Old 06-22-2010, 01:51 PM   #1
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
Creaking floors
Okay, my searches ended up with nothing. My 95 ex 1000 has a creaking noise in the floor just as you enter the rear bedroom area from the center bathroom area. This model has the walk thru bath and a carpeted floor. Now, my pea brain says creaking means dry subfloor, which is good. but the creaking is annoying. The carpet is too good to just rip up and then fix the creak although this may be the best answer. Any hints?
wmarsha is offline   Reply With Quote
Old 06-22-2010, 11:28 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my trailer, when new, had a creak in the floor at the bedroom entrance. The repair shop repaired the creak from underneath. later I had another creak in the front. I decided to just leave it as is. Now I don't have any creaks; The weather and temperature, and expansion and contraction has something to do with it too. Probably not worth bothering with.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-23-2010, 06:20 AM   #3
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Some people sweep talcum powder over squeaking hardwood floors to stop the squeaks. You could try sprinkling talcum powder over the spot in your trailer and letting it settle through the carpet backing if it's porous. After a while use a vaccuum to lift out the excess.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 01-16-2013, 07:52 PM   #4
2009 25' FB International
Dunedin , Florida
Squeaking floors
My 2009 International Ocean Breeze 25' TT has loud creaking floors that can be heard 2 campsites away. Very embarassing for me and most probably for Airstream, too. I was told that at the repair shop they would shim up the floor from the underside. My question is, would the bottom pan have to be removed to access the area to be shimmed? The areas are under the entrance and in the bathroom. I can certainly shim up the areas, but not sure what I''ll encounter under there.
Thanks for any input.
dunedinfan is offline   Reply With Quote
