Old 01-26-2015, 11:47 AM   #1
1982 31' Excella
Missoula , Montana
Shock replacement
I have a 1981 EXCELLA and tried to replace the shocks today. was able to get the first 2 unbolted but can not remove the end attached to the axle bracket. The repair book says to twist them round, I tried that, no good.
I then measured the width of the top of shock and measured the distance between bolt and frame rails. the top of shock bracket is 1/4 to 3/8 inch wider then distance between bolt and frame rails. The only way I can see to change shocks is to drop axles, or cut away part of frame
I don't think i am missing anything, but if someone has a trick that i don't know I am all ears.
I would just as soon drop axles when I need new ones.
Vernbots is offline   Reply With Quote
Old 01-26-2015, 11:54 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Pry the rubber grommet out of the old shock. If they are original they will be in two halves.
Some shocks require the bending of the bracket to gain enough clearance.
Soak the threads with penetrating oil to avoid breaking the bolt.
Old 01-26-2015, 12:03 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Below is a link to OUtofdoorsmart.com's helpful hint about changing shocks without bending, destroying anything. No doubt, it is tight!
Airstream Shock replacement guide
good luck!
Old 01-29-2015, 10:51 AM   #4
Ottawa , ON
It's helpful and gives a number of tips, and to those who didn't watch it, the trick is to cut the rubber grommet in half.
Be a lot better if the video had better lighting, many parts are just all black.
Thanks for posting it!
To Shock or not to Shock jlovelady Shocks 35 11-16-2012 08:01 AM
Shock replacement dmadam Shocks 29 09-30-2008 08:55 PM
Replacement shock golddigger Shocks 11 10-12-2006 08:38 AM
Suburban shock replacement Craig Tow Vehicles 3 11-28-2005 08:02 PM
Shock Replacement Time? 87MH Mechanics Corner - Engines, Transmission & More... 3 03-09-2003 08:41 AM
