Old 10-21-2003, 09:45 AM   #1
85EXCELLA32's Avatar
1986 32' Excella
Crestline , Ohio
Question mystery drain valves
Need help locating the 3 drain valves on my 1985 Excella 32 ft. road side center bath? The manual indicates three valves of which I yet to locate. There is a small T-handle just off the pressure reg. line. But it only turns and with no water flow at all. Iíve considered blowing air through the lines and then just adding antifreeze through the city water hookup but not sure this will fill the water lines at the level of the 3 mystery valves.
Thanks for any input on this!
Jerry
On the River
85EXCELLA32 is offline   Reply With Quote
Old 10-21-2003, 12:27 PM   #2
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Your best bet is to buy a RV Pump Converter Winterizing Kit. This is the easy and practical way to fill the water lines in your RV with antifreeze. The kit installs before entering the water pump and allows you to use your pump to draw anti-freeze from the bottle to winterize your system. Does your trailer have the water heater-by-pass kit?
Dwight is offline   Reply With Quote
Old 10-21-2003, 12:54 PM   #3
1986 32' Excella
Crestline , Ohio
No I wish the hot water tank did have the by-pass. I've considered installing one but I would have to remove the mattress and the plywood under the dbl bed to install it and then every spring and fall to open and or close it.
I know 7 gal. vs 2 gal. to do the winterizing.
I have a spare 12 volt pump rigged up to pump anti. in from the city water hook up hopfully this will fill all the lines once the hot water tank is full.
Jerry
On the River
Old 10-21-2003, 01:43 PM   #4
LOST , Hawaii
Run some through the fresh water tank and your pump also.
Look underneath for openings in the skin, that should help locate the drain valves.
John
74Argosy24MH is offline   Reply With Quote
Another question - Drain valves kamadeca Waste Systems, Tanks & Totes 12 07-24-2004 11:29 AM
'86 345 AS MH Drain Valves Jim Tyrney Airstream Motorhome Forums 12 12-06-2003 09:28 PM
The Case of the Dual Mystery Valves.... drboyd Plumbing - Systems & Fixtures 2 11-16-2003 05:14 PM
mystery battery drain FOUND Curtis-79MH Airstream Motorhome Forums 1 06-18-2003 09:03 AM
Drain valves on '79 Sovereign smily 1974 - 1979 Sovereign 3 01-28-2003 11:09 AM
