Chris,
Looking good, nice outriggers too! BTW I just found out the other day we can still buy those from an Airstream dealer...go figure... I will probably go that route on my '80 when the time comes.
Aaron
WBCCI #XXXX AIR #2495
Chris:
How did you replace the floor so that the plywood panel could be placed in the channels? Thanks
In my opinion the easiest way to replace the plywood and get it into the bottom c-channel is to lay the sheets lengthwise instead of cross-wise. Put a plywood spline 4 to 6 inches wide under the middle joint and attach it to both sides with glue and screws. On the ends you can put the curved pieces in cross-wise if you put them in first. The trick is start with them on the diagonal and rotate them into position.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
