Old 02-06-2014, 07:54 PM   #71
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Been meaning to thank you for the info on using krylon fusion for painting plastic. I will make sure from here on out that anytime I paint plastic, I will use Krylon Fusion.
I keep picturing the zillion empty cans you used to paint the interior of your airstream using krylon fusion.
Thanks also for the info on the outside shower and painting it with Nickel Shimmer.
Dan
Old 02-12-2014, 07:10 AM   #72
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I used Fusion on my Overlander bathroom sink. It came out nice and clean looking and has been used for almost two years...
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-13-2014, 09:20 AM   #73
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Alan
I painted my 66 TW sink using Porv whitecoat. I wish I had used Krylon fusion.
Dan
Old 02-14-2014, 10:21 AM   #74
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Rob installed the dishwasher and microwave cabinets, which he had to modify heavily in the installation. He is refs using the cabinets one at a time and the hickory is beautiful. We had a frustrating week: the new stove we ordered from Michigan arrived completely destroyed. We are waiting for UPS to pick it back up for return. Anyone have a 22" stove to sell?
Skatiero is offline   Reply With Quote
Old 02-14-2014, 10:28 AM   #75
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Here is the dishwasher installed.
ID:	205596   Click image for larger version
Old 02-14-2014, 10:59 AM   #76
1986 32' Excella
potomac , Maryland
All, is there a common source for the leak which ends up rotting the floor just inside and to the right of the front door?
camsoldman is offline   Reply With Quote
Old 02-14-2014, 11:27 AM   #77
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
I blame it on the aluminum over the step. Splash water can penetrate the panel and sit on the wood. I enlarged the panel and sealed it to death so hopefully it will not happen again.
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 02-14-2014, 11:31 AM   #78
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Suhweeet!!! Is that a dishwasher made specifically for RV's? I've never seen one (I guess I haven't looked), but with your crowd, it's a great thing, I'm sure!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 02-14-2014, 12:36 PM   #79
m.nolte's Avatar
1967 30' Sovereign
Fairhope , Alabama
Whoa, a dishwasher. I'm impressed!
Melissa
m.nolte is offline   Reply With Quote
Old 02-14-2014, 02:27 PM   #80
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Oh, we love the dishwasher. We have one in our 29' too. (we are selling the 29' as soon as this 32' is mostly complete.) it saves time, water, hot water, and gray tank space. It is super quiet and does a great job washing the dishes and makes us choose real dishes over paper. It also stores the dishes, so there's no loss of storage room.
Old 02-14-2014, 04:36 PM   #81
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
loking good Katie and Rob...almost stopped by today to see it as we were around the corner,,,but my new to me truck was leaking gas...so we ran back to the dealership where they replaced the fuel filter. Thankfully that was all it was.
Hope to see it soon..
AIR #005
retired!
Old 02-14-2014, 05:08 PM   #82
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Alana, aww, we would have loved to have seen you! Come back soon! Hope you are enjoying the new truck, fuel filters aside!
Old 02-14-2014, 05:58 PM   #83
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
As far as leaks, I learned fairly quick that it's not worth the effort to try and locate a specific leak but I take a weekend and scrape out the old and I use adseal for the larger seams and acryl-r for the small seams around the windows, panel seams, doors etc. and I do the whole trailer. I buy it from airstreams website. I also use rustoleum oil based white paint on the roof which keeps it cool and helps seal around rivets on top. I will say though that there are a few areas that are more critical than others to seal. Make sure your vents are sealed on top. Make sure that if you have an awning that you seal where the rail is attached to the roof and it's rivets. That was where my 89-29 was leaking down onto the floor to the right of the door. Also, people ignore the lower rubrail and it must be sealed on the top. I use a small bead of adseal on the top of it all the way around the trailer. I always use blue tape on both sides of the bead then remove it. It looks pro that way. You don't ever need a very big bead. Most people use too much. When I was replacing some sub floor I watched water pour in through the lower rubrail and it soaks the insulation in the belly pan and the bottom of the subfloor stays wet and rots. I'm not listing everything but some other areas are adseal on the window eyebrows and acryl-r on the sides and bottom. I run a small bead of adseal on the top of the top beltline rail because that is wear the panels over lap. It wouldn't hurt to do the bottom beltline rail as well to keep it out of the rivets that attach it. My pet peeve is not glopping sealant of any kind all over and using to much so that's why I tape.
Rob
Old 02-15-2014, 09:00 AM   #84
danjoe91's Avatar
1985 32' Excella
Valley Village , California
Images: 16
Everything you do looks amazing. I thought about the dishwasher, but it's just the two of us and I wasn't sure if I would be getting a little too crazy by adding it, but it might be worth it in lower water consumption and grey water tank space. What brand is that?
danjoe91 is offline   Reply With Quote
