Old 08-28-2016, 09:40 PM   #1
MHH
1982 27' International
Allen , Texas
Water won't flow into RV. Help ?
Why will water not flow to inside the RV?
MHH is offline   Reply With Quote
Old 08-28-2016, 10:03 PM   #2
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Some additional details would be helpful. City water fitting? Filling Tank? What are you trying to do?
Old 08-28-2016, 10:12 PM   #3
MHH
Allen , Texas
City water connection. Is there a filter somewhere that could be stopped up? Thanks
Old 08-28-2016, 11:09 PM   #4
2004 22' Safari
Inside the city water connection there is a check valve.
If the check valve has come apart inside the connection it can restrict water flow into the connection.
You may need to replace the whole connection to fix. A temporary solution to get water into the trailer is to fill your tank from the portable water filler.
Northerngirl is offline   Reply With Quote
Old 08-29-2016, 05:16 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
One possibility - There may be a water pressure regulator in the inlet pipe. If it is there it will look similar to this:
Some of these have a screen inside that is intended to stop sand and sediment that comes in through the hose. Sometimes the screens accumulate so much stuff that the water can't pass through. If this pressure reulator is the problem you may be able to clean out the debris, but I suggest replacing it.
Another possibility - Some people install a washer with a screen at the inlet, where the hose connects. Look inside where you connect the hose to see if that might be clogged up.
This is a link to a copy of the 1982 owners manual, in case you do not have one.
https://www.airstream.com/wp-content...0110i.arc_.pdf
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
No water flow after hooking to city water Grevers911 Fresh Water Systems 8 06-23-2013 10:08 PM
Shur-Flow Won't Quit jdalrymple Water Heaters, Filters & Pumps 2 09-15-2008 06:27 PM
Help! Graywater backing-up into bathtub / won't drain team_no Waste Systems, Tanks & Totes 5 01-01-2008 06:15 PM
city water won't flow..help! AirSpleen Fresh Water Systems 9 08-20-2006 05:39 PM
