker Manufacturing or something like that. I still have the one side I pulled out of the trailer if someone is interested.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Extra Battery Placement JaceBeck 1997 - 1999 Safari 16 10-02-2002 01:03 PM
Auto Battery problems.... kzener40 Airstream Motorhome Forums 10 08-05-2002 06:37 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
