Old 08-21-2009, 05:23 PM   #1
2000 31' Excella
Maryville , Tennessee
Excella questions ?
Hello, we are trying to understand what most excellas have when it comes to carpet in the kitchen.
My wife says she would rather not have it in the kitchen but will accept it if most (1996-2000) comes that way.
In an earlier post I ask about dinettes and found out some do and some don't so I imagine carpet is the same.
We are looking at excellas and limited AS and just wondered if there is a spec sheet that says all excellas have carpet and all limited does not (kitchen) etc.
Robbie R.
Robbie R. is offline   Reply With Quote
Old 08-21-2009, 05:34 PM   #2
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
My '97 had yellow shag carpet in the kitchen. We opted to take it out and put down some vinyl. See some of the vinyl here: http://www.airforums.com/photos/show...00&userid=3264
The problem with the OEM carpet is that the floor is covered with the carpet before the cabinets are installed at the factory. If you remove all the OEM carpet and if you don't put back carpet where the OEM carpet was located, you wind up with a space the thickness of the carpet under the cabinets. In other words, the cabinets are suspended above the floor deck, hung by the walls, with a 1/2" or so gap between the wood decking and the cabinet bottoms where the carpet used to be. I chose to make wood shims to support the cabinets where the carpet was removed. When I put the sheet vinyl down, I had to use quarter round oak at the perimeter to hide the gap and shims between the sheet vinyl and the bottom of the cabinets. It was a pain, but turned out well.
So Long!
Bob Thompson is offline   Reply With Quote
Old 08-21-2009, 06:08 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Don't let the presence of carpet be the decision maker in the selection of your trailer.
It is all too easy to remove it and install a manufactured wood floor. I did mine with my assistant.
2004 Excursion 4x4
Old 08-21-2009, 06:10 PM   #4
2000 31' Excella
HowieE, that looks great !
Thanks Bob. I just wondered if the carpet thing was just a random deal.
I looked at all your pics and just wonder how you find time to go camping........
Great work !
Robbie R.
Old 08-21-2009, 06:11 PM   #5
Crusty's Avatar
1992 34' Excella
I cut up the carpet in my kitchen (too many spilled glasses of grape juice) and installed Treadmaster vinyl flooring from Home Depot in its place and I've never looked back since then.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 08-21-2009, 06:48 PM   #6
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
89 Excella 1000
Ours started with carpeting in all areas. The PO pulled that out and did the floor in Pergo. Looks great and is easily cleaned up.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 08-21-2009, 09:07 PM   #7
Central , Mississippi
In researching our '91 I found that it was an option to have a non carpeted floor in the kitchen. I really don't recall what the option was, vinyl or wood.
Our non excella '77 had wood/composite tile in the kitchen with carpet everywhere else.
Its really not a big deal to pull the carpet and put down whatever style floor ya' want
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-21-2009, 10:03 PM   #8
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Last week I was sitting pondering the same question, I was pulling out the original yellow shag and recarpeting my Excella with a scrap piece of carpet that would do the whole length from the rear up past the kitchen. Really wanted the look and feel of new carpet in the kitchen but decided to cut it off where the patchwork wood type stuff is in the kitchen. I've never kept a dry floor in a kitchen, so I doubt I could start now. The original carpet installation looked like it was a real class job. I used two wide flat chisels to talk the carpet edges back under the edges of the beds.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 06-11-2017, 08:59 AM   #9
1985 34' Excella
Sandusky , Ohio
We are having a new floor installed at P&S Airstream in Helena Oh. Putting in Happy Feet Endurance Cook. Can't wait to see it.
pauliesg is offline   Reply With Quote
Old 06-11-2017, 09:25 AM   #10
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Whatever the flooring is it will be 20 years old and could use and update. We have 2 late 80's Excellas with the carpet long gone from both.
Bill M. is online now   Reply With Quote
Old 06-11-2017, 09:43 AM   #11
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Between us and the dogs, a lot gets tracked into something like a trailer or a house. I would not vote for carpet anywhere near a door or a work area. Find something easier to clean and go with that.
1989 Excella 25' newbie questions BillTex 1987 - 1989 Excella 40 09-28-2015 06:58 AM
1983 Excella Questions Larry71 1981 - 1983 Excella 4 12-24-2009 09:17 AM
1999 Excella 28' Questions TomR 1997 -2001 Excella 5 06-03-2009 09:56 AM
84 Excella Questions Alligood General Interior Topics 11 03-21-2006 11:12 AM
Exterior Finish Questions-85 Excella Kirby Stone Cleaning, Stripping & Polishing 2 10-21-2002 05:27 AM
