Old 03-09-2015, 12:35 PM   #1
1982 31' Excella
Missoula , Montana
Tool kit
I am a semi newbie for the airstream world but not to the repair world. We live in western Montana, and do some boon docking and also some road trips.
I have another 5000 mile road trip coming up and was trying to cut down on my tool inventory. I have a 1982 Excella 31 I have replace everything but axles on the running gear, have pulled trailer 7,500 miles since I purchased and only one water leak, plumbing.
Most of the tools have been used by others or for routine maintenance. The tools are carried in back of my pickup in 3 tote boxes, and 1 small grip, as I call it what i use all the time grip, Attached is my current list for tools I carry. I feel sometimes I carry to much and sometimes maybe not enough. Any suggestions will be greatly appreciated.
Please let me know if I really do need therapy, as my wife says.
The one thing I learned from my gramp ( old AG dealership)was if its mechanical it will break.
Randy
SSC (Silver Senior Center)
SSC TOOL KIT
GORILLA TAPE; most important tool in kit
GLOVES; LEATHER, MECHANIC GLOVES, HD RUBBER GLOVES, THROW AWAY RUBBER GLOVES,
SOCKET SETS ;1/2”- 3/8” METRIC AND US TO 1”
WRENCHES; ¼” THRU 7/8” METRIC 4MM THRU 20MM, 2 CRESENT WRENCHES
3 SCREW DRIVERS PHILIPS AND FLAT
18 VOLT IMPACT DRIVER; only way to remove old rusty screws
5 PLIERS; SIDE CUTTERS, NEEDLE NOSE , REGULAR PLIERS, WATER PUMP, & VISEGRIP
HAMMERS ETC; CLAW HAMMER, RUBBER HAMMER, AXE, SMALL HACKSAW, TIN SNIPS, CENTER PUNCH, EMERY PAPER
ELECTRIC KIT; WIRE, MULTIMETER, CONNECTORS, SOLDER GUN, SILVER SOLDER, WIRE TIES, FUSES, LED BULBS, TEST LIGHT, 4 ALLIGATOR CLIPS, ELECTRIC TAPE, JUMPER CABLES, WIRE STRIPPING AND CRIMPING PLIERS, WIRE NUTS. SHRINK TUBE
PLUMBING KIT ; PEX TUBING, PEX SHARK BIT CONNECTORS 2 STRAIGHT AND 2 45*, VARIOUS SIZE HOSE CLAPS. HOSE WASHERS, PLUMMERS TAPE.
RIVET KIT; VARIOUS SIZE RIVETS, RIVET GUN, DRILL BITS, 18 VOLT VARIABLE SPEED DRILL W/CHARGER, 3 SIZES OF STAINLESS STEEL METAL SCREWS,CAULK GUN WITH TUBE OF TREMPRO 635 IN IT.
COTTER PIN ASSORTMENT
TIRE CHANGING KIT ; TANDEM TIRE CHANGING RAMP, 4 WAY WRENCH, BACK PACK SNOW SHOVEL, 4 WAY WRENCH, 2 8X10 TARPS, AIR GUAGE. HUB CAP HAMMER, 12 VOLT COMPRESSOR, also use impact driver
EXTERIOR UPKEEP KIT; NUVITE POLISH, CYCLONE POLISHER, ORBITAL POLISHER, TOWELS AND RAGS,STEEL WOOL, BLACK METAL SPAY PAINT, WIRE BRUSH, WASHING BRUSH WITH EXTENTION HANDLE, 50 FOOT HOSE. SPRAY NOZZLE, SMALL LADDER
Vernbots is offline   Reply With Quote
On-the-road tool kit. What's in yours? gomotomoto Our Community 21 10-09-2014 03:08 PM
Airstream Interstate Tool Kit Ron_CA Sprinter and B-van Forum 6 06-07-2014 08:31 PM
What do you carry in your LY road tool kit? RhinoWW Land Yacht/Legacy Motorhomes 10 02-15-2014 10:50 PM
Road Tool Kit Reay 2005 and newer - Bambi all models 15 03-25-2013 02:17 PM
Best rivet tool? Andy R Ribs, Skins & Rivets 9 09-24-2006 07:36 AM
