Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1978 Excella
Old 08-17-2004, 08:01 AM   #1
Excella 31' Curb weight
Has anyone weighed their Excella 31 loaded as we usually haul them? If not, what is your best estimate of the weight?
I'm getting a new tow vehicle, and need a realilstic weight estimate, not the bare-bones unloaded one.
Bill & Jeanne Miller
78 Excella 31 CB
St. Louis
wvmiller is offline   Reply With Quote
Old 08-17-2004, 08:19 AM   #2
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
The best solution is to take the GVWR printed on the plate of the trailer.
My 31 ft Excella says 8300 lbs.
Some people load an ungodly amount of "stuff" in their trailers and are probably overloaded. That tells me that once you are loaded, a trip across a scale is a great idea to make sure you are not overloaded for the sake of your frame and axles.
If you take 8300 GVWR, and want a 25% margin for travelling in mountains you get 10,375 needed towing capacity.
So, large block gasser with proper axle ratio, or diesel is the best way to go if you want to be able to have any hope of staying with the flow of traffic in any kind of hilly terrain.
I used to tow mine with a 350 in a Yukon. The thought of coming out of the hole at Santa Rosa, NM on I-40 headed West to Clines Corners at 42 mph in 2nd gear and 3000 rpms as the 18 wheelers blow me off the road at 80 mph was enough to cause me to not want to do that, ever.
So, I towed in the flats of West Texas until I could upgrade my tow rig to a Duramax/Allison. Now, I don't even know the trailer is behind me. Instead of white knuckles, and transmission temp, engine temp, and oil pressure guage watching, I just drive pretty much worry free about the performance of my tow rig concentrating on the road and other traffic. It is much less busy and much more enjoyable. And, definitely makes me glad that the tow capacity of my tow rig is not mariginal for the trailer I am pulling.
dscluchfc is offline   Reply With Quote
Old 08-17-2004, 08:20 AM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Excella 31 Curb weight
Greetings Bill and Jeanne!
Based on the empty weight for a '78 Excella of 4,850 pounds and empty hitch weight of 580 pounds, you are likely dealing with a realistic gross weight of between 6,500 and 7,000 pounds - - remembering that the factory empty weight does not include options nor fluids.
Another option would be to check the placquard on the front of your coach that has the serial number and related information. If it is like the placquard on my '78 Argosy Minuet, it should list the GVWR or Gross Vehicle Weight Rating for your coach - - in the case of my Minuet it is within 150 pounds of the actual gross loaded weight of the coach. The GVWR would give you a starting point for the minimum trailer tow weight rating for a prospective tow vehicle.
As an example, my '64 Overlander has a listed factory empty weight of 3,930 pounds with an empty hitch weight of 405 pounds - - the actual empty weight figures including options and accessories is 4,440 pounds with an empty hitch weight of 465 pounds. The actual gross weight when loaded for an extended vacation is 6,100 pounds with a gross hitch weight approaching 775 pounds depending upon how full the 40 pound LP tanks happen to be at the time.
My recommendation would be to consider a 3/4-ton based vehicle with either the big-block gas V8 or the diesel if you prefer that fuel type. I know that the 1500 (1/2-ton) Chevrolet extended cab pickup that I had prior to the Suburban was struggling with my '64 Overlander on aything but level terrain. The Suburban has been a wonderful tow vehicle from the time of purchase (ordered new to my specifications and delivered 4-21-98), and now has in excess of 131,000 miles - - have never regretted going with the big block gas V8 nor the 4.10 differential gearing.
Good luck with your search for the ideal tow vehicle!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 08-17-2004, 09:29 AM   #4
Tow vehicle
For a variety of reasons, I prefer a Suburban-type vehicle to a pickup. I've always used 3/4 ton big blocks until 2001, when I bought a 1500 4x4, looking for a better ride. I knew it was light on power, so I added a Whipple Supercharger, some suspension modifications, and it has had more than adequate power for all occasions.
Unfortunately, the 4L60E tranny burned up at 42,000 miles! Also, the lighter frame and chassis components become obvious when you tow.
I am agonizing between the 2500 4x4 Suburban with a 6L and 4.10 rear axle (with Quadrasteer, which is terrific), one with a big block and 3.73 gears (no Quadrasteer available, though), and and Excursion with the 6.0 diesel. I've been a Chevy guy all my life, but that is a pretty effective tow vehicle with lots of room for big family on long trips.
Choices, choices, choices,,,,,,,
78 Excella 31 CB
St. Louis
Old 08-17-2004, 07:32 PM   #5
Cracker's Avatar
Pittsfield , Maine
78 31' Excella Weight
[QUOTE=overlander64]Greetings Bill and Jeanne!
Kevin:
Not questioning your weights at all - but just surprised that a '78 Excella is so much lighter than the current models. Aside from the Corian countertops and the oak cabinetry is there anything else that added substantially to the weight???
Cracker
Cracker is offline   Reply With Quote
Old 08-17-2004, 08:16 PM   #6
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 194
Greetings Cracker!
[QUOTE=Cracker]
Kevin:
The empty weight figures are from the Airstream corporate website, and have proven to be relatively accurate so long as one remembers that for the Vintage coaches the empty weight didn't include any optional equipment. You can see the progression of a gradual increase in empty weight as time progressed with the coaches - - reflecting changes in standard vs. optional equipment as well as in materials utilized in construction. Throughout much of the 1970s, the coaches were still being built with the idea that most owners would likely use a full-size family automobile to tow the coach so there was greater concern about maintaining lighter weights. You can find the weight charts at:
Airstream Weights and Measures
The base 30'/31' Airstream Double Bed/Rear Bath model progressed from:
1957 - - 3,860 pounds empty trailer weight/355 pounds empty tongue weight
1965 - - 4,370 pounds empty trailer weight/410 pounds empty tongue weight
1968 - - 4,640 pounds empty trailer weight/415 pounds empty tongue weight
1970 - - 4,960 pounds empty trailer weight/490 pounds empty tongue weight
1974 - - 5,065 pounds empty trailer weight/495 pounds empty tongue weight
1978 - - 4,850 pounds empty trailer weight/580 pounds empty tongue weight
1982 - - 6,800 pounds empty trailer weight/650 pounds empty tongue weight
1988 - - 6,500 pounds empty trailer weight/800 pounds empty tongue weight (side bath as no rear baths listed for 1988 31'/32')
The pre-1980s coaches were somewhat lighter in weight than the coaches that would follow. Part of that can be attributed to the level of standard equipment included with the coach as well as to the materials utilized in the manufacture of the coaches.
Kevin
P.S.: Looking at the figures, it would appear that some adjustments were made between 1974 and 1978. My speculation would be that it was a reaction to the Oil embargo and resulting energy crisis concerns that followed.
Kevin D. Allen
AIR #827
Old 08-17-2004, 09:25 PM   #7
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Kevin- During the Beatrice years, in order to lower weight, in response to the oil embargo, and lower sales, compromises were made. The chief compromise was in the weight of the frame as the Beatrice owners opted for a lighter frame. This backfired to some extent as the tail sag and rear end separation years happen to coincide with the Beatirce Foods ownership years.
Once Thor was the owner, and the engineering problems diagnosed, the frame was once again beefed back up, and therefore the weight went up again.
Also, you are correct that there are many more "standard" features that are not aftermarket add-ons today, that also has increased the "base weight" from the earlier years.
Still best to look at the plate and see what the GVWR is for the trailer with the present axles to begin to determine what capacity tow vehicle to aquire.
...just my 2 cents....
Old 08-18-2004, 04:04 AM   #8
IceKing02's Avatar
Recent towing experience with 31' Excella
I just pulled my 81' Excella II for 5,000 miles with an 02 King Ranch 4x4. It has the 5.4L engine and 3.55 gearing which are maybe not ideal for towing. Even so I had few modifications (electric fans and a rear sway bar) and a positive experience with towing. As dscluchfc noted previously there were two times where I was towing along at 42mph in 2nd gear because of 9% or 10% gradient to the road (NY to AK and crossing the Canadian Rockies). As long as I was with traffic it was no problem to cruise along at 70+mph but you don't get to set your cruise control and ignore hills. Already I am convinced that a supercharger (and other modifications) is the way to go for me. I am unwilling to depreciate another vehicle just to get a diesel. Besides, as a daily driver my F150 is just fine to suit my everyday needs. I'll beef up the power and risk blowing out the tranny, which is more likely to happen while doing high-speed passes at the local raceway...
Don't forget the fact that while in Canada we were regularly filling the 25 gallon tank for $70-85 canadian and getting 7.9mpg (worst tank) to 10.6mpg with an overall average of 9.7mpg (light right foot). The diesel is cheaper and giving you better mileage overall. Also, don't underestimate the extra work that you will be doing when there's no option to punch in the cruise control. It makes a difference in terms of driver fatigue. Good luck!
"Few things are impossible to diligence and skill" -Samuel Johnson
IceKing02 is offline   Reply With Quote
Old 08-18-2004, 08:09 AM   #9
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Ice- Great comments. My Duramax gets 20 mpg solo, 17 average driving, and about 11 towing 70+ mph.
With the torque of the diesel, I could set the cruise, except that when towing, I don't know that setting the cruise is the safest thing to do as you are not as "engaged" in driving as maybe you should be when towing if the cruise is on.
The largest difference I notice in towing with the diesel vs. the 350 Chevy is in driver fatigue. I no longer arrive after 300-400 miles absolutely fatigued. I could easily drive 500-700 miles in a day with the diesel and still not be as tired as I was with the too small gasser.
The benefits of not arriving tired are alone worth the price of the Duramax in my opinion.
Old 08-18-2004, 01:46 PM   #10
IceKing02's Avatar
Additional "Recent towing experience"
dscluchfc,
Even if I can drive the additional mileage, my 4 year old, my 2 year old and my lovely, loving wife won't tolerate more than six hours in the truck without complaint...
Old 08-18-2004, 07:23 PM   #11
Cracker's Avatar
Pittsfield , Maine
Back to Kevin:
An interesting summary of the weights from 1957 to current models! I initially worried about not having sufficient capacity for all of our gear. So far it does not seem to be a problem - however, I haven't run the trailer across a scale since I loaded up for travel. Time permitting, I plan on doing the scale thing this weekend.
Cracker
Old 02-18-2006, 02:40 PM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Interesting reading guys. So if you were starting from scratch-a 25000 budget in mind would you think a 70's to early 80s Excella in the 30' range and a decent 90s diesel truck would be the solution? Sound conceivable?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-18-2006, 02:54 PM   #13
I've towed my Excella 31 for years now with a 3/4 ton Suburban with a big block, and a 1/2 ton Supercharged Suburban. The 3/4 was better at towing, but the 1/2 ton get better mileage and has a better ride when we are not towing. Mileage is pretty grim either way. With diesel more than gasoline many places, it's pretty mcuh oof a wash from a dolllar viewpoint.
We prefer the Suburban for kids and dogs.
78 Excella 31 CB
St. Louis
Old 02-18-2006, 03:38 PM   #14
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Yes, it's true that diesel is now more expensive than gasoline. However, the diesel engine is 30% more efficient that a gas engine of the same displacement. What does that mean? Well, for me, it means going from a 235-hp Dodge Dakota to a 305-hp Cummins Ram, and now I'm getting 20 mpg mixed instead of the Dakota's 14. The BEST the Dakota ever got was 17 mpg.
The fun part of having the Cummins is putting THREE GALLONS of oil in it at oil change. (And filling up a 35-gallon gas tank.)
Also, this engine is known for going 500,000 miles before needing overhaul. I've never been in a Duramax/Allison, but I used to work as a critical transport paramedic, and I can honestly say that Ford Powerstrokes have left me broken down all over the American southeast. Getting a Cummins diesel of my own was just sanity preservation.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 02-18-2006, 05:56 PM   #15
Steve Heywood's Avatar
1997 30' Excella
Waddell , Arizona
Images: 13
7850-8100 lbs loaded for a family of 3 and a small dog.
Steve Heywood
Waddell, AZ
1999 19' Bambi (SOLD)
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 02-18-2006, 10:22 PM   #16
Cedars's Avatar
1983 31' Excella
Waterloo , Iowa
just looked at the weight charts AGAIN!! Seems like I have spent a lot of time looking at those things over the years.
And I really apprecaited your explaination of weight gain over the years, Kevin.
Now, can you explain to me why a 1982 31, Excella center bath, weighs 6800-600 and our 1983 31 Excella, center bath says 4950-600? that indicates a LOSS of 1850 pounds in general, doesn't it?
Do you suppose that 6800# figure is actually the GVWR?
I know the charts are generally accurate but this detail between the two years same model, really bothers me!
Elizabeth in Iowa
The carpeting is gone! The carpeting is gone! Long live the cork floor!
Cedars is offline   Reply With Quote
Old 02-19-2006, 07:26 AM   #17
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
[quote=SafeHarbor]Yes, it's true that diesel is now more expensive than gasoline. However, the diesel engine is 30% more efficient that a gas engine of the same displacement. What does that mean? Well, for me, it means going from a 235-hp Dodge Dakota to a 305-hp Cummins Ram, and now I'm getting 20 mpg mixed instead of the Dakota's 14. The BEST the Dakota ever got was 17 mpg.
Other than mileage how was the Dakota as a tow vehicle? A smaller truck might suit my lifestyle better. I am getting out of a Jeep GC and consideriong something that can tow, and also is extended cab.
AIR #005
retired!
Old 02-19-2006, 09:50 AM   #18
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
Hi, Alan,
I can't say about the modern Dakotas. Mine was a 93 model that I ordered and got in Nov. 92. I ordered it expressly to tow the Argosy. I specified the 4.01 rear end, the 5.2L V8 (old 318), the heavy duty suspension package (which really made it a one-ton truck), and the tow package.
It pulled the Argosy great, but it wasn't powerful enough or heavy enough to tow the Excella. Coming back from Michigan last year, I was climbing hills in Appalachia at 55 mph and 3500 RPM.
The truck itself was great. I drove it from 1992 to 2005, and in 128K all it ever needed was the ventilation blower repaired and a new water pump at 100K. And a headlight switch rewiring in the campground at the Ft. Desoto forum rally in October.
The main problem when towing the Excella with the Dakota was passing trucks blowing the back end of the trailer one way and then the front end (and the truck) the other way. I was able to overcome this slightly by driving on the extreme right edge of the lane and then briefly steering toward the overtaking truck as it approached. If I timed it just right, the trailer would be moving leftward just as the air blast from the truck hit the back. I would already be making the correction, and the air blast reaching the front would help me straighten out as the trailer came back into trail in the original position on the far right.
As you can imagine, this requires concentration, and the timing has to be JUST RIGHT. And, by the way, some of the truck drivers REALLY don't like it.
Towing the Excella made me rethink what I want in a tow vehicle.
I decided to get the longest wheelbase, heaviest vehicle I could find. I don't need a truck very often, but when I do, I NEED a truck, so the Suburban would not have worked for me.
I have a friend who has a Durango with the V8, and he's never seen more than 14 MPG from it, even doing a 50 mile commute out in the country. I doubt a Dakota extended cab model would do much better.
Lamar
Klaatu barada nikto
Old 10-10-2014, 04:56 PM   #19
Happy Wonderer
B_Pi's Avatar
1997 25' Safari
Box Elder , South Dakota
What is it with towing a trailer at 70+ mph?
That is not legal in many places and foolhardy otherwise in my opinion.
We keep it -60 mph no matter where.
B_Pi is offline   Reply With Quote
Axle weights limits vs. combined weight - What am I missing? Section8 Towing, Tow Vehicles & Hitches 27 06-07-2022 05:40 PM
1976 Excella 500 urb2165 1975-1976 Excella 500 12 06-11-2011 12:00 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
