Old 09-21-2002, 05:38 PM   #21
1962 19' Globetrotter
2001 31' Excella
Craig,
I'll do that. The original is nothing special. Just a black button with a small white circle around the button. I think the replacement I bought looks much better than the original...
Now I've replaced the button and the chimes and still nothing! Jumping the posts doesn't make the new chimes chime either.
Craig
Craig is offline   Reply With Quote
Old 09-22-2002, 09:21 AM   #22
2001 31' Excella
Ok, unless anyone has any other ideas, I'm giving up on the doorbell. I've replaced the switch and the chimes and still nothing. I can't believe something so simple is causing me so much frustration.
Old 09-22-2002, 09:59 AM   #23
2001 31' Excella
Got it!!
Forget my last comment. I got it working!! Still not sure what the exact problem was, but after I replaced the switch, the fuse must have blown, because I checked the fuse before I started and it was fine.
My lesson learned is to keep checking the fuses! Thanks to all for providing help.
Old 09-22-2002, 11:48 AM   #24
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Jumping posts
If you jumped the posts on the switch, no harm would be done. If you jumped the posts on the chime itself with the button pushed, you would have blown the fuse by bypassing the coil in the chiime.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 09-23-2002, 04:47 PM   #25
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Craig,
Glad to see you got the doorbell squared away. What's your next project?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-23-2002, 07:32 PM   #26
2001 31' Excella
Craig,
I ordered the new hot water heater today...
Craig
Old 09-24-2002, 07:43 PM   #27
davidz71's Avatar
1986 25' Sovereign
Craig,
I saw where uwe was recommending the install. I will probably print his suggestions out and save it for future use.
Craig
AIR #0078
3.73 rear end
Old 04-03-2003, 06:14 AM   #28
pap
My doorbell works...just about the only thing on the Excella that does.
But as I was reading this thread I noticed a very good question that had not been answered. Surely with all the electrical expertise on the forum someone knows don't you think??
Fred H. asked in this thread back in Sept.2002:
I looked in Lowe's at door bells. They are all 16v and use a converter to change the house 120v to 16v. How should that work in RV?
pap is offline   Reply With Quote
Old 04-03-2003, 06:59 AM   #29
Contributing Member
Pahaska's Avatar
Doorbell voltage
Common household doorbells will work just fine on 12v DC. The household converters put out 16v AC which is a sine wave. It is the average voltage that rings the bell/buzzer and that is a lot less than the 16v peak. If you look at the RMS (Root Mean Square) of the 16v AC, you will find that the energy content is not far from what you get with 12v DC.
John W. Irwin
WBCCI #9632
Old 09-10-2017, 11:00 AM   #30
journeydog's Avatar
2018 28' Tommy Bahama
Silver City , New Mexico
Door Bell Power
My door bell is made by NuTone and powered by 4 C batteries. The bell stopped doing it's 'ding' after about a 300 mile ride. I opened the white box under the fold-down kitchen counter extension and found that 3 of the 4 batteries had come loose and fell out, probably while in travel. The box design and construction is pretty M-Mouse, so I put some fairly thin foam inside the cover of the box lid before replacing it to put a little pressure on the batteries to hold them in place - so far, so good.
Class A Safari Trek 2830 - SOLD, TC Lance 1010 - SOLD,
TT Arctic Fox 30U - SOLD, TT Forest River Mini - SOLD
Class B+ Pleasure Way P
ursuit - FS, $$$$ - GONE
If it ain't broke I can break it
A dime still makes a pretty good screwdriver
journeydog is offline   Reply With Quote
Old 09-10-2017, 11:37 AM   #31
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
My button on my 93 Excella is located on the trailer grab handle next to the door. A couple of years ago the button wires broke off. The repair would involve removing some inner skin. To me it's not worth it. I disconnected the power at the bell itself under the couch. If I ever fix it I may put in an A-oo-gah horn under the stairs.
Doorbell Fuse?- '88 345 Classic Mh jslee77 General Motorhome Topics 2 11-24-2003 06:03 PM
Door bells smily Electrical - Systems, Generators, Batteries & Solar 1 10-23-2003 11:35 AM
Dead doorbell on '92 30' fangthorpe Mechanics Corner - Engines, Transmission & More... 5 05-09-2003 10:00 PM
