Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1981 - 1983 Excella
Old 08-05-2016, 08:20 AM   #1
Chris_P's Avatar
1982 31' Excella
Montgomery , Texas
Mystery Switch
I just recently picked up a 1982 Airstream Excella 31' center bath/twin and need help identifying the switch street side-front in the picture. Anyone know?
Name:	ImageUploadedByAirstream Forums1470406762.309385.jpg
Thanks!
Chris P
Lake Conroe, TX
Chris P
'82 Excella 31'
'19 Ford F150 EcoBoost
Lake Conroe / Montgomery, TX
Chris_P is offline   Reply With Quote
Old 08-05-2016, 08:45 AM   #2
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
Might be the switch that turns off your converter, disconnects it from power. Flip it and see if you can hear the hum of the converter.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 08-05-2016, 08:47 AM   #3
Chris_P's Avatar
1982 31' Excella
Montgomery , Texas
Sounds logical. I'll check it out!
Chris_P
Lake Conroe, TX
Chris P
'82 Excella 31'
Old 08-05-2016, 04:09 PM   #4
Chris_P's Avatar
1982 31' Excella
Montgomery , Texas
Well the mystery switch doesn't seem to effect the converter. Could it be the switch for the up lighting behind the curtain valances?
Chris_P
Lake Conroe, TX
Chris P
'82 Excella 31'
Old 08-05-2016, 04:48 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Is it factory or user installed? I suspect the latter and if so - given its location - I wonder if it either turns those speakers on or controls the outlet underneath it.
Old 08-05-2016, 04:55 PM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
That is a 12 volt switch.... used for years and years!
With that being said it is a factory switch not necessarily installed by the factory!
Old 09-16-2016, 01:56 AM   #7
PCHCMPR's Avatar
1985 31' Excella
Los Angeles , California
I have the same switch on my '85. It is connected to a fluorescent fixture almost directly above it (behind the hardwood curtain header). It took several tries to figure it out as the light is very dim and could only be seen at night.
AIR - 99197 WBBCI - 7665
PCHCMPR is offline   Reply With Quote
Old 09-20-2016, 08:29 PM   #8
Chris_P's Avatar
1982 31' Excella
Montgomery , Texas
That's what I figured it would be for. Thanks!
Chris P
'82 Excella 31'
Old 02-14-2017, 05:17 PM   #9
Chris_P's Avatar
1982 31' Excella
Montgomery , Texas
Well I got the time to investigate the switch and see why the lights weren't working. Pulled the switch and reattached the black wires to it and blam-o!!
Chris P
'82 Excella 31'
Mystery Switch jagcb750 Classic Motorhomes 54 10-09-2011 11:50 AM
'89 Excella 25 mystery switch? Pix attached also... BillTex 1987 - 1989 Excella 12 05-22-2011 01:05 PM
Switch Mystery excella1976 1975-1976 Excella 500 2 01-26-2008 08:06 AM
Mystery toggle switch mpumphrey04 Electrical - Systems, Generators, Batteries & Solar 9 12-07-2005 07:47 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
