Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1984 -1986 Excella
Old 02-20-2018, 01:49 PM   #1
1986 34' Excella
Stewartstown , Pennsylvania
Question '86 Excella double axle wheel well repair?
Hey guys. I've seen that from time to time people have had the problem of a blowout on the trailer breaking the outer and inner lining for the wheel wells on their excella. I went ahead and purchased the replacement before researching how it's installed.
Let's just say I'm in no position to rip out the entire bathroom and subfloor right now.
Luckily the outer liner is split in a few ways but mostly there. If it were fabric, I could sew it back together. I've seen repairs on such plastic before with fiberglass tape and epoxy. I was wondering if anyone has any howto on that method of fixing? Since I have a spare wheel well inner/outer cover, I can cannibalize it where I need to. I just need to know what type of epoxy/tape to use.
Thanks in advance!
bsimmons is offline   Reply With Quote
Old 02-20-2018, 01:53 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have used rattle can expandable foam to fill the gap between inner and outer fender well with good results. Also glues the pieces in position. I have also pop riveted a patch with Vulkem (now Trempro 116) sealing the edges. If you have hair cover it. Only way to get the goop out is to cut it.
Old 02-20-2018, 03:14 PM   #3
1986 34' Excella
I'll certainly have to give that a think. Thank you.
Old 02-20-2018, 04:05 PM   #4
1999 30' Excella 1000
small town , Maryland
Can you use the new one as a liner for the old ? Remove tires, trim edges to fit from outside, rivot and silicone caulk perimeter to seal. My .5 cents not 2cents.... Almost forgot...Welcome to the forum bsimmons
streaminwild is offline   Reply With Quote
Well, well, well...you'll never guess what followed us home today! InsideOut Vintage Kin 86 06-08-2023 08:54 AM
Judging axle condition by wheel well idroba Axles 8 05-21-2012 09:14 AM
Well, Well, Well........ Jim & Susan Off Topic Forum 54 06-12-2005 12:46 PM
