Old 10-21-2007, 09:27 PM   #1
1999 25' Safari
Sebastopol , California
Painting 1984 Excella Walls
What type of paint do I need to paint right over the walls in my Excella 1984 31'?
Aluminumb is offline   Reply With Quote
Old 10-21-2007, 10:44 PM   #2
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
More info, please! Do they have cupboards attached? What is on there now? We have older vintage and used zolotone. Love it. But probably isn't what you need... are your interior walls you want to paint, wood? plastic? aluminum? You might post a picture or so and let folks know what you want to accomplish, you will get lots of help that way.
Good luck,
Mrs. NorCal Bambi (traveling in S Tardis ~ from the Great State of Jefferson)
CaddyGrn is offline   Reply With Quote
Old 10-22-2007, 05:36 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
In 1984, the interior walls were flexible PVC laminated to aluminum. You need to use a primer what will block the plasticizer migration and adhere to plasticized PVC. The original Kills solvent based primer might be a place to start. A solvent urethane based primer might also work. After you prime the walls, you could use any latex scrubbable egg shell or semi-gloss enamel. I would not reccomend any flat type finish as it will hold dirt and not be as washable.
Old 10-22-2007, 06:18 AM   #4
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
Speaking as a house painter,Grahams paint out of illinois makes a wonderful flat ceramic paint that would be incredibly washable ! At 45.00-48.00 a gallon it should be !!! Also a primer that is acrylic (such as gripper from glidden ) will work also,but you must let it dry for at least 48 hours.
Rollerboy is offline   Reply With Quote
Old 10-22-2007, 07:43 AM   #5
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
We just primed the entire interior of our Argosy with Glidden Gripper this weekend. It took two coats to cover the nasty yellowed endcaps, but the walls covered great with one coat - except the bathroom, which took two.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 10-22-2007, 07:51 AM   #6
1969 31' Sovereign
atlanta , Georgia
Hi - I am getting to the tail end of a 12 month resto mod on a '69 31' sov - we wanted interior walls to be smooth and durable so we taped off and sprayed two coats of heavy auto primer - finished up with two coats of oil based interior house paint. Very nice end product. Also used auto primaer and paint for all interior trim and end caps.
j-
nunya001 is offline   Reply With Quote
Painting Walls of Bambi Marshall44 Upholstery, Blinds, Walls & Interior Finishes 13 04-19-2010 01:25 PM
Thoughts on painting oak cabinets & walls potatoes Cabinets, Counter Tops & Furnishings 17 01-16-2006 10:56 AM
Painting Interior walls, Ceiling DJbyRequest General Interior Topics 37 05-29-2005 09:51 PM
1984 Excella WHAT? muvywrtr 1984 -1986 Excella 6 02-13-2005 12:09 PM
Painting plastic walls and bathroom sink jwaldin Upholstery, Blinds, Walls & Interior Finishes 4 11-14-2003 08:37 AM
