Old 05-18-2013, 11:06 AM   #1
Cheboygan , Michigan
Angry Black water leak, OUCH!
Hello fellow Airstreamers:
I have a small amount of what appears to be back water dripping out of a weep hole in tank farm belly pan.
Have any of you removed the belly pan under the black water tank?
Our Airstream is a 1998 34 ft Excella.
It isn't leaking much but, it won't get better by itself.
I will appreciate any information that may make a not too good of a job go better,
Tom
1998 34 Excella
2008 GMC 2500HD Duramax
teedunlap is offline   Reply With Quote
Old 05-18-2013, 01:25 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sorry to hear. I would drain tank a d sanitize best i can. Then sanitize again. Let sanitized water leak out a lot longer than it has been leaking.
I would not lay under to drop tank. Buy that's your call. I would want a pit like an oil change joint to drive in and service this problem.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-18-2013, 07:50 PM   #3
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Yea dirty work... I wonder if you can rent a bio hazard suit any where? Good luck, you will have to get in there to figure out where it is leaking from..
Silverflames is offline   Reply With Quote
