Old 04-21-2008, 04:03 PM   #1
valletta , malta
Excella 34' where is the Genset?
I am looking to buy a 34 but I cant find mention of a gen set in any of them, I prefer to camp off site. where can I fit the genset (I guess easiest answer is right outside the trailer) but I would like to go integral
Any help appreciated
bronywolfe is offline   Reply With Quote
Old 04-21-2008, 04:19 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Howdy valletta -- Welcome to the Forums! Airstream trailers have never come with a genset. I've read of a few custom installations but doing this within the shell is problematical. Somebody did a thread where they mounted two Honda eu2000i gensets on the A-frame. Genset were put in Airstream motorhomes but I can't speak with any authority on that.
A lot of people boondock with their Airstreams and there is a subforum at http://www.airforums.com/forums/f37/ with much discussion on power while off-grid.
5 meter Langford Nahanni
Old 04-21-2008, 05:25 PM   #3
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
You sure about that? My father's '78 Sovereign International has an LP-powered Onan that appears to be a factory installation. It's mounted streetside underneath one of the rear twin beds. There's a box built around it that's lined with sound deadening material, a vented factory type door to the outside, and the exhaust exits through the belly pan. The controls are mounted with the trailer's control panel inside the overhead cabinet at the front of the trailer with the control wiring running inside the walls all the way to the back. If it wasn't a factory install, someone went through a LOT of trouble to get it in there like that. I'm not doubting that it was never an option, but it looks to have been custom ordered with the unit.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 04-21-2008, 05:37 PM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Sovereigns were available with a 300 watt LP generator mounted in a cubbyhole. My 74 owner's manual shows it, and the '74 and '77 service manuals both show them as options.
Old 04-21-2008, 05:45 PM   #5
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
A LPG generator was available on Airstreams in the mid 1970's.
I believe it was only a 12 volt unit to keep the battery charged.
(That was ahead of it's time along with the Excella-Vac disc brakes.)
I've seem one AS with the LPG generator in person years ago, a 73 Excella 500.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 04-21-2008, 06:17 PM   #6
Journalist's Avatar
1969 25' Tradewind
I can confirm that it's 12-volt. Pulls a 700-watt inverter without breaking a sweat though. The controls are set up on a timer. You crank the timer over up to about an hour maximum, and then hit the start button. My only complaint is that it's rather loud in comparison to some of the smaller modern portable generators, and it makes the streetside twin bed vibrate like a cheap Vegas hotel room bed.
AIR #8891
Old 04-21-2008, 06:36 PM   #7
Air Apparent's Avatar
Northern Illinois , Illinois
Valletta:
We caravaned with a couple who had a late 1990's classic 30 who had a factory installed genset. It was under one of the dinette seats and exhausted out the side.
Dave
2008 Classic 34
Dodge Ram 2500 Quad Cab CTD
AIR #7317 WBCCI #1772 TAC-IL 1
Air Apparent is offline   Reply With Quote
Old 04-21-2008, 07:32 PM   #8
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Valletta
We install Onan or Generac 4000 Watt (3600 LP) gen sets under the forward dinette seat on 30's and 34's. The installation is a little involved but it can be done.
They exhuast vent through the floor. We modify and exterior compartment door to be the intake vent.
They can also be installed under the bed but the dinette seat is an easier and neater installation.
Andrew T is offline   Reply With Quote
Old 04-21-2008, 07:35 PM   #9
Well Preserved
1993 21' Sovereign
That's the one. It is "rated" at 300 watts, but another post here shows that the rating was conservative.
Old 08-16-2010, 08:38 PM   #10
1987 32' Excella
Chesterfield , Missouri
Originally Posted by Andrew T View Post
Hi Valletta
Andy- Do you have any photos of the generator installations you have done? I have a 32' Excella with the dinette and was considering a Onan Microlite 2800 under the seat nearest the fridge and fabricating a new vent to the outside for air intake. Thanks
farmboss104 is offline   Reply With Quote
Old 08-17-2010, 04:26 PM   #11
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Would also appreciate pictures if possible.
Old 08-17-2010, 05:35 PM   #12
Central , Mississippi
The Genset for my 34' 1991 excella 1000 classic is in the bed of my truck....
Load it up! - Airstream Forums
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-17-2010, 06:33 PM   #13
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I have seen one late '90's trailer with an genset custom installed by the factory. It is a very unusual and rare option. I think you would be better off finding a trailer you like, then adding one.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 08-17-2010, 08:44 PM   #14
2004 30' Classic Slideout
Albuqueruqe , New Mexico
I installed a 3200 quite diesel onan in the back of the truck, works like a dream! And heck the truck is for sale here on the classifieds… I ordered a new 11 Ford and I’m going to do the same genset in the new truck! I first started looking at how to install a generator in my 31 classic, and just could not come up with a good way of doing it without hacking up my Airstream… there is just no good place to put it…
Name:	gen set install 005.jpg
nmgt350h is offline   Reply With Quote
What makes an Excella an Excella? MaraLindstro 1990 - 1993 Excella 17 Today 06:03 PM
Can you run both Air Conditioners with the Genset? Keyair Classic Motorhomes 4 08-26-2011 05:32 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
