Old 06-30-2015, 10:20 AM   #21
1985 31' Excella
Dallas , Texas
Well, the green ball tires are already on their way, so I guess I am trying them for a bit at least. I won't be doing much overland traveling for the first couple of years at least. The airstream will be out in the boondocks near my land and I will be working on it, so the tires should be good for a while.
Jacob, which battery did you get? Bluetop Type 27? And, given the info supplied earlier, did you change out the charging system? What with?
Todd
busoluv is offline   Reply With Quote
Old 06-30-2015, 01:01 PM   #22
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Agree with the Optima. I put a Yellow Top in my Pathfinder. Motorcycle batteries are AGM batteries, too.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-04-2015, 09:55 AM   #23
danjoe91's Avatar
1985 32' Excella
Valley Village , California
Images: 16
I have been using the Reese hitch with the friction sway control and my 1985 31' tracks beautifully. As far as tires go , currently I have St225/75 R15 sized tires on the original 15" rims. I am considering moving up to 16" rims so I can have the Michelin LT tires put on. I do not want Chinese made tires. There are as many choices as there are opinions on this, so good luck!
danjoe91 is offline   Reply With Quote
Where is the anti sway device located/electric brakes? Mrcrowley Electrical - Systems, Generators, Batteries & Solar 19 07-07-2006 12:40 PM
Anti sway on a 16' Bambi Gnostic Hitches, Couplers & Balls 40 06-10-2006 08:39 PM
Best combo WD anti-sway hitch wacnstac Hitches, Couplers & Balls 6 03-03-2006 02:59 PM
Dual Cam Anti-Sway Roswell On The Road... 7 04-20-2004 09:57 PM
Trouble Drilling to Install Anti Sway Cams DEO Hitches, Couplers & Balls 21 02-26-2004 05:15 AM
