Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1981 - 1983 Excella
Old 10-03-2016, 05:42 PM   #1
1981 31' Excella II
Glendale , Arizona
Leaky Waste Valves
My 1981 Excella (side bath) has leaky waste valves. I'm looking to purchase this seal kit, but I see the warning that it may not work for some models with a stainless steel top plate.
My trailer is stored about 85 miles away from me at the moment, so I can't just go out there and look. Does anyone know if this kit will work for me or not?
az_streamer is offline   Reply With Quote
Old 10-03-2016, 06:46 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Leaky waste water dump valves is a common problem on vintage Airstreams. I recommend replacing the valves with Valterra valves instead. It is nearly the same work. I paid about $20 each for the valves and fittings, not that much more than the seal kit.
Airstream spent hours and hours making servicing these valves as difficult as possible during the mid 80s. So it is a major project to get the valves replaced. However, it is just work, nothing complicated.
Here are a couple of photos of the tank pan I had to remove to gain access to the valves, the new "drain manifold" with new black Valterra valves I replicated from the old Airstream one. This was done 4 years ago and I have had no trouble with them since (knock on wood).
Some folks carefully cut an access hatch in the tank pan to save removing it, and to provide access to the valves for future repairs. This is what Airstream should have done in the first place in my view.
I hope this gives you a little perspective of the job at had to get valve to stop leaking.
David
Name:	1205 ABS Cover Removed.jpg
ID:	272809   Click image for larger version
Name:	1205 New Foam Insulation.jpg
Name:	1205 New Valtera Plumbing.jpg
ID:	272811   Click image for larger version
Name:	1205 New PVC Drain Manifold.jpg
Old 10-03-2016, 07:04 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
No way would I fool with a seal kit....I replaced mine last summer. I bought new Thetford valves, adapters, and pipe for $167. I cut an access hole and made a cover out of an old street sign.
CRH is offline   Reply With Quote
leaky leaky leaky Zellia All Argosy Trailers 8 08-07-2015 05:25 AM
What brand to order for leaky waste valve DoggerStream Waste Systems, Tanks & Totes 1 05-02-2014 03:17 AM
Leaky Thetford toilet valves raebaker06 Sinks, Showers & Toilets 7 03-28-2007 07:12 PM
leaky gaskets in waste discharge jaiman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 09-01-2003 04:11 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
